Bonjour à tous
Smart sous jeedom 4.0.59
hier j’ai fait la mise à jour du plugin, et depuis, plus de lancement du demon
la maj s’est bien passée
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 9.4 (stretch)
-- Updating repo...
Get:1 http://security.debian.org stretch/updates InRelease [53.0 kB]
Ign:3 http://ftp.debian.org/debian stretch InRelease
Get:4 http://ftp.debian.org/debian stretch-updates InRelease [93.6 kB]
Hit:5 http://www.deb-multimedia.org stretch InRelease
Get:6 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Get:7 http://ftp.debian.org/debian stretch-proposed-updates InRelease [106 kB]
Hit:8 http://ftp.debian.org/debian stretch Release
Get:9 https://deb.nodesource.com/node_12.x stretch InRelease [4585 B]
Get:10 https://oph.mdrjr.net/meveric all InRelease [19.4 kB]
Get:11 http://security.debian.org stretch/updates/main Sources [217 kB]
Get:12 http://security.debian.org stretch/updates/main arm64 Packages [510 kB]
Get:13 http://security.debian.org stretch/updates/main Translation-en [233 kB]
Hit:14 https://oph.mdrjr.net/meveric stretch InRelease
Get:15 http://ftp.debian.org/debian stretch-backports/main Sources.diff/Index [27.8 kB]
Get:16 http://ftp.debian.org/debian stretch-backports/main arm64 Packages.diff/Index [27.8 kB]
Get:17 http://ftp.debian.org/debian stretch-backports/main Sources 2020-07-06-2001.22.pdiff [70 B]
Get:18 http://ftp.debian.org/debian stretch-backports/main arm64 Packages 2020-07-06-2001.22.pdiff [1312 B]
Get:19 http://ftp.debian.org/debian stretch-proposed-updates/main Sources.diff/Index [27.8 kB]
Get:20 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages.diff/Index [27.8 kB]
Get:21 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en.diff/Index [27.8 kB]
Get:22 http://ftp.debian.org/debian stretch-proposed-updates/main Sources 2020-06-28-2006.15.pdiff [979 B]
Get:23 http://ftp.debian.org/debian stretch-proposed-updates/main Sources 2020-07-02-2005.56.pdiff [2357 B]
Get:24 http://ftp.debian.org/debian stretch-proposed-updates/main Sources 2020-07-03-2002.25.pdiff [12.7 kB]
Get:25 http://ftp.debian.org/debian stretch-proposed-updates/main Sources 2020-07-04-0206.57.pdiff [31 B]
Get:26 http://ftp.debian.org/debian stretch-proposed-updates/main Sources 2020-07-06-1401.05.pdiff [12.0 kB]
Get:27 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-06-28-2006.15.pdiff [782 B]
Get:28 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-06-29-0201.41.pdiff [2969 B]
Get:29 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-07-02-2005.56.pdiff [2117 B]
Get:30 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-07-03-2002.25.pdiff [22.8 kB]
Get:31 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-07-04-0206.57.pdiff [6909 B]
Get:32 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-07-06-1401.05.pdiff [4436 B]
Get:33 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-07-06-2001.22.pdiff [2914 B]
Get:34 http://ftp.debian.org/debian stretch-proposed-updates/main arm64 Packages 2020-07-07-0200.57.pdiff [1308 B]
Get:35 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en 2020-06-28-2006.15.pdiff [1855 B]
Get:36 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en 2020-07-02-2005.56.pdiff [614 B]
Get:37 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en 2020-07-03-2002.25.pdiff [3991 B]
Get:38 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en 2020-07-04-0206.57.pdiff [4141 B]
Get:39 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en 2020-07-06-2001.22.pdiff [2355 B]
Get:40 http://ftp.debian.org/debian stretch-proposed-updates/main Translation-en 2020-07-07-0200.57.pdiff [2799 B]
Get:41 http://ftp.debian.org/debian stretch-proposed-updates/contrib arm64 Packages [492 B]
Get:42 http://ftp.debian.org/debian stretch-proposed-updates/contrib Translation-en [256 B]
Get:44 https://oph.mdrjr.net/meveric all/c2 arm64 Packages [6906 B]
Get:45 https://deb.nodesource.com/node_12.x stretch/main arm64 Packages [762 B]
Ign:2 https://repo.jeedom.com/odroid stable InRelease
Get:46 https://repo.jeedom.com/odroid stable Release [932 B]
Get:47 https://repo.jeedom.com/odroid stable Release.gpg [659 B]
Fetched 1566 kB in 15s (99.7 kB/s)
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.3).
python-dev is already the newest version (2.7.13-2).
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 172 not upgraded.
-- Installed version of Python :
Python 3.5.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (9.0.1-2+deb9u1).
python3-dev is already the newest version (3.5.3-1).
python-requests is already the newest version (2.12.4-1).
-- Installation of audio sox library
sox is already the newest version (14.4.1-5+deb9u2).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-5).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:3.2.14-1~deb9u1).
-- Upgrade setuptools with command pip3.7 if not up to date
WARNING: You are using pip version 19.2.3, however version 20.1.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.7/site-packages (47.3.1)
-- Installed version of pip :
pip 19.2.3 from /usr/local/lib/python3.7/site-packages/pip (python 3.7)
-- Installation of python library 'requests' with command pip3.7
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.7/site-packages (2.24.0)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.7/site-packages (from requests>=2.21.0) (2.9)
Requirement already satisfied: chardet<4,>=3.0.2 in /usr/local/lib/python3.7/site-packages (from requests>=2.21.0) (3.0.4)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/site-packages (from requests>=2.21.0) (2020.6.20)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.7/site-packages (from requests>=2.21.0) (1.25.9)
-- Installation of python library 'protobuf' with command pip3.7
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/site-packages (3.12.2)
Requirement already satisfied: six>=1.9 in /usr/local/lib/python3.7/site-packages (from protobuf>=3.11.0) (1.15.0)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/site-packages (from protobuf>=3.11.0) (47.3.1)
-- Installation of python library 'zeroconf' with command pip3.7
Requirement already satisfied: zeroconf>=0.25.1 in /usr/local/lib/python3.7/site-packages (0.27.1)
Requirement already satisfied: ifaddr in /usr/local/lib/python3.7/site-packages (from zeroconf>=0.25.1) (0.1.7)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.7
Requirement already satisfied: click in /usr/local/lib/python3.7/site-packages (7.1.2)
Requirement already satisfied: bs4 in /usr/local/lib/python3.7/site-packages (0.0.1)
Requirement already satisfied: six in /usr/local/lib/python3.7/site-packages (1.15.0)
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.7/site-packages (from bs4) (4.9.1)
Requirement already satisfied: soupsieve>1.2 in /usr/local/lib/python3.7/site-packages (from beautifulsoup4->bs4) (2.0.1)
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3.7
Requirement already satisfied: tqdm in /usr/local/lib/python3.7/site-packages (4.46.1)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/site-packages (0.57.0)
Requirement already satisfied: casttube in /usr/local/lib/python3.7/site-packages (0.2.1)
Requirement already satisfied: six in /usr/local/lib/python3.7/site-packages (from websocket-client) (1.15.0)
Requirement already satisfied: requests in /usr/local/lib/python3.7/site-packages (from casttube) (2.24.0)
Requirement already satisfied: idna<3,>=2.5 in /usr/local/lib/python3.7/site-packages (from requests->casttube) (2.9)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /usr/local/lib/python3.7/site-packages (from requests->casttube) (1.25.9)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/site-packages (from requests->casttube) (2020.6.20)
Requirement already satisfied: chardet<4,>=3.0.2 in /usr/local/lib/python3.7/site-packages (from requests->casttube) (3.0.4)
-- Installation of dependencies is done !
J’ai relancé l’installation des dépendances
ERROR:root:ERROR: One or several pychromecast controllers are not loaded !
File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 54, in <module>
import pychromecast.pychromecast.controllers.youtube as youtube
File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/controllers/youtube.py", line 6, in <module>
from casttube import YouTubeSession
ImportError: No module named 'casttube'
Mon Jeedom est aphone, help please
