Mes scénarios qui lance la commande Extinction du poêle ne fonctionne pas.
Par contre lorsque je lance l’action manuellement, ça fonctionne.
Voici les logs :
2026-10-27 08:33:09]WARNING Commande [Chauffage][Poele Lola][Extinction poêle] refusée : options non reconnues
0094|[2026-10-27 08:33:09] DEBUG execute resultat ERROR
0095|[2026-10-27 08:33:11] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET CNTR","TS":1793086391},"SUCCESS":true,"DATA":{"IGNERRORS":0,"POWERTIME":"42513:20","SERVICETIME":"546:18","PQT":2677,"OVERTMPERRORS":0,"HEATTIME":"3863:48","ONTIME":"00:00","IGN":1324}}
0096|[2026-10-27 08:33:11] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+ALLS
0097|[2026-10-27 08:33:11] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET ALLS","TS":1793086391},"SUCCESS":true,"DATA":{"T2":25.9,"F2LF":2,"PQT":2677,"PWR":3,"T4":0,"FANLMINMAX":[0,5,0,1,0,1],"FDR":0,"F2V":0,"MOD":301,"DPT":0,"APLWDAY":2,"MAC":"78:25:44:7F:18:DB","SETP":19,"APLTS":"2026-10-27 08:45:01","STATUS":9,"T3":25,"T1":21.1,"PUMP":0,"T5":0,"F1RPM":0,"OUT":0,"F1V":0,"SN":"LT201233280570923048546","LSTATUS":51,"EFLAGS":4,"F2L":7,"CORE":119,"DP":-5,"CHRSTATUS":0,"IN":5,"FWDATE":"2019-05-10","VER":44,"MBTYPE":0}}
0098|[2026-10-27 08:33:12] DEBUG Fin : getInformations
0099|[2026-10-27 08:33:12] DEBUG pull : fin
0100|[2026-10-27 08:34:04] DEBUG pull : Démarrage du cron
0101|[2026-10-27 08:34:04] DEBUG Début : getInformations
0102|[2026-10-27 08:34:04] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+TIME
0103|[2026-10-27 08:34:05] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET TIME","TS":1793086445},"SUCCESS":true,"DATA":{"STOVE_WDAY":2,"STOVE_DATETIME":"2026-10-27 08:46:00"}}
0104|[2026-10-27 08:34:05] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+STDT
0105|[2026-10-27 08:34:07] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET STDT","TS":1793086447},"SUCCESS":true,"DATA":{"GWDEVICE":"eth0.1","GATEWAY":"192.168.1.254","PSENSLTSH":0,"WMAC":"3E:CE:30:18:8D:71","plzbridge":"2.2.1 2021-10-08 09:30:45","HWTYPE":6,"NOMINALPWR":9,"AUTONOMYTYPE":2,"WMODE":"ap","STOVETYPE":1,"CHRONOTYPE":5,"SPLMIN":6,"DSPFWVER":0,"MOD":301,"FAN2MODE":3,"EGW":"192.168.1.254","MAC":"78:25:44:7F:18:DB","FAN2TYPE":2,"SPLMAX":51,"ECBL":"up","FLUID":0,"WADR":"192.168.10.1","CLOUD_ENABLED":true,"EPR":"static","PELLETTYPE":3,"PSENSLMIN":0,"SNCHK":1,"PSENSLMAX":0,"PSENSTYPE":0,"CONFIG":1,"LABEL":"Poele Lola","EMSK":"255.255.255.0","BLEMBMODE":1,"WGW":"","UICONFIG":1,"BLEDSPMODE":1,"MAINTPROBE":0,"ICONN":1,"EBCST":"192.168.1.255","FWDATE":"2019-05-10","WSSID":"connboxCA556","WPR":"static","VER":44,"WPWR":"","MBTYPE":0,"WENC":"psk2","CBTYPE":"miniembwifi","EADR":"192.168.1.36","sendmsg":"2.1.2 2018-03-28 10:19:09","WMSK":"255.255.255.0","EMAC":"78:25:44:7F:18:DB","CORE":119,"SN":"LT201233280570923048546","APLCONN":1,"DNS":["127.0.0.1"],"SYSTEM":"2.5.3 2021-10-08 10:30:20 (657c8cf)","WBCST":"192.168.10.255","WCH":"11"}}
0106|[2026-10-27 08:34:07] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+CHRD
0107|[2026-10-27 08:34:09] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET CHRD","TS":1793086449},"SUCCESS":true,"DATA":{"D2":{"M3":"P3","M2":"P2","M1":"P1"},"D3":{"M3":"P3","M2":"P2","M1":"P1"},"D1":{"M3":"P3","M2":"P2","M1":"P1"},"D7":{"M3":"P3","M2":"P2","M1":"P1"},"D6":{"M3":"P3","M2":"P2","M1":"P1"},"D5":{"M3":"P3","M2":"P2","M1":"P1"},"CHRSTATUS":1,"P6":{"CHRSETP":23,"START":"21:30","STOP":"22:30"},"P5":{"CHRSETP":22,"START":"17:00","STOP":"21:00"},"P4":{"CHRSETP":21,"START":"14:30","STOP":"16:30"},"P2":{"CHRSETP":21,"START":"18:00","STOP":"21:00"},"P3":{"CHRSETP":19,"START":"21:00","STOP":"06:00"},"D4":{"M3":"P3","M2":"P2","M1":"P1"},"P1":{"CHRSETP":20,"START":"06:00","STOP":"18:00"}}}
0108|[2026-10-27 08:34:09] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+CNTR
0109|[2026-10-27 08:34:10] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET CNTR","TS":1793086450},"SUCCESS":true,"DATA":{"IGNERRORS":0,"POWERTIME":"42513:21","SERVICETIME":"546:18","PQT":2677,"OVERTMPERRORS":0,"HEATTIME":"3863:48","ONTIME":"00:00","IGN":1324}}
0110|[2026-10-27 08:34:10] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+ALLS
0111|[2026-10-27 08:34:12] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET ALLS","TS":1793086452},"SUCCESS":true,"DATA":{"T2":25.9,"F2LF":2,"PQT":2677,"PWR":3,"T4":0,"FANLMINMAX":[0,5,0,1,0,1],"FDR":0,"F2V":0,"MOD":301,"DPT":0,"APLWDAY":2,"MAC":"78:25:44:7F:18:DB","SETP":19,"APLTS":"2026-10-27 08:46:06","STATUS":9,"T3":24,"T1":21.1,"PUMP":0,"T5":0,"F1RPM":0,"OUT":0,"F1V":0,"SN":"LT201233280570923048546","LSTATUS":51,"EFLAGS":4,"F2L":7,"CORE":119,"DP":-5,"CHRSTATUS":0,"IN":5,"FWDATE":"2019-05-10","VER":44,"MBTYPE":0}}
0112|[2026-10-27 08:34:12] DEBUG Fin : getInformations
0113|[2026-10-27 08:34:12] DEBUG pull : fin
0114|[2026-10-27 08:35:06] DEBUG pull : Démarrage du cron
0115|[2026-10-27 08:35:06] DEBUG Début : getInformations
0116|[2026-10-27 08:35:06] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+TIME
0117|[2026-10-27 08:35:06] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET TIME","TS":1793086506},"SUCCESS":true,"DATA":{"STOVE_WDAY":2,"STOVE_DATETIME":"2026-10-27 08:47:01"}}
0118|[2026-10-27 08:35:06] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+STDT
0119|[2026-10-27 08:35:08] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET STDT","TS":1793086508},"SUCCESS":true,"DATA":{"GWDEVICE":"eth0.1","GATEWAY":"192.168.1.254","PSENSLTSH":0,"WMAC":"3E:CE:30:18:8D:71","plzbridge":"2.2.1 2021-10-08 09:30:45","HWTYPE":6,"NOMINALPWR":9,"AUTONOMYTYPE":2,"WMODE":"ap","STOVETYPE":1,"CHRONOTYPE":5,"SPLMIN":6,"DSPFWVER":0,"MOD":301,"FAN2MODE":3,"EGW":"192.168.1.254","MAC":"78:25:44:7F:18:DB","FAN2TYPE":2,"SPLMAX":51,"ECBL":"up","FLUID":0,"WADR":"192.168.10.1","CLOUD_ENABLED":true,"EPR":"static","PELLETTYPE":3,"PSENSLMIN":0,"SNCHK":1,"PSENSLMAX":0,"PSENSTYPE":0,"CONFIG":1,"LABEL":"Poele Lola","EMSK":"255.255.255.0","BLEMBMODE":1,"WGW":"","UICONFIG":1,"BLEDSPMODE":1,"MAINTPROBE":0,"ICONN":1,"EBCST":"192.168.1.255","FWDATE":"2019-05-10","WSSID":"connboxCA556","WPR":"static","VER":44,"WPWR":"","MBTYPE":0,"WENC":"psk2","CBTYPE":"miniembwifi","EADR":"192.168.1.36","sendmsg":"2.1.2 2018-03-28 10:19:09","WMSK":"255.255.255.0","EMAC":"78:25:44:7F:18:DB","CORE":119,"SN":"LT201233280570923048546","APLCONN":1,"DNS":["127.0.0.1"],"SYSTEM":"2.5.3 2021-10-08 10:30:20 (657c8cf)","WBCST":"192.168.10.255","WCH":"11"}}
0120|[2026-10-27 08:35:08] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+CHRD
0121|[2026-10-27 08:35:09] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET CHRD","TS":1793086509},"SUCCESS":true,"DATA":{"D2":{"M3":"P3","M2":"P2","M1":"P1"},"D3":{"M3":"P3","M2":"P2","M1":"P1"},"D1":{"M3":"P3","M2":"P2","M1":"P1"},"D7":{"M3":"P3","M2":"P2","M1":"P1"},"D6":{"M3":"P3","M2":"P2","M1":"P1"},"D5":{"M3":"P3","M2":"P2","M1":"P1"},"CHRSTATUS":1,"P6":{"CHRSETP":23,"START":"21:30","STOP":"22:30"},"P5":{"CHRSETP":22,"START":"17:00","STOP":"21:00"},"P4":{"CHRSETP":21,"START":"14:30","STOP":"16:30"},"P2":{"CHRSETP":21,"START":"18:00","STOP":"21:00"},"P3":{"CHRSETP":19,"START":"21:00","STOP":"06:00"},"D4":{"M3":"P3","M2":"P2","M1":"P1"},"P1":{"CHRSETP":20,"START":"06:00","STOP":"18:00"}}}
0122|[2026-10-27 08:35:09] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+CNTR
0123|[2026-10-27 08:35:10] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET CNTR","TS":1793086510},"SUCCESS":true,"DATA":{"IGNERRORS":0,"POWERTIME":"42513:22","SERVICETIME":"546:18","PQT":2677,"OVERTMPERRORS":0,"HEATTIME":"3863:48","ONTIME":"00:00","IGN":1324}}
0124|[2026-10-27 08:35:10] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=GET+ALLS
0125|[2026-10-27 08:35:13] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"GET ALLS","TS":1793086513},"SUCCESS":true,"DATA":{"T2":25.8,"F2LF":2,"PQT":2677,"PWR":3,"T4":0,"FANLMINMAX":[0,5,0,1,0,1],"FDR":0,"F2V":0,"MOD":301,"DPT":0,"APLWDAY":2,"MAC":"78:25:44:7F:18:DB","SETP":19,"APLTS":"2026-10-27 08:47:06","STATUS":9,"T3":24,"T1":21.1,"PUMP":0,"T5":0,"F1RPM":0,"OUT":0,"F1V":0,"SN":"LT201233280570923048546","LSTATUS":51,"EFLAGS":4,"F2L":7,"CORE":119,"DP":-5,"CHRSTATUS":0,"IN":5,"FWDATE":"2019-05-10","VER":44,"MBTYPE":0}}
0126|[2026-10-27 08:35:13] DEBUG Fin : getInformations
0127|[2026-10-27 08:35:13] DEBUG pull : fin
0128|[2026-10-27 08:35:14] DEBUG execute options ""
0129|[2026-10-27 08:35:14] DEBUG execute $options {"user_login":"Alex43_b","user_id":"2"}
0130|[2026-10-27 08:35:14] DEBUG sendCommand - commande CMD+OFF
0131|[2026-10-27 08:35:14] DEBUG makeRequest - get URL http://192.168.1.36/cgi-bin/sendmsg.lua?cmd=CMD+OFF
0132|[2026-10-27 08:35:14] DEBUG makeRequest - résultat : {"INFO":{"RSP":"OK","CMD":"CMD OFF","TS":1793086514},"SUCCESS":true,"DATA":{"STATUS":9,"LSTATUS":51}}
0133|[2026-10-27 08:35:14] DEBUG execute resultat OK
Informations Jeedom Delta
Core : 4.6.2 (master)
DNS Jeedom Delta : non
Plugin : Palazzetti
Version : 2026-10-24 01:29:06 (beta)
Santé
🟢 Matériel : diy
🟢 Système à jour : OK
🟢 Cron actif : OK
🟢 Scénario actif : OK
🟢 Démarré : OK 2026-10-24 10:26:03
🟢 Date système (dernière heure enregistrée) : OK 2026-10-27 08:37:34 (2026-10-27 08:14:02)
🟢 Droits sudo : OK
🟢 Version Jeedom : 4.6.2
🟢 Version OS : debian 12.15
🟢 Version PHP : 8.2.35
🟢 Nombre de processus Apache : 16
🟢 Version OS : Linux jeedom12 6.1.0-54-arm64 #1 SMP Debian 6.1.190-1 (2026-10-16) aarch64 GNU/Linux [12.15]
🟢 Version database : 10.11.19-MariaDB-0+deb12u1
🟢 Espace disque libre : 84 %
🟢 Connexion active/max/autorisée : 13/48/151
🟢 Taille base de données : 77.1 MB
🟢 Espace disque libre tmp : 94 %
🟢 Mémoire disponible : 74 % (Total 4928 Mo)
🟢 Mémoire suffisante : 0
🟢 Erreur I/O : 0
🟠 Swap disponible : Inconnue
🟢 Swappiness : 10 %
🟢 Charge : 1.6 - 1.79 - 1.71
🟢 Node : v22.23.4
🟢 Python 3 : Python 3.11.2
🟢 Persistance du cache : OK
🟢 Apache private tmp : OK
