Bonjour a tous,
Après plusieurs recherches et essai qui n’ont pas fonctionné, je vous fait part de mon problème en esperant que vous pourriez me venir en aide.
Après avoir chaque tentative de téléchargement des dépendance du plugin Kroomba le statut reste en NOK.
je vous mets les logs de l’instal.
Pour info mon robot apsi et un irobot roomba i7
* Installation des dépendances *
Version de Python 3 installée :
Python 3.9.2
Hit:1 http://ftp.fr.debian.org/debian bullseye InRelease
Hit:2 http://ftp.fr.debian.org/debian bullseye-updates InRelease
Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
Reading package lists...
Building dependency tree...
Reading state information...
python3-pip is already the newest version (20.3.4-4+deb11u1).
The following packages were automatically installed and are no longer required:
ethtool libmspack0 libxmlsec1 libxmlsec1-openssl zerofree
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
python3-setuptools is already the newest version (52.0.0-4).
WARNING: No metadata found in /usr/local/lib/python3.9/dist-packages
Found existing installation: six 1.16.0
ERROR: Cannot uninstall six 1.16.0, RECORD file not found. You might be able to recover from this via: 'pip install --force-reinstall --no-deps six==1.16.0'.
Found existing installation: paho-mqtt 1.6.1
Uninstalling paho-mqtt-1.6.1:
Successfully uninstalled paho-mqtt-1.6.1
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: setuptools in /usr/local/lib/python3.9/dist-packages (62.6.0)
WARNING: Error parsing requirements for six: [Errno 2] No such file or directory: '/usr/local/lib/python3.9/dist-packages/six-1.16.0.dist-info/METADATA'
Requirement already satisfied: six in /usr/local/lib/python3.9/dist-packages (1.16.0)
ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: '/usr/local/lib/python3.9/dist-packages/six-1.16.0.dist-info/METADATA'
Collecting paho-mqtt
Using cached paho_mqtt-1.6.1-py3-none-any.whl
Installing collected packages: paho-mqtt
Successfully installed paho-mqtt-1.6.1
sudo: git: command not found
mv: cannot stat 'Roomba980-Python/roomba': No such file or directory
chown: cannot access 'roomba': No such file or directory
chmod: cannot access 'roomba': No such file or directory
* Installation terminée *
