Bonjour, depuis aujourd’hui, mon KLF200 ne cesse de redémarrer dès que je lance une action (ouvrir ou fermer) pour n’importe quel volet.
Voici les logs :
* Installation des dépendances *
Get:1 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:2 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
Err:4 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.178.69.128 443]
Hit:5 https://oph.mdrjr.net/meveric all InRelease
Hit:6 https://oph.mdrjr.net/meveric buster InRelease
Hit:7 http://www.deb-multimedia.org buster InRelease
Reading package lists...
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
Installation des dépendances apt
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 154 not upgraded.
Installation du module pyvlx pour python
Requirement already up-to-date: pyvlx in /usr/local/lib/python3.7/dist-packages (0.2.19)
Requirement already satisfied, skipping upgrade: PyYAML in /usr/local/lib/python3.7/dist-packages (from pyvlx) (5.4.1)
Installation du module aiohttp pour python
Requirement already up-to-date: aiohttp in /usr/local/lib/python3.7/dist-packages (3.8.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (20.3.0)
Requirement already satisfied, skipping upgrade: charset-normalizer<3.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (2.0.7)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (5.1.0)
Requirement already satisfied, skipping upgrade: async_timeout<5.0,>=4.0.0a3 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (4.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.6.3)
Requirement already satisfied, skipping upgrade: frozenlist>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.2.0)
Requirement already satisfied, skipping upgrade: aiosignal>=1.1.2 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (1.2.0)
Requirement already satisfied, skipping upgrade: asynctest==0.13.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (0.13.0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.4 in /usr/local/lib/python3.7/dist-packages (from aiohttp) (3.7.4.3)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp) (3.1)
Installation du module bottle pour python
Requirement already up-to-date: bottle in /usr/local/lib/python3.7/dist-packages (0.12.19)
* Installation terminée *
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.1.69', 51200)
[2021-11-16 20:38:44][ERROR] : KLF200 has been restarted after found not responding
======== Running on http://0.0.0.0:9123 ========
(Press CTRL+C to quit)
Task was destroyed but it is pending!
task: <Task pending coro=<Heartbeat.loop() running at /usr/local/lib/python3.7/dist-packages/pyvlx/heartbeat.py:42> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0x7f9060f318>()]>>
[2021-11-16 20:40:23][ERROR] : KLF200 has been restarted after found not responding
[2021-11-16 20:40:24][ERROR] : KLF200 has been restarted after found not responding
File "/var/www/html/plugins/klf200/resources/klf200d.py", line 269, in <module>
LOOP.run_until_complete(init_pyvlx_connection(LOOP))
File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_complete
return future.result()
File "/var/www/html/plugins/klf200/resources/klf200d.py", line 22, in init_pyvlx_connection
await pyvlx.load_nodes()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/pyvlx.py", line 76, in load_nodes
await self.nodes.load(node_id)
File "/usr/local/lib/python3.7/dist-packages/pyvlx/nodes.py", line 69, in load
await self._load_all_nodes()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/nodes.py", line 85, in _load_all_nodes
await get_all_nodes_information.do_api_call()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/api/api_event.py", line 21, in do_api_call
await self.send_frame()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/api/api_event.py", line 33, in send_frame
await self.pyvlx.send_frame(self.request_frame())
File "/usr/local/lib/python3.7/dist-packages/pyvlx/pyvlx.py", line 66, in send_frame
await self.connect()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/pyvlx.py", line 43, in connect
await self.connection.connect()
File "/usr/local/lib/python3.7/dist-packages/pyvlx/connection.py", line 91, in connect
ssl=self.create_ssl_context(),
File "/usr/lib/python3.7/asyncio/base_events.py", line 959, in create_connection
raise exceptions[0]
File "/usr/lib/python3.7/asyncio/base_events.py", line 946, in create_connection
await self.sock_connect(sock, address)
File "/usr/lib/python3.7/asyncio/selector_events.py", line 464, in sock_connect
return await fut
File "/usr/lib/python3.7/asyncio/selector_events.py", line 494, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.1.69', 51200)
[2021-11-16 20:40:43][ERROR] : KLF200 has been restarted after found not responding
[2021-11-16 20:40:45][ERROR] : KLF200 has been restarted after found not responding
[2021-11-16 20:40:46][ERROR] : KLF200 has been restarted after found not responding
[2021-11-16 20:41:43][ERROR] : KLF200 has been restarted after found not responding
Merci de votre aide
