Je rencontre un problème avec Jmqtt.
J’ai des interruption de service par intermittance.
J’ai reinstallé les dependances (un topic en parlait), toujours pareil.
J’ai reinstallé mon mosquitto sur une vm toute propre, idem.
Voici les logs jmqttd que j’ai put chopé au moment ou ça tombe:
0466|[2023-05-15 22:57:18,501][INFO] Client1107 Brk1107Th on_message() : Message received (topic="zigbee/piscine_pompe", payload="{"child_lock":"UNLOCK","current":0,"energy":33.02,"indicator_mode":"off/on","linkquality":21,"power":0,"state":"OFF","voltage":228}", QoS=0, retain=False)
0467|[2023-05-15 22:57:18,501][DEBUG] JMsg.Snd Brk1107Th send_async() : Enqued the message in 0.001907ms (qToJ size 1): {'cmd': 'messageIn', 'id': '1107', 'topic': 'zigbee/piscine_pompe', 'payload': '{"child_lock":"UNLOCK","current":0,"energy":33.02,"indicator_mode":"off/on","linkquality":21,"power":0,"state":"OFF","voltage":228}', 'qos': 0, 'retain': False}
0468|[2023-05-15 22:57:18,555][DEBUG] JMsg.Snd SockOut _loopSnd() : Sending 1 messages (0 left in queue)
0469|[2023-05-15 22:57:18,568][DEBUG] JMsg.Snd SockOut send() : Sent TO Jeedom 1 messages handled in 12.687445ms (qToJ size 0): [{'cmd': 'messageIn', 'id': '1107', 'topic': 'zigbee/piscine_pompe', 'payload': '{"child_lock":"UNLOCK","current":0,"energy":33.02,"indicator_mode":"off/on","linkquality":21,"power":0,"state":"OFF","voltage":228}', 'qos': 0, 'retain': False}]
0470|[2023-05-15 22:57:24,378][ERROR] JMsg.Rcv MainThread is_working() : Nothing has been received for 135s (max 135s), Jeedom does not want me any longer.
0471|[2023-05-15 22:57:24,479][INFO] Main MainThread shutdown() : Stop jMQTT python daemon
0472|[2023-05-15 22:57:24,479][DEBUG] JMsg.Rcv MainThread receiver_stop() : Stop requested
0473|[2023-05-15 22:57:24,547][INFO] JMsg.Rcv SockIn _loopRcv() : Stopped
0474|[2023-05-15 22:57:24,547][DEBUG] JMsg.Rcv MainThread receiver_stop() : Stopped
0475|[2023-05-15 22:57:24,547][DEBUG] JMsg.Snd Brk1201Th send_async() : Enqued the message in 0.003338ms (qToJ size 1): {'cmd': 'brokerDown', 'id': '1201'}
0476|[2023-05-15 22:57:24,548][INFO] Client1201 Brk1201Th on_disconnect() : Disconnected from broker.
0477|[2023-05-15 22:57:24,548][DEBUG] Client1201 MainThread stop() : jMqttClient ended
0478|[2023-05-15 22:57:24,548][DEBUG] Client571 MainThread stop() : jMqttClient ended
0479|[2023-05-15 22:57:24,548][DEBUG] JMsg.Snd Brk1095Th send_async() : Enqued the message in 0.002146ms (qToJ size 2): {'cmd': 'brokerDown', 'id': '1095'}
0480|[2023-05-15 22:57:24,548][INFO] Client1095 Brk1095Th on_disconnect() : Disconnected from broker.
0481|[2023-05-15 22:57:24,549][DEBUG] Client1095 MainThread stop() : jMqttClient ended
0482|[2023-05-15 22:57:24,549][DEBUG] JMsg.Snd Brk1082Th send_async() : Enqued the message in 0.002146ms (qToJ size 3): {'cmd': 'brokerDown', 'id': '1082'}
0483|[2023-05-15 22:57:24,549][INFO] Client1082 Brk1082Th on_disconnect() : Disconnected from broker.
0484|[2023-05-15 22:57:24,550][DEBUG] Client1082 MainThread stop() : jMqttClient ended
0485|[2023-05-15 22:57:24,550][DEBUG] JMsg.Snd Brk1107Th send_async() : Enqued the message in 0.002861ms (qToJ size 4): {'cmd': 'brokerDown', 'id': '1107'}
0486|[2023-05-15 22:57:24,550][INFO] Client1107 Brk1107Th on_disconnect() : Disconnected from broker.
0487|[2023-05-15 22:57:24,551][DEBUG] Client1107 MainThread stop() : jMqttClient ended
0488|[2023-05-15 22:57:24,551][DEBUG] JMsg.Snd Brk1322Th send_async() : Enqued the message in 0.001669ms (qToJ size 5): {'cmd': 'brokerDown', 'id': '1322'}
0489|[2023-05-15 22:57:24,551][INFO] Client1322 Brk1322Th on_disconnect() : Disconnected from broker.
0490|[2023-05-15 22:57:24,552][DEBUG] Client1322 MainThread stop() : jMqttClient ended
0491|[2023-05-15 22:57:24,552][DEBUG] JMsg.Snd Brk1542Th send_async() : Enqued the message in 0.002146ms (qToJ size 6): {'cmd': 'brokerDown', 'id': '1542'}
0492|[2023-05-15 22:57:24,552][INFO] Client1542 Brk1542Th on_disconnect() : Disconnected from broker.
0493|[2023-05-15 22:57:24,552][DEBUG] Client1542 MainThread stop() : jMqttClient ended
0494|[2023-05-15 22:57:24,553][DEBUG] Main MainThread shutdown() : Sent Daemon Down signal to Jeedom
0495|[2023-05-15 22:57:24,553][DEBUG] JMsg.Snd MainThread sender_stop() : Stop requested
0496|[2023-05-15 22:57:24,580][INFO] JMsg.Snd SockOut _loopSnd() : Stopped
0497|[2023-05-15 22:57:24,580][DEBUG] JMsg.Snd MainThread sender_stop() : Stopped
0498|[2023-05-15 22:57:24,797][DEBUG] JMsg.Snd MainThread send() : Sent TO Jeedom 1 messages handled in 217.529774ms (qToJ size 0): [{'cmd': 'daemonDown'}]
0499|[2023-05-15 22:57:24,798][DEBUG] root MainThread <module>() : Exit 0
et puis cela repart.
j’ai ça aussi dans les logs jmqttd, je ne sais pas si c’est normal.
0095|[2023-05-15 23:02:16,869][INFO] Client1322 Brk1322Th on_message() : Message received (topic="zwave/SalleAManger/Lampe_Ambience/lastActive", payload="{"time":1684184537520,"value":1684184537520}", QoS=1, retain=False)
0096|[2023-05-15 23:02:16,869][DEBUG] JMsg.Snd Brk1322Th send_async() : Enqued the message in 0.003338ms (qToJ size 1): {'cmd': 'messageIn', 'id': '1322', 'topic': 'zwave/SalleAManger/Lampe_Ambience/lastActive', 'payload': '{"time":1684184537520,"value":1684184537520}', 'qos': 1, 'retain': False}
0097|[2023-05-15 23:02:16,875][DEBUG] JMsg.Snd SockOut send() : Sent TO Jeedom 1 messages handled in 16.595125ms (qToJ size 1): [{'cmd': 'messageIn', 'id': '1322', 'topic': 'zwave/SalleAManger/Lampe_Ambience/50/0/value/66561', 'payload': '{"time":1684184537439,"value":246.03}', 'qos': 1, 'retain': False}]
0098|[2023-05-15 23:02:16,875][DEBUG] JMsg.Snd SockOut _loopSnd() : Sending 1 messages (0 left in queue)
0099|[2023-05-15 23:02:16,883][DEBUG] JMsg.Snd SockOut send() : Sent TO Jeedom 1 messages handled in 7.672787ms (qToJ size 0): [{'cmd': 'messageIn', 'id': '1322', 'topic': 'zwave/SalleAManger/Lampe_Ambience/lastActive', 'payload': '{"time":1684184537520,"value":1684184537520}', 'qos': 1, 'retain': False}]
0100|[2023-05-15 23:02:16,886][DEBUG] Main MainThread run() : Heartbeat received from Jeedom
0101|[2023-05-15 23:02:16,886][INFO] Main MainThread h_newClient() : Client already exists for Broker 571. Restarting it.
0102|[2023-05-15 23:02:16,886][DEBUG] Client571 MainThread stop() : jMqttClient ended
0103|[2023-05-15 23:02:16,887][ERROR] Client571 MainThread start() : jMqttClient.start() Exception
0104|Traceback (most recent call last):
0105|File "/var/www/html/plugins/jMQTT/resources/jmqttd/jMqttClient.py", line 235, in start
0106|self.mqttclient.connect(self.mqtthostname, self.mqttport, 30)
0107|File "/var/www/html/plugins/jMQTT/resources/jmqttd/venv/lib/python3.7/site-packages/paho/mqtt/client.py", line 914, in connect
0108|return self.reconnect()
0109|File "/var/www/html/plugins/jMQTT/resources/jmqttd/venv/lib/python3.7/site-packages/paho/mqtt/client.py", line 1044, in reconnect
0110|sock = self._create_socket_connection()
0111|File "/var/www/html/plugins/jMQTT/resources/jmqttd/venv/lib/python3.7/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
0112|return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
0113|File "/usr/lib/python3.7/socket.py", line 727, in create_connection
0114|raise err
0115|File "/usr/lib/python3.7/socket.py", line 716, in create_connection
0116|sock.connect(sa)
0117|ConnectionRefusedError: [Errno 111] Connection refused
0118|[2023-05-15 23:02:16,889][INFO] Client1322 Brk1322Th on_message() : Message received (topic="zwave/SalleAManger/Lampe_Ambience/50/0/value/66561", payload="{"time":1684184537539,"value":246.03}", QoS=1, retain=False)
0119|[2023-05-15 23:02:16,889][DEBUG] JMsg.Snd Brk1322Th send_async() : Enqued the message in 0.001907ms (qToJ size 1): {'cmd': 'messageIn', 'id': '1322', 'topic': 'zwave/SalleAManger/Lampe_Ambience/50/0/value/66561', 'payload': '{"time":1684184537539,"value":246.03}', 'qos': 1, 'retain': False}
si quelqu’un a une idée ?
pour info jmqtt_dep:
0000|======================================================================
0001|== 15/05/2023 09:16:24 == Dependencies installation for jMQTT
0002|======================================================================
0003|[ 0% ] : Checking parameters...
0004|== System: Linux jeedom-vm 4.19.0-23-amd64 #1 SMP Debian 4.19.269-1 (2022-12-20) x86_64 GNU/Linux
0005|== Jeedom version: 4.3.17
0006|== jMQTT version: 2023-04-15
0007|[ 9% ] : Checking parameters : [ OK ]
0008|[ 10% ] : Synchronize the package index...
0009|[ 19% ] : Synchronize the package index : [ OK ]
0010|[ 20% ] : Install Composer...
0011|[ 29% ] : Install Composer : [ OK ]
0012|[ 30% ] : Install JsonPath-PHP library...
0013|[ 39% ] : Install JsonPath-PHP library : [ OK ]
0014|[ 40% ] : Remove Composer...
0015|[ 49% ] : Remove Composer : [ OK ]
0016|[ 50% ] : Install python3 venv and pip debian packages...
0017|[ 59% ] : Install python3 venv and pip debian packages : [ OK ]
0018|[ 60% ] : Create a python3 Virtual Environment...
0019|[ 69% ] : Create a python3 Virtual Environment : [ OK ]
0020|[ 70% ] : Install required python3 libraries in venv...
0021|[ 99% ] : Install required python3 libraries in venv : [ OK ]
0022|[100% ] : Finished !
0023|======================================================================
0024|== OK == Installation Successful
0025|======================================================================
Jeedom version 4.3.17
