[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index 5bff3af..7e78c4c 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -36,6 +36,8 @@
 - Konfiguration hinzufügen *Thermokon 798808 - MCS Raumsensor Temperatur, relative Luftfeuchtigkeit, Helligkeit*
+- Konfiguration hinzufügen *Ewattch Squid Pro Rogowski*
 # 29.04.2024
 - Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index 78c1633..26dbd7e 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -36,6 +36,8 @@
 - Adding configuration *Thermokon 798808 - MCS Ambient sensor temperature, relative humidity, brightness*
+- Adding configuration *Ewattch Squid Pro Rogowski*
 # 04/29/2024
 - Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index 5793d9a..9c513b1 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -36,6 +36,8 @@
 - Agregar configuración *Thermokon 798808 - MCS Sensor ambiente temperatura, humedad relativa, luminosidad*
+- Agregar configuración *Ewattch Calamar Pro Rogowski*
 # 29/04/2024
 - Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index 582e327..4f98c8d 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -25,6 +25,7 @@
         "Quandify Cubic Meter": "Kubikmeter quantifizieren",
         "Ajout des commandes de downlinks": "Downlinks-Befehle hinzugefügt",
         "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Raumsensor Temperatur, relative Luftfeuchtigkeit, Helligkeit",
+        "Ewattch Squid Pro Rogowski": "Ewattch Squid Pro Rogowski",
         "29\/04\/2024": "29.04.2024",
         "Dragino D23LBLS": "Dragino D23LBLS",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index 730d8d9..581475a 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -25,6 +25,7 @@
         "Quandify Cubic Meter": "Quantify Cubic Meter",
         "Ajout des commandes de downlinks": "Added downlinks commands",
         "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Ambient sensor temperature, relative humidity, brightness",
         "29\/04\/2024": "04\/29\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index 1e19411..22f305c 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -25,6 +25,7 @@
         "Quandify Cubic Meter": "Cuantificar Metro Cúbico",
         "Ajout des commandes de downlinks": "Comandos de enlaces descendentes agregados",
         "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Sensor ambiente temperatura, humedad relativa, luminosidad",
+        "Ewattch Squid Pro Rogowski": "Ewattch Calamar Pro Rogowski",
         "29\/04\/2024": "29\/04\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index 7960792..4d099c6 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -27,6 +27,7 @@
         "Quandify Cubic Meter": "Quandify Cubic Meter",
         "Ajout des commandes de downlinks": "Ajout des commandes de downlinks",
         "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index cb2f7b6..6d4998d 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -25,6 +25,7 @@
         "Quandify Cubic Meter": "Quantificar Metro Cúbico",
         "Ajout des commandes de downlinks": "Adicionados comandos de downlinks",
         "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Sensor ambiente de temperatura, umidade relativa, brilho",
+        "Ewattch Squid Pro Rogowski": "Ewattch Lula Pro Rogowski",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo",
diff --git a/docs/pt_PT/changelog.md b/docs/pt_PT/changelog.md
index a21cc0e..94159da 100644
--- a/docs/pt_PT/changelog.md
+++ b/docs/pt_PT/changelog.md
@@ -36,6 +36,8 @@
 - Adicionando configuração *Thermokon 798808 - MCS Sensor ambiente de temperatura, umidade relativa, brilho*
+- Adicionando configuração *Ewattch Lula Pro Rogowski*
 # 29/04/2024
 - Adicionando configuração *Dragino D23LBLS* (propriedades : Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo)
GitHub
sha: 827bebc6ebfa3dba8e9d1606ac367d382ad8a5b0
