[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index 2f6b59c..5bff3af 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -32,6 +32,10 @@
- Konfiguration hinzufügen *Enginko MCF - LW13 IO*
+- Downlinks-Befehle hinzugefügt *Kubikmeter quantifizieren*
+- Konfiguration hinzufügen *Thermokon 798808 - MCS Raumsensor Temperatur, relative Luftfeuchtigkeit, Helligkeit*
# 29.04.2024
- Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index ff630f3..78c1633 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -32,6 +32,10 @@
- Adding configuration *Enginko MCF - LW13 IO*
+- Added downlinks commands *Quantify Cubic Meter*
+- Adding configuration *Thermokon 798808 - MCS Ambient sensor temperature, relative humidity, brightness*
# 04/29/2024
- Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index b1c2164..5793d9a 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -32,6 +32,10 @@
- Agregar configuración *Enginko MCF - LW13 IO*
+- Comandos de enlaces descendentes agregados *Cuantificar Metro Cúbico*
+- Agregar configuración *Thermokon 798808 - MCS Sensor ambiente temperatura, humedad relativa, luminosidad*
# 29/04/2024
- Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index a019cbc..582e327 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -22,12 +22,14 @@
"SHE MIO LORA V2": "SIE MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "bis zu 20 Temperaturfühler hinzufügen",
"Enginko MCF - LW13 IO": "Enginko MCF - LW13 IO",
+ "Quandify Cubic Meter": "Kubikmeter quantifizieren",
+ "Ajout des commandes de downlinks": "Downlinks-Befehle hinzugefügt",
+ "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Raumsensor Temperatur, relative Luftfeuchtigkeit, Helligkeit",
"29\/04\/2024": "29.04.2024",
"Dragino D23LBLS": "Dragino D23LBLS",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
"Citylone SL32 et Citylone SL22": "Citylone SL32 und Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Spannung, Strom, Leistung, Cos Phi, Temperatur, LED-Spannung, Lampenniveau, Lampenmodus, Position anfordern, Breitengrad, Längengrad, Status der Zeitänderung anfordern, Zeitänderung aktivieren, Zeitänderung deaktivieren, RSSI, Zeitstempel, Aktualisierung über LNS, On Relay , Aus-Relais",
- "Quandify Cubic Meter": "Kubikmeter quantifizieren",
"Code Erreur, Volume Total, Etat de fuite, Etat de la batterie, Temp Minimum, Temp Maximum, Temp Ambiante": "Fehlercode, Gesamtvolumen, Leckstatus, Batteriestatus, Mindesttemperatur, Höchsttemperatur, Umgebungstemperatur",
"Eastron SDM630": "Eastron SDM630",
"Serial Number, Total Energy, Frequency, Total Power Factor, Maximum Total System Power Demand, Total Current": "Seriennummer, Gesamtenergie, Frequenz, Gesamtleistungsfaktor, Maximaler Gesamtstrombedarf des Systems, Gesamtstrom",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index 0f64503..730d8d9 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -22,12 +22,14 @@
"SHE MIO LORA V2": "SHE MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "add up to 20 temperature probes",
+ "Quandify Cubic Meter": "Quantify Cubic Meter",
+ "Ajout des commandes de downlinks": "Added downlinks commands",
+ "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Ambient sensor temperature, relative humidity, brightness",
"29\/04\/2024": "04\/29\/2024",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
"Citylone SL32 et Citylone SL22": "Citylone SL32 and Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relay , Off Relay",
- "Quandify Cubic Meter": "Quantify Cubic Meter",
"Code Erreur, Volume Total, Etat de fuite, Etat de la batterie, Temp Minimum, Temp Maximum, Temp Ambiante": "Error Code, Total Volume, Leak Status, Battery Status, Minimum Temp, Maximum Temp, Ambient Temp",
"Serial Number, Total Energy, Frequency, Total Power Factor, Maximum Total System Power Demand, Total Current": "Serial Number, Total Energy, Frequency, Total Power Factor, Maximum Total System Power Demand, Total Current",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index b312f56..1e19411 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -22,12 +22,14 @@
"SHE MIO LORA V2": "ELLA MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "añadir hasta 20 sondas de temperatura",
+ "Quandify Cubic Meter": "Cuantificar Metro Cúbico",
+ "Ajout des commandes de downlinks": "Comandos de enlaces descendentes agregados",
+ "Thermokon 798808 - MCS Capteur d'ambiance température, humidité relative, luminosité": "Thermokon 798808 - MCS Sensor ambiente temperatura, humedad relativa, luminosidad",
"29\/04\/2024": "29\/04\/2024",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
"Citylone SL32 et Citylone SL22": "Citylone SL32 y Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Voltaje, corriente, potencia, cos phi, temperatura, voltaje del LED, nivel de lámparas, modo de lámparas, posición de solicitud, latitud, longitud, estado de cambio de hora de solicitud, habilitar cambio de hora, deshabilitar cambio de hora, RSSI, marca de tiempo, actualización a través de LNS, en relé , Relé apagado",
- "Quandify Cubic Meter": "Cuantificar Metro Cúbico",
"Code Erreur, Volume Total, Etat de fuite, Etat de la batterie, Temp Minimum, Temp Maximum, Temp Ambiante": "Código de error, volumen total, estado de fuga, estado de la batería, temperatura mínima, temperatura máxima, temperatura ambiente",
[... diff too long, it was truncated ...]
GitHub
sha: 37733daaa0b5a8ec67e051e5cb0b5fdab57cbec7
