[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index 4d59f11..4c8b8b4 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -20,6 +20,10 @@
 - Konfiguration hinzufügen *Milesight EM300 DI*
+- Konfiguration hinzufügen *Mclimate Display CO2 Lite*
+- Konfiguration hinzufügen *Mclimate CO2-Anzeige*
 # 29.04.2024
 - Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index ce54472..ea8bde1 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -20,6 +20,10 @@
 - Adding configuration *Milesight EM300 DI*
+- Adding configuration *Mclimate Display CO2 lite*
+- Adding configuration *Mclimate Display CO2*
 # 04/29/2024
 - Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index 8c768f8..3e8be66 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -20,6 +20,10 @@
 - Agregar configuración *Milesight EM300 DI*
+- Agregar configuración *Mclimate Pantalla CO2 lite*
+- Agregar configuración *Pantalla climática CO2*
 # 29/04/2024
 - Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index f3f35cb..77cb254 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -15,6 +15,8 @@
         "MClimate Fan Coil Thermostat": "MClimate-Gebläsekonvektor-Thermostat",
         "WATTECO Testeur de réseau NETW'O": "WATTECO NETW'O Netzwerktester",
         "Milesight EM300 DI": "Milesight EM300 DI",
+        "Mclimate Display CO2 lite": "Mclimate Display CO2 Lite",
+        "Mclimate Display CO2": "Mclimate CO2-Anzeige",
         "29\/04\/2024": "29.04.2024",
         "Dragino D23LBLS": "Dragino D23LBLS",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index c85c7dc..3105fec 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -15,6 +15,8 @@
         "MClimate Fan Coil Thermostat": "MClimate Fan Coil Thermostat",
         "WATTECO Testeur de réseau NETW'O": "WATTECO NETW'O network tester",
+        "Mclimate Display CO2 lite": "Mclimate Display CO2 lite",
+        "Mclimate Display CO2": "Mclimate Display CO2",
         "29\/04\/2024": "04\/29\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index 03f79d8..b7ef989 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -15,6 +15,8 @@
         "MClimate Fan Coil Thermostat": "Termostato Fan Coil Mclimate",
         "WATTECO Testeur de réseau NETW'O": "Probador de red WATTECO NETW'O",
+        "Mclimate Display CO2 lite": "Mclimate Pantalla CO2 lite",
+        "Mclimate Display CO2": "Pantalla climática CO2",
         "29\/04\/2024": "29\/04\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index f1cfe71..df18e9b 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -17,6 +17,8 @@
         "WATTECO Testeur de réseau NETW'O": "WATTECO Testeur de réseau NETW'O",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index 9574348..f2b8f18 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -15,6 +15,8 @@
         "MClimate Fan Coil Thermostat": "Termostato de fan coil MClimate",
         "WATTECO Testeur de réseau NETW'O": "Testador de rede WATTECO NETW'O",
+        "Mclimate Display CO2 lite": "Exibição Mclimate CO2 Lite",
+        "Mclimate Display CO2": "Exibição Mclimate CO2",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo",
diff --git a/docs/pt_PT/changelog.md b/docs/pt_PT/changelog.md
index b569eae..bf4a611 100644
--- a/docs/pt_PT/changelog.md
+++ b/docs/pt_PT/changelog.md
@@ -20,6 +20,10 @@
 - Adicionando configuração *Milesight EM300 DI*
+- Adicionando configuração *Exibição Mclimate CO2 Lite*
+- Adicionando configuração *Exibição Mclimate CO2*
 # 29/04/2024
 - Adicionando configuração *Dragino D23LBLS* (propriedades : Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo)
GitHub
sha: 18d798a08d616e1509710bec4676d845f5fb581e
