[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index e09a187..2c1d89d 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -12,6 +12,8 @@
 - Konfiguration hinzufügen *Milesight WS303* (Eigenschaften : Batterie, Leckagestatus)
+- Ändern der Konfiguration *Vega SI-11 Rev2* (Eigenschaften : Kommunikationszeitraum, Eingabemodus)
 # 29.04.2024
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index 206a72a..e0de152 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -12,6 +12,8 @@
 - Adding configuration *Milesight WS303* (properties : Battery, Leakage Status)
+- Changing the configuration *Vega SI-11 Rev2* (properties : Communication period, Input Mode)
 # 04/29/2024
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index 0a624ac..8039863 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -12,6 +12,8 @@
 - Agregar configuración *Mira de millas WS303* (propiedades : Batería, estado de fuga)
+- Cambiando la configuración *Vega SI-11 Rev2* (propiedades : Periodo de comunicación, modo de entrada)
 # 29/04/2024
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index 2a044b9..8b8aa92 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -10,6 +10,8 @@
         "Milesight WS303": "Milesight WS303",
         "Ajout de la configuration": "Konfiguration hinzufügen",
         "Batterie, Leakage Status": "Batterie, Leckagestatus",
+        "Vega SI-11 Rev2": "Vega SI-11 Rev2",
+        "Communication period, Input Mode": "Kommunikationszeitraum, Eingabemodus",
         "29\/04\/2024": "29.04.2024",
         "Dragino D23LBLS": "Dragino D23LBLS",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index 89eebe3..fd5a5fa 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -10,6 +10,8 @@
         "Ajout de la configuration": "Adding configuration",
         "Batterie, Leakage Status": "Battery, Leakage Status",
+        "Communication period, Input Mode": "Communication period, Input Mode",
         "29\/04\/2024": "04\/29\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index 1c029a6..7ec3634 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -10,6 +10,8 @@
         "Milesight WS303": "Mira de millas WS303",
         "Ajout de la configuration": "Agregar configuración",
         "Batterie, Leakage Status": "Batería, estado de fuga",
+        "Communication period, Input Mode": "Periodo de comunicación, modo de entrada",
         "29\/04\/2024": "29\/04\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index 2837405..870acd4 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -12,6 +12,8 @@
         "Ajout de la configuration": "Ajout de la configuration",
         "Batterie, Leakage Status": "Batterie, Leakage Status",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index f2182e2..3970187 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -10,6 +10,8 @@
         "Milesight WS303": "Milhas WS303",
         "Ajout de la configuration": "Adicionando configuração",
         "Batterie, Leakage Status": "Bateria, status de vazamento",
+        "Communication period, Input Mode": "Período de comunicação, modo de entrada",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo",
diff --git a/docs/pt_PT/changelog.md b/docs/pt_PT/changelog.md
index cc9a104..221ac44 100644
--- a/docs/pt_PT/changelog.md
+++ b/docs/pt_PT/changelog.md
@@ -12,6 +12,8 @@
 - Adicionando configuração *Milhas WS303* (propriedades : Bateria, status de vazamento)
+- Alterando a configuração *Vega SI-11 Rev2* (propriedades : Período de comunicação, modo de entrada)
 # 29/04/2024
GitHub
sha: 4a8b6ed28f207f51dd20f063b89cdcd25734057e
