[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index bb1d07c..e09a187 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -10,6 +10,9 @@
- Ändern der Konfiguration *Drahtloser MClimate-Thermostat* (Eigenschaften : Manuelle Aktualisierung der Zieltemperatur)
+- Konfiguration hinzufügen *Milesight WS303* (Eigenschaften : Batterie, Leckagestatus)
# 29.04.2024
- Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index 4c64f74..206a72a 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -10,6 +10,9 @@
- Changing the configuration *MClimate Wireless Thermostat* (properties : Manual Target Temperature Update)
+- Adding configuration *Milesight WS303* (properties : Battery, Leakage Status)
# 04/29/2024
- Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index b0741b0..0a624ac 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -10,6 +10,9 @@
- Cambiando la configuración *Termostato inalámbrico MClimate* (propiedades : Actualización manual de la temperatura objetivo)
+- Agregar configuración *Mira de millas WS303* (propiedades : Batería, estado de fuga)
# 29/04/2024
- Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index 3948793..2a044b9 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -7,9 +7,11 @@
"Modification de la configuration": "Ändern der Konfiguration",
"propriétés": "Eigenschaften",
"Manual Target Temperature Update": "Manuelle Aktualisierung der Zieltemperatur",
+ "Milesight WS303": "Milesight WS303",
+ "Ajout de la configuration": "Konfiguration hinzufügen",
+ "Batterie, Leakage Status": "Batterie, Leckagestatus",
"29\/04\/2024": "29.04.2024",
"Dragino D23LBLS": "Dragino D23LBLS",
- "Ajout de la configuration": "Konfiguration hinzufügen",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
"Citylone SL32 et Citylone SL22": "Citylone SL32 und Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Spannung, Strom, Leistung, Cos Phi, Temperatur, LED-Spannung, Lampenniveau, Lampenmodus, Position anfordern, Breitengrad, Längengrad, Status der Zeitänderung anfordern, Zeitänderung aktivieren, Zeitänderung deaktivieren, RSSI, Zeitstempel, Aktualisierung über LNS, On Relay , Aus-Relais",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index 131ea3e..89eebe3 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -7,9 +7,11 @@
"Modification de la configuration": "Changing the configuration",
"propriétés": "properties",
"Manual Target Temperature Update": "Manual Target Temperature Update",
+ "Ajout de la configuration": "Adding configuration",
+ "Batterie, Leakage Status": "Battery, Leakage Status",
"29\/04\/2024": "04\/29\/2024",
- "Ajout de la configuration": "Adding configuration",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
"Citylone SL32 et Citylone SL22": "Citylone SL32 and Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relay , Off Relay",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index e257930..1c029a6 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -7,9 +7,11 @@
"Modification de la configuration": "Cambiando la configuración",
"propriétés": "propiedades",
"Manual Target Temperature Update": "Actualización manual de la temperatura objetivo",
+ "Milesight WS303": "Mira de millas WS303",
+ "Ajout de la configuration": "Agregar configuración",
+ "Batterie, Leakage Status": "Batería, estado de fuga",
"29\/04\/2024": "29\/04\/2024",
- "Ajout de la configuration": "Agregar configuración",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
"Citylone SL32 et Citylone SL22": "Citylone SL32 y Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Voltaje, corriente, potencia, cos phi, temperatura, voltaje del LED, nivel de lámparas, modo de lámparas, posición de solicitud, latitud, longitud, estado de cambio de hora de solicitud, habilitar cambio de hora, deshabilitar cambio de hora, RSSI, marca de tiempo, actualización a través de LNS, en relé , Relé apagado",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index d6f7886..2837405 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -9,9 +9,11 @@
"Modification de la configuration": "Modification de la configuration",
"propriétés": "propriétés",
+ "Ajout de la configuration": "Ajout de la configuration",
+ "Batterie, Leakage Status": "Batterie, Leakage Status",
- "Ajout de la configuration": "Ajout de la configuration",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
"Citylone SL32 et Citylone SL22": "Citylone SL32 et Citylone SL22",
"Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai": "Voltage, Current, Power, Cos Phi, Temperature, LED Voltage, Lamps level, Lamps mode, Request Position, Latitude, Longitude, Request Time Change State, Enable Time Change, Disable Time Change, RSSI, Timestamp, Update via LNS, On Relai, Off Relai",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index b1784d2..f2182e2 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -7,9 +7,11 @@
"Modification de la configuration": "Alterando a configuração",
"propriétés": "propriedades",
"Manual Target Temperature Update": "Atualização manual da temperatura alvo",
+ "Milesight WS303": "Milhas WS303",
+ "Ajout de la configuration": "Adicionando configuração",
+ "Batterie, Leakage Status": "Bateria, status de vazamento",
[... diff too long, it was truncated ...]
GitHub
sha: 5fee13c93cef0b9ec8d7418115a27744b7745602
