[Jenkins] Updated translation
diff --git a/core/i18n/de_DE.json b/core/i18n/de_DE.json
index 0feb17c..5c08cb7 100644
--- a/core/i18n/de_DE.json
+++ b/core/i18n/de_DE.json
@@ -1,18 +1,20 @@
"plugins\/lorapayload\/plugin_info\/configuration.php": {
- "401 - Accès non autorisé": "401 - Nicht autorisierter Zugriff"
+ "401 - Accès non autorisé": "401 - Nicht autorisierter Zugriff",
+ "Plugin MQTT à utiliser": "Zu verwendendes MQTT-Plugin"
"plugins\/lorapayload\/desktop\/php\/lorapayload.php": {
"Gestion": "Verwaltung",
"Configuration": "Aufbau",
- "Mes Equipements Lora (<?php echo $count; ?>)": "Meine Lora-Ausrüstung (<?php echo $count; ?> )",
+ "Génération automatique (BETA)": "Automatische Generierung (BETA)",
+ "Mes Equipements Lora (<?php echo sizeof(eqLogic::byType('lorapayload')); ?>)": "Meine Lora-Ausrüstung (<?php echo sizeof(eqLogic::byType('lorapayload')); ?> )",
"Rechercher": "Suche",
"Configuration avancée": "Erweiterte Konfiguration",
"Sauvegarder": "Speichern",
"Supprimer": "Entfernen",
"Equipement": "Ausrüstung",
- "Payload": "Nutzlast",
+ "LoRaWAN": "LoRaWAN",
"Commandes": "Aufträge",
"Nom de l'équipement": "Ausrüstungsname",
"Objet parent": "Übergeordnetes Objekt",
@@ -20,18 +22,30 @@
"Activer": "Aktivieren Sie",
"Visible": "Sichtbar",
"Catégorie": "Kategorie",
- "Commande d'envoi": "Befehl senden",
- "Avoir confirmation": "Bestätigung haben",
"Recréer les commandes": "Befehle neu erstellen",
- " . $info['groupe'] . ": "$ info ['group']",
+ "Commande de Payload": "Payload-Befehl",
"Format du payload": "Nutzdatenformat",
"Hexadécimal": "Hexadezimal",
"Base64": "Base64",
+ "Commande d'envoi": "Befehl senden",
+ "Avoir confirmation": "Bestätigung haben",
+ "Device EUI": "Geräte-EUI",
+ "Application Key": "Anwendungsschlüssel",
+ "Ajouter une commande info": "Bestellinformationen hinzufügen",
+ "Ajouter une commande action": "Fügen Sie einen Aktionsbefehl hinzu",
+ "ID": "AUSWEIS",
"Nom": "Nachname",
+ "Type": "Art",
"Logical ID (info)": "Logische ID (Info)",
"Paramètres": "Die Einstellungen",
"Etat": "Zustand",
- "Options": "Optionen"
+ "Options": "Optionen",
+ "Génération automatique": "Automatische Generierung",
+ "Objet": "Objekt",
+ "Modèle": "Modell",
+ "Dev EUI": "EUI-Entwickler",
+ "App Key": "App-Schlüssel",
+ "Application CS": "CS-App"
"plugins\/lorapayload\/desktop\/js\/lorapayload.js": {
"Nom de la commande": "Befehlsname",
@@ -51,7 +65,9 @@
"Annuler": "Abbrechen",
"Démarrer": "Start",
"Etes-vous sûr de vouloir récréer toutes les commandes ? Cela va supprimer les commandes existantes": "Möchten Sie wirklich alle Befehle neu erstellen? Dadurch werden die vorhandenen Bestellungen gelöscht",
- "Opération réalisée avec succès": "Operation erfolgreich abgeschlossen"
+ "Opération réalisée avec succès": "Operation erfolgreich abgeschlossen",
+ "Générer": "Generieren",
+ "Veuillez renseigner tous les champs pour initier la génération automatique": "Bitte füllen Sie alle Felder aus, um die automatische Generierung zu starten"
"plugins\/lorapayload\/core\/php\/jeeLorapayload.php": {
"Vous n\\'etes pas autorisé à effectuer cette action": "Sie sind nicht berechtigt, diese Aktion auszuführen"
@@ -66,7 +82,8 @@
"Périphérique reconnu, intégration en cours": "Gerät erkannt, Integration läuft",
"SET_EXT_TEMP_10(Lorapayload)": "SET_EXT_TEMP_10(Lorapayload)",
"Thermostat": "Thermostat",
- "SET_EXT_TEMP_01(Lorapayload)": "SET_EXT_TEMP_01(Lorapayload)"
+ "SET_EXT_TEMP_01(Lorapayload)": "SET_EXT_TEMP_01(Lorapayload)",
+ " . $info['groupe'] . ": ". $info['group'] ."
"info.json": {
"Plugin permetant le traduire les Payloads Lora, uniquement destiné au projet de l'équipe Jeedom": "Plugin, mit dem die Lora-Nutzdaten übersetzt werden können, nur für das Jeedom-Teamprojekt vorgesehen"
diff --git a/core/i18n/en_US.json b/core/i18n/en_US.json
index a7dbb1e..ad089cc 100644
--- a/core/i18n/en_US.json
+++ b/core/i18n/en_US.json
@@ -1,18 +1,20 @@
- "401 - Accès non autorisé": "401 - Unauthorized Access"
+ "401 - Accès non autorisé": "401 - Unauthorized Access",
+ "Plugin MQTT à utiliser": "MQTT plugin to use"
"Gestion": "Management",
"Configuration": "Configuration",
- "Mes Equipements Lora (<?php echo $count; ?>)": "My Lora Equipment (<?php echo $count; ?> )",
+ "Génération automatique (BETA)": "Automatic generation (BETA)",
+ "Mes Equipements Lora (<?php echo sizeof(eqLogic::byType('lorapayload')); ?>)": "My Lora Equipment (<?php echo sizeof(eqLogic::byType('lorapayload')); ?> )",
"Rechercher": "Search",
"Configuration avancée": "Advanced configuration",
"Sauvegarder": "Save",
"Supprimer": "Remove",
"Equipement": "Equipment",
- "Payload": "Payload",
"Commandes": "Orders",
"Nom de l'équipement": "Equipment name",
"Objet parent": "Parent object",
@@ -20,18 +22,30 @@
"Activer": "Activate",
"Visible": "Display",
"Catégorie": "Category",
- "Commande d'envoi": "Send command",
- "Avoir confirmation": "Have confirmation",
"Recréer les commandes": "Recreate commands",
+ "Commande de Payload": "Payload command",
"Format du payload": "Payload format",
"Hexadécimal": "Hexadecimal",
"Base64": "Base64",
+ "Commande d'envoi": "Send command",
+ "Avoir confirmation": "Have confirmation",
+ "Device EUI": "Device EUI",
+ "Application Key": "Application Key",
+ "Ajouter une commande info": "Add order info",
+ "Ajouter une commande action": "Add an action command",
+ "ID": "ID",
"Nom": "Last name",
+ "Type": "Kind",
"Logical ID (info)": "Logical ID (info)",
"Paramètres": "Settings",
"Etat": "State",
- "Options": "Options"
+ "Options": "Options",
+ "Génération automatique": "Automatic generation",
+ "Objet": "Object",
+ "Modèle": "Model",
+ "Dev EUI": "EUI Dev",
+ "App Key": "App Key",
+ "Application CS": "CS app"
"Nom de la commande": "Command name",
@@ -51,7 +65,9 @@
"Annuler": "To cancel",
"Etes-vous sûr de vouloir récréer toutes les commandes ? Cela va supprimer les commandes existantes": "Are you sure you want to recreate all the commands? This will delete the existing orders",
- "Opération réalisée avec succès": "Operation successfully completed"
+ "Opération réalisée avec succès": "Operation successfully completed",
+ "Générer": "Generate",
+ "Veuillez renseigner tous les champs pour initier la génération automatique": "Please fill in all fields to initiate automatic generation"
"Vous n\\'etes pas autorisé à effectuer cette action": "You are not authorized to perform this action"
@@ -66,7 +82,8 @@
[... diff too long, it was truncated ...]
GitHub
sha: eaa22a7513cbce43125bc76d18f56f5fc9f284e3
