Bonjour ,
Je viens d’installer jeedouino et tente de televerser sur un NodeMCU le sketch récupéré via le plugin Jeedouino mais il y a à chaque fois une erreur dans la compilation :
Arduino: 1.6.5 (Mac OS X), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Sketch + WiFi Settings, 115200"
In file included from /private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:29:0:
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.h:27:7: error: redefinition of 'class WiFiUDP'
class WiFiUDP : public UDP {
In file included from /private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/utility/wifi_drv.h:26:0,
from /private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:26:
/Users/PO/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/ESP8266WiFi/src/WiFiUdp.h:32:7: error: previous definition of 'class WiFiUDP'
class WiFiUDP : public UDP, public SList<WiFiUDP> {
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In constructor 'WiFiUDP::WiFiUDP()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:35:22: error: class 'WiFiUDP' does not have any field named '_sock'
WiFiUDP::WiFiUDP() : _sock(NO_SOCKET_AVAIL) {}
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual uint8_t WiFiUDP::begin(uint16_t)':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:45:9: error: '_sock' was not declared in this scope
_sock = sock;
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:46:9: error: '_port' was not declared in this scope
_port = port;
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual int WiFiUDP::available()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:56:7: error: '_sock' was not declared in this scope
if (_sock != NO_SOCKET_AVAIL)
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual void WiFiUDP::stop()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:66:8: error: '_sock' was not declared in this scope
if (_sock == NO_SOCKET_AVAIL)
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:69:26: error: '_sock' was not declared in this scope
ServerDrv::stopClient(_sock);
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual int WiFiUDP::beginPacket(IPAddress, uint16_t)':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:88:7: error: '_sock' was not declared in this scope
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:90:7: error: '_sock' was not declared in this scope
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual int WiFiUDP::endPacket()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:101:32: error: '_sock' was not declared in this scope
return ServerDrv::sendUdpData(_sock);
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual size_t WiFiUDP::write(const uint8_t*, size_t)':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:111:27: error: '_sock' was not declared in this scope
ServerDrv::insertDataBuf(_sock, buffer, size);
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual int WiFiUDP::read()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:125:23: error: '_sock' was not declared in this scope
ServerDrv::getData(_sock, &b);
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual int WiFiUDP::read(unsigned char*, size_t)':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:137:31: error: '_sock' was not declared in this scope
if (!ServerDrv::getDataBuf(_sock, buffer, &size))
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual int WiFiUDP::peek()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:152:22: error: '_sock' was not declared in this scope
ServerDrv::getData(_sock, &b, 1);
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual IPAddress WiFiUDP::remoteIP()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:167:25: error: '_sock' was not declared in this scope
WiFiDrv::getRemoteData(_sock, _remoteIp, _remotePort);
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp: In member function 'virtual uint16_t WiFiUDP::remotePort()':
/private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/WiFi/src/WiFiUdp.cpp:177:25: error: '_sock' was not declared in this scope
Multiple libraries were found for "Servo.h"
Used: /Users/PO/Library/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/libraries/Servo
Not used: /private/var/folders/vt/_1qh_xdx62xcwllq01svtgv40000gn/T/AppTranslocation/357588B0-07EE-4227-9CA3-E59A1ED6944F/d/Arduino.app/Contents/Java/libraries/Servo
Error compiling.
Quelqu’un peut il m’aider ? j’utilise Arduino 1.6.5 comme dans les tutos.
merci d’avance
