Jeedom V4.1.17 buster et plugin google smarthome
Depuis la migration, lorsque je fais une demande (exemple ouvre les volets), j’ai en retour « une erreur s’est produite sur les volets » et ce pour toutes les commandes.
J’ai relancé 3 fois les dépendances avec comme résultat:
*             Installation des dépendances             *
Hit:1 http://www.deb-multimedia.org buster InRelease
Hit:2 http://ftp.uk.debian.org/debian buster InRelease
Hit:3 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:4 http://security.debian.org/debian-security buster/updates InRelease
Hit:6 https://deb.nodesource.com/node_12.x buster InRelease
Hit:7 https://oph.mdrjr.net/meveric all InRelease
Hit:8 https://oph.mdrjr.net/meveric buster InRelease
Err:5 https://repo.jeedom.com/odroid stable InRelease
502  Bad Gateway [IP: 51.210.253.116 443]
Reading package lists...
Building dependency tree...
Reading state information...
81 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease  502  Bad Gateway [IP: 51.210.253.116 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 82 not upgraded.
/var/www/html/plugins/gsh/core/class/../../resources/install_apt.sh: line 10: ${PROGRESS_FILE}: ambiguous redirect
Version actuelle : 12
Ok, version suffisante
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
npm : Depends: nodejs (>= 6.11~) but it is not going to be installed
Depends: node-abbrev (>= 1.1.1~) but it is not going to be installed
Depends: node-ansi-regex (>= 3.0~) but it is not going to be installed
Depends: node-ansistyles (>= 0.1.3~) but it is not going to be installed
Depends: node-aproba (>= 1.2~) but it is not going to be installed
Depends: node-archy (>= 1.0~) but it is not going to be installed
Depends: node-cacache (>= 10.0.4~) but it is not going to be installed
Depends: node-bluebird (>= 3.5.1~) but it is not going to be installed
Depends: node-call-limit (>= 1.1~) but it is not going to be installed
Depends: node-chownr (>= 1.0.1~) but it is not going to be installed
Depends: node-config-chain (>= 1.1.11~) but it is not going to be installed
Depends: node-detect-indent (>= 5.0~) but it is not going to be installed
Depends: node-detect-newline (>= 2.1~) but it is not going to be installed
Depends: node-editor (>= 1.0~) but it is not going to be installed
Depends: node-fs-vacuum (>= 1.2.10~) but it is not going to be installed
Depends: node-fs-write-stream-atomic (>= 1.0.10~) but it is not going to be installed
Depends: node-glob (>= 7.1.2~) but it is not going to be installed
Depends: node-graceful-fs (>= 4.1.11~) but it is not going to be installed
Depends: node-has-unicode (>= 2.0.1~) but it is not going to be installed
Depends: node-hosted-git-info (>= 2.6~) but it is not going to be installed
Depends: node-iferr (>= 0.1.5~) but it is not going to be installed
Depends: node-inflight (>= 1.0.6~) but it is not going to be installed
Depends: node-inherits (>= 2.0.3~) but it is not going to be installed
Depends: node-ini (>= 1.3.5~) but it is not going to be installed
Depends: node-npm-package-arg but it is not going to be installed
Depends: node-promzard but it is not going to be installed
Depends: node-jsonstream (>= 1.3.2~) but it is not going to be installed
Depends: node-json-parse-better-errors (>= 1.0.1~) but it is not going to be installed
Depends: node-lazy-property (>= 1.0~) but it is not going to be installed
Depends: node-libnpx (>= 10.0.1~) but it is not going to be installed
Depends: node-lockfile (>= 1.0.3~) but it is not going to be installed
Depends: node-lru-cache (>= 4.1.1~) but it is not going to be installed
Depends: node-mississippi (>= 3.0~) but it is not going to be installed
Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
Depends: node-move-concurrently (>= 1.0.1~) but it is not going to be installed
Depends: node-nopt but it is not going to be installed
Depends: node-normalize-package-data (>= 2.4~) but it is not going to be installed
Depends: node-gyp (>= 3.6.2~) but it is not going to be installed
Depends: node-resolve-from (>= 4.0~) but it is not going to be installed
Depends: node-encoding but it is not going to be installed
Depends: node-errno but it is not going to be installed
Depends: node-npmlog (>= 4.1.2~) but it is not going to be installed
Depends: node-once (>= 1.4~) but it is not going to be installed
Depends: node-opener (>= 1.4.3~) but it is not going to be installed
Depends: node-osenv (>= 0.1.5~) but it is not going to be installed
Depends: node-path-is-inside (>= 1.0.2~) but it is not going to be installed
Depends: node-promise-inflight (>= 1.0.1~) but it is not going to be installed
Depends: node-ansi but it is not going to be installed
Depends: node-qw (>= 1.0.1~) but it is not going to be installed
Depends: node-read (>= 1.0.7~) but it is not going to be installed
Depends: node-read-package-json (>= 2.0.13~) but it is not going to be installed
Depends: node-request (>= 2.83~) but it is not going to be installed
Depends: node-retry (>= 0.10.1~) but it is not going to be installed
Depends: node-rimraf (>= 2.6.2~) but it is not going to be installed
Depends: node-safe-buffer (>= 5.1.1~) but it is not going to be installed
Depends: node-semver (>= 5.5~) but it is not going to be installed
Depends: node-sha (>= 2.0.1~) but it is not going to be installed
Depends: node-slide (>= 1.1.6~) but it is not going to be installed
Depends: node-sorted-object (>= 2.0.1~) but it is not going to be installed
Depends: node-from2 but it is not going to be installed
Depends: node-stream-iterate but it is not going to be installed
Depends: node-ssri (>= 5.2.4~) but it is not going to be installed
Depends: node-strip-ansi (>= 4.0~) but it is not going to be installed
Depends: node-tar (>= 4.4~) but it is not going to be installed
Depends: node-text-table (>= 0.2~) but it is not going to be installed
Depends: node-uid-number (>= 0.0.6~) but it is not going to be installed
Depends: node-unique-filename (>= 1.1~) but it is not going to be installed
Depends: node-unpipe (>= 1.0~) but it is not going to be installed
Depends: node-boxen (>= 1.2.1~) but it is not going to be installed
Depends: node-import-lazy but it is not going to be installed
Depends: node-is-npm (>= 1.0~) but it is not going to be installed
Depends: node-latest-version (>= 3.0~) but it is not going to be installed
Depends: node-semver-diff (>= 2.0~) but it is not going to be installed
Depends: node-xdg-basedir (>= 3.0~) but it is not going to be installed
Depends: node-validate-npm-package-name (>= 3.0~) but it is not going to be installed
Depends: node-which (>= 1.3~) but it is not going to be installed
Depends: node-wrappy (>= 1.0.2~) but it is not going to be installed
Depends: node-write-file-atomic (>= 2.3~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
npm WARN ts-node@8.2.0 requires a peer of typescript@>=2.0 but none is installed. You must install peer dependencies yourself.
audited 73 packages in 2.833s
found 1 low severity vulnerability
run `npm audit fix` to fix them, or `npm audit` for details
*             Installation terminée                    *
Une idée d’ou vient le bug ?
Eric
Je commencerai par faire ce que dit le log
Fait, mais j’ai l’erreur suivante:
npm ERR! code AUDITNOPJSON npm ERR! audit No package.json found: cannot audit a project without a package.json
Pour moi, c’est du chinois.
Eric
