J’ai une JEEDOM SMART sous la version 3.3.53 en debian 9 qui redémarre toute seule environ toutes les 10-20 minutes et je n’ai aucune idée pourquoi, juste avant de redémarrer j’ai les logs suivantes dans syslog :
Nov 3 20:43:01 localhost CRON[20356]: (root) CMD (su --shell=/bin/bash - www-data -c '/usr/bin/php /var/www/html/core/php/jeeCron.php' >> /dev/null)
Nov 3 20:43:01 localhost CRON[20358]: (root) CMD (/usr/bin/php /var/www/html/install/update/../../core/php/watchdog.php >> /dev/null)
Nov 3 20:44:01 localhost CRON[22097]: (root) CMD (su --shell=/bin/bash - www-data -c '/usr/bin/php /var/www/html/core/php/jeeCron.php' >> /dev/null)
Nov 3 20:44:01 localhost CRON[22098]: (root) CMD (/usr/bin/php /var/www/html/install/update/../../core/php/watchdog.php >> /dev/null)
Nov 3 20:44:01 localhost CRON[22101]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Nov 3 20:45:01 localhost CRON[23857]: (root) CMD (/usr/bin/php /var/www/html/install/update/../../core/php/watchdog.php >> /dev/null)
Nov 3 20:45:01 localhost CRON[23858]: (root) CMD (su --shell=/bin/bash - www-data -c '/usr/bin/php /var/www/html/core/php/jeeCron.php' >> /dev/null)
Nov 3 20:45:01 localhost CRON[23860]: (www-data) CMD (/usr/bin/php /var/www/html/core/php/jeeCron.php >> /dev/null)
Nov 3 20:45:20 localhost systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Nov 3 20:45:20 localhost systemd[1]: Stopped target Timers.
Nov 3 20:45:20 localhost systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Nov 3 20:45:20 localhost systemd[1]: Stopped Clean PHP session files every 30 mins.
Nov 3 20:45:20 localhost systemd[1]: Stopped target Graphical Interface.
Nov 3 20:45:20 localhost systemd[1]: Stopped target Sound Card.
Nov 3 20:45:20 localhost systemd[1]: Stopped target Multi-User System.
Nov 3 20:45:20 localhost systemd[1]: Stopping OpenBSD Secure Shell server...
Nov 3 20:45:20 localhost systemd[1]: Stopped target Login Prompts.
Nov 3 20:45:20 localhost systemd[1]: Stopping Getty on tty1...
Nov 3 20:45:20 localhost systemd[1]: Stopping Serial Getty on ttyS0...
Nov 3 20:45:20 localhost systemd[1]: Stopping Fail2Ban Service...
Nov 3 20:45:20 localhost systemd[1]: Stopping Unattended Upgrades Shutdown...
Nov 3 20:45:20 localhost systemd[1]: Stopping Regular background program processing daemon...
Nov 3 20:45:20 localhost systemd[1]: Stopping The Apache HTTP Server...
Nov 3 20:45:20 localhost systemd[1]: Stopping LSB: mosquitto MQTT v3.1 message broker...
Nov 3 20:45:20 localhost systemd[1]: Stopping Login Service...
Nov 3 20:45:20 localhost systemd[1]: Stopping LSB: Start NTP daemon...
Nov 3 20:45:20 localhost systemd[1]: Stopping LSB: Set the CPU Frequency Scaling governor to "ondemand"...
Nov 3 20:45:20 localhost systemd[1]: Stopping The PHP 7.0 FastCGI Process Manager...
Nov 3 20:45:20 localhost systemd[1]: Stopped OpenVPN service.
Avez-vous une idée pour diagnostiquer le problème ?
