Ce matin j’ai redémarré mon raspberry 3b+ et depuis Jeedom n’est plus accessible.
This is not the page you are looking for
The file /index.php couldn’t be found.
En saisissant la ligne de commande sudo service apache2 restart j’ai le résultat suivant :
ob for apache2.service failed because the control process exited with error code.
See « systemctl status apache2.service » and « journalctl -xe » for details.
J’ai donc lancé la commande systemctl status apache2.service et voici le résultat :
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset:
Drop-In: /etc/systemd/system/apache2.service.d
└─privatetmp.conf
Active: failed (Result: exit-code) since Thu 2019-10-17 10:50:02 CEST; 34s ag
Process: 9387 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILU
oct. 17 10:50:02 raspberrypi apachectl[9387]: (98)Address already in use: AH0007
oct. 17 10:50:02 raspberrypi apachectl[9387]: no listening sockets available, sh
oct. 17 10:50:02 raspberrypi apachectl[9387]: AH00015: Unable to open logs
oct. 17 10:50:02 raspberrypi apachectl[9387]: Action ‹ start › failed.
oct. 17 10:50:02 raspberrypi apachectl[9387]: The Apache error log may have more
oct. 17 10:50:02 raspberrypi systemd[1]: apache2.service: Control process exited
oct. 17 10:50:02 raspberrypi systemd[1]: Failed to start The Apache HTTP Server.
oct. 17 10:50:02 raspberrypi systemd[1]: apache2.service: Unit entered failed st
oct. 17 10:50:02 raspberrypi systemd[1]: apache2.service: Failed with result 'ex
lines 1-17/17 (END)
Ensuite, en saisissant la commande journalctl -xe , j’ai ce résultat :
– L’unité (unit) deconz-init.service a commencé à démarrer.
oct. 17 10:55:16 raspberrypi systemd[1]: Stopped deCONZ: ZigBee gateway – REST
– Subject: L’unité (unit) deconz.service a terminé son arrêt
– Defined-By: systemd
– Support: Debian -- User Support
– L’unité (unit) deconz.service a terminé son arrêt.
oct. 17 10:55:16 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway – REST
– Subject: L’unité (unit) deconz.service a terminé son démarrage
– L’unité (unit) deconz.service a terminé son démarrage, avec le résultat done.
oct. 17 10:55:16 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway – Initi
– Subject: L’unité (unit) deconz-init.service a terminé son démarrage
– L’unité (unit) deconz-init.service a terminé son démarrage, avec le résultat
oct. 17 10:55:16 raspberrypi deCONZ[11816]: libpng warning: iCCP: known incorrec
oct. 17 10:55:16 raspberrypi deCONZ[11816]: This plugin does not support propaga
lines 1239-1261/1261 (END)
lines 1239-1258/1261 100%
Je ne suis pas expert en là matière. Si vous avez des idées, je suis preneur.
Merci pour votre aide
