Après avoir voulu mettre à jour la version de mon Jeedom en 4.2.1 (je suis actuellement 4.1.24), j’ai rencontré l’erreur suivante après l’update : (désolé pour les logs, j’ai fais une restauration et j’ai perdu les logs de l’update)
[END BACKUP SUCCESS]
Download url : https://github.com/jeedom/core/archive/beta.zip
Download in progress
Resolving github.com (github.com) 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443 connected.
HTTP request sent, awaiting response 302 Found
Location: https://codeload.github.com/jeedom/core/zip/beta [following]
--2021-07-14 16:26:15-- https://codeload.github.com/jeedom/core/zip/beta
Resolving codeload.github.com (codeload.github.com) 140.82.121.10
Connecting to codeload.github.com (codeload.github.com)|140.82.121.10|:443 connected.
HTTP request sent, awaiting response 200 | OK
Length: 72123196 (69M) [application/zip]
Saving to: '/tmp/jeedom/install/jeedom_update.zip'
0K 4% 6.43M 10s
3072K 8% 8.12M 9s
6144K 13% 8.10M 8s
9216K
17% 7.40M 8s
12288K 21% 8.42M 7s
15360K 26% 8.11M 7s
18432K 30% 8.38M 6s
21504K 34% 8.38M 6s
24576K
39% 8.34M 5s
27648K 43% 7.75M 5s
30720K 47% 9.09M 4s
33792K 52% 8.95M 4s
36864K 56% 8.79M 4s
39936K 61% 8.89M 3s
43008K
65% 7.91M 3s
46080K 69% 8.86M 3s
49152K 74% 8.81M 2s
52224K 78% 8.18M 2s
55296K 82% 8.64M 1s
58368K
. 87% 7.91M 1s
61440K 91% 8.08M 1s
64512K 95% 8.37M 0s
67584K 100% 9.59M=8.3s
2021-07-14 16:26:24 (8.27 MB/s) - '/tmp/jeedom/install/jeedom_update.zip' saved [72123196/72123196] | OK
Cleaning folders | OK
Create temporary folder | OK
Unzip in progress | OK
Clean temporary files (tmp) | OK
Disable all task
. | OK
Disable all scenario | OK
Moving files
Ignore file /tmp/jeedom_unzip/core-beta///docs/de_DE/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/en_US/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/es_ES/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/fr_FR/noteVersion.md because size is 0
Ignore file /tmp/jeedom_unzip/core-beta///docs/pt_PT/noteVersion.md because size is 0 | OK
Remove temporary files | OK
Remove useless files
Cleaning 3rdparty
Cleaning desktop
Cleaning mobile
Cleaning core
Cleaning docs
Cleaning install
Cleaning script
Cleaning vendor
PHP Fatal error: Uncaught Error: Call to undefined method update::setUpdateDate() in /var/www/html/install/update.php:225
Stack trace:
#0 {main}
thrown in /var/www/html/install/update.php on line 225
Niveau santé un bon nombre de démon n’ont pas démarrés et l’erreur la plus visible semble être celle-ci dans le centre de mise à jours.
Unknown column 'updateDate' in 'field list' : SELECT
id,
type,
logicalId,
name,
localVersion,
remoteVersion,
status,
configuration,
source,
updateDateFROM
update WHERE logicalId=:logicalId
Si jamais vous avez une idée.
PS : Après être revenu en 4.1.24 je n’ai plus de problème.
Merci à vous
