Je rencontre un problème depuis hier, mon IP public est réguliérement bannie par Jeedom.
Je suis obligé de me connecter en local, pour supprimer le bannissement.
Je m’en suis rendu compte lorsque j’ai voulu me connecter depuis l’extérieur, j’avais une erreur 404 et forcement impossible de valider mon identifiant/mdp/double authentification.
Au niveau log :
http.error:
[Thu Apr 15 11:58:09.506902 2021] [php7:warn] [pid 5616] [client 127.0.0.1:35932] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 11:58:09.507032 2021] [php7:warn] [pid 5616] [client 127.0.0.1:35932] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 11:58:09.507071 2021] [php7:warn] [pid 5616] [client 127.0.0.1:35932] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 11:58:09.507109 2021] [php7:warn] [pid 5616] [client 127.0.0.1:35932] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.533185 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.533378 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.533417 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.533451 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.911525 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.911651 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.911693 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:08.911785 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:09.168043 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:09.168188 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:09.168228 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:09.168267 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
[Thu Apr 15 12:03:09.187565 2021] [php7:warn] [pid 2317] [client 127.0.0.1:36808] PHP Warning: preg_match(): Empty regular expression in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 154
connection:
[2021-04-14 19:53:24][INFO] : Connexion de l'utilisateur : OUARZA
[2021-04-14 19:57:54][INFO] : Connexion de l'utilisateur : OUARZA
[2021-04-14 21:18:24][INFO] : Connexion de l'utilisateur : OUARZA
[2021-04-14 21:21:31][INFO] : Connexion de l'utilisateur : OUARZA
[2021-04-14 21:27:55][INFO] : Connexion de l'utilisateur : momotte
[2021-04-14 22:19:11][INFO] : Connexion de l'utilisateur par clef : OUARZA
[2021-04-15 07:26:03][INFO] : Connexion de l'utilisateur : tablette
[2021-04-15 13:34:11][INFO] : Connexion de l'utilisateur par clef : OUARZA
[2021-04-15 13:35:44][INFO] : Connexion de l'utilisateur : OUARZA
[2021-04-15 14:24:59][INFO] : Connexion de l'utilisateur par clef : OUARZA
Pouvez-vous m’aider à investiguer ce phénomène ?
Merci par avance.
Mathieu
