via le protocole jeezigbee je détecte bien la lampe lexman mais j’arrive pas à la piloter
"date_code": "20211116",
"definition": {
"description": "ENKI LEXMAN E14 LED RGBW",
"exposes": [
"features": [
"access": 7,
"description": "On\/off state of this light",
"label": "State",
"name": "state",
"property": "state",
"type": "binary",
"value_off": "OFF",
"value_on": "ON",
"value_toggle": "TOGGLE"
"access": 7,
"description": "Brightness of this light",
"label": "Brightness",
"name": "brightness",
"property": "brightness",
"type": "numeric",
"value_max": 254,
"value_min": 0
"access": 7,
"description": "Color temperature of this light",
"label": "Color temp",
"name": "color_temp",
"presets": [
"description": "Coolest temperature supported",
"name": "coolest",
"value": 153
"description": "Cool temperature (250 mireds \/ 4000 Kelvin)",
"name": "cool",
"value": 250
"description": "Neutral temperature (370 mireds \/ 2700 Kelvin)",
"name": "neutral",
"value": 370
"description": "Warmest temperature supported",
"name": "warmest",
"value": 370
"property": "color_temp",
"type": "numeric",
"unit": "mired",
"value_max": 370,
"value_min": 153
"access": 7,
"description": "Color temperature after cold power on of this light",
"label": "Color temp startup",
"name": "color_temp_startup",
"presets": [
"name": "coolest",
"value": 153
"name": "cool",
"value": 250
"name": "neutral",
"value": 370
"name": "warmest",
"value": 370
"description": "Restore previous color_temp on cold power on",
"name": "previous",
"value": 65535
"property": "color_temp_startup",
"type": "numeric",
"unit": "mired",
"value_max": 370,
"value_min": 153
"access": 7,
"description": "Color of this light in the CIE 1931 color space (x\/y)",
"features": [
"access": 7,
"label": "X",
"name": "x",
"property": "x",
"type": "numeric"
"access": 7,
"label": "Y",
"name": "y",
"property": "y",
"type": "numeric"
"label": "Color (X\/Y)",
"name": "color_xy",
"property": "color",
"type": "composite"
"type": "light"
"access": 2,
"description": "Triggers an effect on the light (e.g. make light blink for a few seconds)",
"label": "Effect",
"name": "effect",
"property": "effect",
"type": "enum",
"values": [
"blink",
"breathe",
"okay",
"channel_change",
"finish_effect",
"stop_effect",
"colorloop",
"stop_colorloop"
"access": 7,
"category": "config",
"description": "Controls the behavior when the device is powered on after power loss. If you get an `UNSUPPORTED_ATTRIBUTE` error, the device does not support it.",
"label": "Power-on behavior",
"name": "power_on_behavior",
"property": "power_on_behavior",
"type": "enum",
"values": [
"off",
"on",
"toggle",
"previous"
"access": 1,
"category": "diagnostic",
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "IP-CDZOTAAP005JA-MAN",
"options": [
"access": 2,
"description": "Controls the transition time (in seconds) of on\/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).",
"label": "Transition",
"name": "transition",
"property": "transition",
"type": "numeric",
"value_min": 0
"access": 2,
"description": "When enabled colors will be synced, e.g. if the light supports both color x\/y and color temperature a conversion from color x\/y to color temperature will be done when setting the x\/y color (default true).",
"label": "Color sync",
"name": "color_sync",
"property": "color_sync",
"type": "binary",
"value_off": false,
"value_on": true
"access": 2,
"description": "State actions will also be published as 'action' when true (default false).",
"label": "State action",
"name": "state_action",
"property": "state_action",
"type": "binary",
"value_off": false,
"value_on": true
"supports_ota": false,
"vendor": "ADEO"
"disabled": false,
"endpoints": {
"1": {
"bindings": [],
"clusters": {
"input": [
"genBasic",
"genIdentify",
"genGroups",
"genScenes",
"genOnOff",
"genLevelCtrl",
"lightingColorCtrl",
"touchlink",
"manuSpecificAmazonWWAH",
"heimanSpecificInfraRedRemote"
"output": [
"genOta"
"configured_reportings": [],
"scenes": []
"242": {
"bindings": [],
"clusters": {
"input": [],
"output": [
"greenPower"
"scenes": []
"friendly_name": "0x881a14fffe922eae",
"ieee_address": "0x881a14fffe922eae",
"interview_completed": true,
"interviewing": false,
"manufacturer": "Adeo",
"model_id": "ZBEK-3",
"network_address": 17998,
"power_source": "Mains (single phase)",
"software_build_id": "2.11.00",
"supported": true,
"type": "Router"
