Je voudrai rajouter 1 module MOES à la bibliothèque des équipements du plugin Zigbee :
MOES - [ZSS-ZK-THL-C] - CAPTEUR DE TEMPÉRATURE, HUMIDITÉ ET LUMINOSITÉ ZIGBEE
"ieee": "5c:02:72:ff:fe:03:cf:d1",
"nwk": 36897,
"status": 2,
"lqi": "255",
"rssi": "-22",
"last_seen": "1669536145.514036",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 262,
"profile_id": 260,
"manufacturer": "_TYZB01_ftdkanlj",
"model": "TS0222",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 75
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TYZB01_ftdkanlj"
"id": 5,
"name": "model",
"value": "TS0222"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 33,
"name": "battery_percentage_remaining",
"value": 200
"id": 1024,
"name": "Illuminance Measurement",
"attributes": [
"id": 0,
"name": "measured_value",
"value": 0
"id": 2,
"status": 1,
"device_type": 770,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 1026,
"name": "Temperature Measurement",
"attributes": [
"id": 0,
"value": 0
"id": 1029,
"name": "Relative Humidity Measurement",
"attributes": [
"id": 0,
"value": 0
"signature": {
"model": "TS0222",
"node_desc": {
"logical_type": 2,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 262,
"input_clusters": [
0,
1,
1024
25,
10
"2": {
"profile_id": 260,
"device_type": 770,
"input_clusters": [
1026,
1029
"class": "zigpy.device"
Merci d’avance
Cordialement
mais je l’ai pas vu.
