J’ai un problème avec l’ajout dans mon réseau zigbee de la vanne ZG-V01
Elle n’est pas reconnu alors que sur le site Jeedom compatibility, elle est présente.
Je vois également des fichiers dans le dossier mais ça ne semble pas correspondre au même modèle hors je ne pense pas qu’il y en ai beaucoup !? Quel est le soucis ?
Plugin Zigbee bêta version 2021-05-11 01:03:15
Objet : GR-SMARTHOME - MOTORISATION ZIGBEE 3.0 POUR VANNE 1/4 DE TOUR
Lien : GR-SMARTHOME - Motorisation Zigbee 3.0 pour vanne 1/4 de tour (domadoo.fr)
"ieee": "60:a4:23:ff:fe:fb:d1:eb",
"nwk": 58275,
"status": 2,
"lqi": "188",
"rssi": "-53",
"last_seen": "1620835466.1162865",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "_TZ3000_m8gy8jy1",
"model": "TS0001",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 71
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_m8gy8jy1"
"id": 5,
"name": "model",
"value": "TS0001"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 57344,
"name": "Cluster",
"attributes": []
"id": 57345,
"name": "Cluster",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "TS0001",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
3,
4,
5,
6,
57344,
57345
25,
10
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Fichier zigbee en debug en effectuant un appuie sur le bouton pour faire le quart de tour puis un autre appuie quelques secondes plus tard :
zigbee.bin.txt (7,2 Ko)
Merci pour l’analyse
