Intégration tête thermostatique MOES ZTRV-BY-100-WH-MS
Bonjour ,
Pouvez-vous intégrer les ZTRV-BY-100-WH-MS (pas FR) de chez MOES dans le plugin ZIGBEE , Le plugin les détectent bien ( en ZTRV…-FR) mais le pilotage de la consigne avec Jeedom ne fonctionne pas.
on
 Configuration
 Action
 Informations brutes
 Configuration json
    "ieee": "a4:c1:38:55:af:cb:99:c5",
    "nwk": 13707,
    "status": 2,
    "lqi": "188",
    "rssi": "-53",
    "last_seen": "1697276266.410684",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 769,
            "profile_id": 260,
            "manufacturer": "_TZE200_b6wax7g0",
            "model": "TS0601",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 67
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_b6wax7g0"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Tuya Manufacturer Specicific",
                    "attributes": [
                            "id": 621,
                            "name": "valve_state",
                            "value": 5
                            "id": 514,
                            "name": "target_temperature",
                            "value": 21
                            "id": 515,
                            "name": "temperature",
                            "value": 220
                            "id": 615,
                            "name": "max_temperature",
                            "value": 300
                            "id": 617,
                            "name": "boost_duration_seconds",
                            "value": 0
                            "id": 619,
                            "name": "comfort_mode_temperature",
                            "value": 20
                            "id": 620,
                            "name": "eco_mode_temperature",
                            "value": 45
                    "id": 513,
                    "name": "MoesThermostatNew",
                    "attributes": [
                            "id": 0,
                            "name": "local_temperature",
                            "value": 2200
                            "id": 18,
                            "name": "occupied_heating_setpoint",
                            "value": 2100
                            "id": 22,
                            "name": "max_heat_setpoint_limit",
                            "value": 30000
                            "id": 30,
                            "name": "running_mode",
                            "value": 4
                            "id": 41,
                            "name": "running_state",
                            "value": 1
                            "id": 16384,
                            "name": "comfort_heating_setpoint",
                            "value": 2000
                            "id": 16385,
                            "name": "eco_heating_setpoint",
                            "value": 4500
                            "id": 16388,
                            "name": "valve_open_percentage",
                            "value": 5
                            "id": 16389,
                            "value": 0
                    "id": 516,
                    "name": "Thermostat User Interface Configuration",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": []
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 769,
                "input_clusters": [
                    0,
                    4,
                    5,
                    61184,
                    513,
                    516,
                    6,
                    1
                    10,
                    25
    "class": "zhaquirks.tuya.ts0601_trv"
Le plugin zigbee est déprécié au profit du nouveau plugin jeezigbee donc il n’y aura plus de nouvelle intégration dans le plugin zigbee.
Sérieux ?
C’est la grosse galère là , je peux pas utiliser la même clé zigbee pour faire fonctionner les 2 plugins .
Oui et cela depuis plusieurs mois déjà.
Non c’est l’un ou l’autre, la clé ne peu fonctionner qu’avec un seul plugin, mais si vous avec acheté le plugin zigbee le nouveau plugin jeezigbee est gratuit et de plus ce nouveau plugin s’appuie sur une base de donnée de device beaucoup plus grande, base qui est mise à jour chaque mois
Oui je viens de lire plusieurs lignes la dessus . Je vais devoir basculer de plugin , ça va me prendre du temps .
Je n’ai jamais utilisé l’outil remplacer , y a t’il des subtilité à connaître ?
Moi non plus donc je n’en ai aucune idée, désolé.
Merci en tout cas de ton aide
