Intégration Hue outdoor wall
Je viens d’intégrer 4 lumières Hue sur un mur de jardin.
Il s’agit de lumière « Hue Outdoor wall » et si le module philipshue les repère bien quand je scanne, il ne les intègre pas.
Le log m’indique
[2021-12-23 09:53:28][DEBUG] : No configuration found for light : 1742930P7 => {"id":16,"attributes":{"state":{"on":false,"bri":208,"hue":7613,"sat":203,"effect":"none","xy":[0.5053,0.4152],"ct":454,"alert":"select","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2021-12-22T13:06:25"},"type":"Extended color light","name":"Mur 1","modelid":"1742930P7","manufacturername":"Signify Netherlands B.V.","productname":"Hue outdoor wall","capabilities":{"certified":true,"control":{"mindimlevel":100,"maxlumen":404,"colorgamuttype":"C","colorgamut":[[0.6915,0.3083],[0.17,0.7],[0.1532,0.0475]],"ct":{"min":153,"max":500}},"streaming":{"renderer":true,"proxy":true}},"config":{"archetype":"walllantern","function":"mixed","direction":"omnidirectional","startup":{"mode":"safety","configured":true}},"uniqueid":"00:17:88:01:09:85:b7:5c-0b","swversion":"1.93.3","swconfigid":"3C58692D","productid":"3241-3127-7871_HC02_PSU01"},"client":{}}
Ce n’est pas gênant puisque j’ai des alternatives de gestion mais je fais remonter l’info.
Si il existe une possibilité d’intégration "à la main, je reste néanmoins preneur^^
Bonne journée
