MQTT Manager - Aucun dossier SSL trouvé
bon je teste une install à zéro de zwavejs + mqttmanager et pour moi ça marche pas sur 4.3.10
les dépendances vont au bout sans problème pour la partie mqtt:
0000|+ echo '*******************Begin of package installation******************'
0002|+ touch /tmp/jeedom_install_in_progress_mqtt2
0003|+ echo 1
0004|+ echo 2
0005|+ sudo chmod +x /var/www/html/core/class/../../resources/install_nodejs.sh
0006|+ sudo /var/www/html/core/class/../../resources/install_nodejs.sh
0007|Reading package lists...
0008|E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
0009|E: Unable to lock directory /var/lib/apt/lists/
0010|Reading package lists...
0011|Building dependency tree...
0012|Reading state information...
0013|apt-utils is already the newest version (1.8.2.3).
0014|build-essential is already the newest version (12.6).
0015|lsb-release is already the newest version (10.2019051400).
0016|git is already the newest version (1:2.20.1-2+deb10u4).
0017|0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
0018|[Check Version NodeJS actuelle : v16.18.1 : [  OK  ]
0019|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [  OK  ]
0020|+ echo 3
0021|+ sudo chmod +x /var/www/html/core/class/../../resources/install_nodejs.sh
0022|+ sudo /var/www/html/core/class/../../resources/install_nodejs.sh
0023|Reading package lists...
0024|E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
0025|E: Unable to lock directory /var/lib/apt/lists/
0026|Reading package lists...
0027|Building dependency tree...
0028|Reading state information...
0029|apt-utils is already the newest version (1.8.2.3).
0030|build-essential is already the newest version (12.6).
0031|lsb-release is already the newest version (10.2019051400).
0032|git is already the newest version (1:2.20.1-2+deb10u4).
0033|0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
0034|[Check Version NodeJS actuelle : v16.18.1 : [  OK  ]
0035|[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [  OK  ]
0036|+ echo 4
0037|+ cd /var/www/html/core/class/../../plugins/mqtt2/resources/mqtt2d
0038|+ rm -rf node_modules
0039|+ sudo npm install
0040|npm WARN deprecated har-validator@5.1.5: this library is no longer supported
0041|npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
0042|npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
0043|added 147 packages, and audited 148 packages in 25s
0044|13 packages are looking for funding
0045|run `npm fund` for details
0046|found 0 vulnerabilities
0047|npm notice
0048|npm notice New major version of npm available! 8.19.2 -> 9.1.2
0049|npm notice Changelog:
0050|npm notice Run `npm install -g npm@9.1.2` to update!
0051|npm notice
0052|+ chown -R www-data:www-data jeedom mqtt2d.js node_modules package-lock.json package.json
0053|+ echo 5
0054|+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end mqtt2
0055|+ rm /tmp/jeedom_install_in_progress_mqtt2
0056|+ echo '*******************End of package installation******************'
0057|*******************End of package installation******************
le plugin apparaît dans l’interface,
je clique sur installer mosquitto en local, ça mouline et ça remplit les champs :
et quand je tente de lancer le démon :
0010|[2022-11-18 14:54:13]ERROR : Erreur sur la fonction deamon_start du plugin : Aucun dossier SSL trouvé, avez vous installé Mosquitto d\'abord ?
0011|[2022-11-18 14:55:03]ERROR : Erreur sur la fonction deamon_start du plugin : Aucun dossier SSL trouvé, avez vous installé Mosquitto d\'abord ?
il n’y a pas de log de cette installation de mosquitto et manifestement il ne doit pas être démarré car dans /var/log il n’y a pas de dossier mosquitto
Il faut remettre les droits à plat depuis la configuration générale Jeedom, onglet OS/DB :
puis cliquer à nouveau sur Installer Mosquitto.
ok je fais ça et je reteste
ok c’est bon ça avance. il faudrait peut être mettre un warning dans la doc à ce sujet :wink:
Oui je vais ajouter un point dans la doc.
Le problème c’est que les cas sont trop rares pour identifier l’origine exacte de ce problème de droits surtout que c’est le core qui gère l’installation. Tu avais déjà tenté une installation de Z-Wave JS ou MQTT Manager aupravant sur cette machine ?
Edit : Finalement j’ai indiqué la marche à suivre directement dans le message d’erreur.
non justement, mais c’est un jeedom standart 4.1 monté en 4.2 puis 4.3. je n’ai rien bidouillé dessus donc normalement tout doit être à l’identique d’une montée de version standard. si cette manip permet de résoudre ce souci, c’est très bien et après tout c’est pas plus mal de revoir si les droits n’ont pas sauté.
en complément sur ma béta de test en debian 11 neuf je n’ai pas eu ce problème, c’est donc dû à des montée en version sur debian 10.
