Bonjour à toutes et à tous,
Sur ma Jeedom SMART j’ai changé mon EMMC (8go → 16go).
Pour cela j’ai fait une sauvegarde et je l’ai restauré.
Tous les plugins sont repartis hormis BLEA et KLF200.
A l’installation des dépendances j’ai quelques choses qui ne passent pas bien dès le départ.
J’ai le sentiment qu’il manque quelques choses.
* Installation des dépendances *
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:4 http://www.deb-multimedia.org buster InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Hit:6 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:7 https://oph.mdrjr.net/meveric all InRelease
Hit:8 https://oph.mdrjr.net/meveric buster InRelease
Err:3 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.178.69.128 443]
Fetched 122 kB in 15s (7925 B/s)
Reading package lists...
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease 502 Bad Gateway [IP: 51.178.69.128 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Installation des dépendances apt
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 138 not upgraded.
Installation du module pyvlx pour python
Collecting pyvlx
Using cached https://files.pythonhosted.org/packages/0f/04/a84b2358e3f98a6c3136508e7ceb03108a280701e32ebcea2b66b2fa72d5/pyvlx-0.2.20.tar.gz
Requirement already satisfied: PyYAML in /usr/local/lib/python3.7/dist-packages (from pyvlx) (5.4.1)
Building wheels for collected packages: pyvlx
Running setup.py bdist_wheel for pyvlx: started
Running setup.py bdist_wheel for pyvlx: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-mx5fncol/pyvlx/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-7_9d5inz --python-tag cp37:
/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:741: UserWarning: Usage of dash-separated 'description-file' will not be supported in future versions. Please use the underscore name 'description_file' instead
% (opt, underscore_opt)
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for pyvlx
Running setup.py clean for pyvlx
Failed to build pyvlx
Installing collected packages: pyvlx
Running setup.py install for pyvlx: started
Running setup.py install for pyvlx: finished with status 'done'
Successfully installed pyvlx
Collecting PyYAML==5.4.1
Installing collected packages: PyYAML
Found existing installation: PyYAML 5.4.1
Uninstalling PyYAML-5.4.1:
Successfully uninstalled PyYAML-5.4.1
Successfully installed PyYAML-5.4.1
* Installation terminée *
