J’essaie tant bien que mal d’installer les dépendances de zigbeelinker sur mon RPI3 mais j’ai toujours le même message en fin d’installation, ci-dessous le log :
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Ign:3 https://deb.nodesource.com/node_14.x buster InRelease
Ign:4 https://deb.nodesource.com/node_14.x buster Release
Ign:5 https://deb.nodesource.com/node_14.x buster/main Sources
Ign:6 https://deb.nodesource.com/node_14.x buster/main armhf Packages
Ign:7 https://deb.nodesource.com/node_14.x buster/main all Packages
Ign:8 https://deb.nodesource.com/node_14.x buster/main Translation-en
Err:5 https://deb.nodesource.com/node_14.x buster/main Sources
The HTTP server sent an invalid reply header
Reading package lists...
W: The repository 'https://deb.nodesource.com/node_14.x buster Release' does not have a Release file.
E: Failed to fetch https://deb.nodesource.com/node_14.x/dists/buster/main/source/Sources The HTTP server sent an invalid reply header
E: Some index files failed to download. They have been ignored, or old ones used instead.
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1+rpi2).
gcc is already the newest version (4:8.3.0-1+rpi2).
git is already the newest version (1:2.20.1-2+deb10u3).
make is already the newest version (4.2.1-1.2).
0 upgraded, 0 newly installed, 0 to remove and 370 not upgraded.
##### Install or update NodeJs
NodeJs 14 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (1.5.7-1+deb10u1).
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
Removed /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service.
##### Update : Download update from Zigbee2mqtt git
##### up to date
##### Configure deamon and start it
mv: cannot stat '/opt/zigbee2mqtt/data/database.db': No such file or directory
mv: cannot stat '/opt/zigbee2mqtt/data/state.json': No such file or directory
chown: cannot access '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json': No such file or directory
chown: cannot access '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db': No such file or directory
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
J’imagine que c’est bêtement un problème de droit mais là je sèche…
Ce RPI est un jeedom secondaire, je gère quelques sondes via jeediuno et fait office d’antenne BLEA également, par d’autres plugin dessus…
Et si je relance les dépendances, j’ai toujours la même fin…
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
0 upgraded, 0 newly installed, 0 to remove and 33 not upgraded.
##### Install Socat
##### up to date
# END #
J’ai mis à jour en buster depuis stretch, peut-être ça le problème…
Je vais voir pour refaire une installation clean depuis une base buster et ma sauvegarde d’hier soir…
