Je suis en V4.2.14 et impossible d’installer les dépendances pour faire fonctionner le plugin.
Merci pour votre aide
Pouvez-vous donc au minimum fournir les logs (copier/coller le contenu dans un Texte préformaté) et une capture de la page santé.
Voici le log [2022-03-12 08:29:28][ERROR] : Le démon n’est pas démarré
Gardena update
* Launch install of dependencies *
Sat Mar 12 09:46:13 CET 2022
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 https://deb.nodesource.com/node_14.x buster InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists...
Install modules using apt-get
Building dependency tree...
Reading state information...
python3 is already the newest version (3.7.3-1).
python3-requests is already the newest version (2.21.0-1).
python3-setuptools is already the newest version (40.8.0-1).
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
Install the required python libraries
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: requests>=2.20.0 in /usr/local/lib/python3.7/dist-packages (2.27.1)
Requirement already satisfied: oauthlib in /usr/local/lib/python3.7/dist-packages (3.2.0)
Requirement already satisfied: requests_oauthlib in /usr/local/lib/python3.7/dist-packages (1.3.1)
Requirement already satisfied: websocket-client~=1.2 in /usr/local/lib/python3.7/dist-packages (1.3.1)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests>=2.20.0) (1.26.8)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests>=2.20.0) (2021.10.8)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests>=2.20.0) (3.3)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests>=2.20.0) (2.0.12)
Sat Mar 12 09:46:23 CET 2022
* Install ended *
La page santé est vierge
C’est à dire ?
Il y a toujours quelque chose sur la page santé jeedom.
Pouvez-vous fournir une capture svp ?
Et donc les dépendances sont installées sans problème.
Pourquoi dites-vous ?
Le démon démarre ? Y a-t-il un log ? Si oui veuillez le fournir également (dans un Texte préformaté cette fois svp sinon c’est illisible)
Vous m’avez mal compris, il me fallait bien la page santé jeedom, pas la santé des équipements gardena;
Mais ce n’est plus important à présent.
Si les dépendances sont bien installées mais je vois le problème maintenant, c’est probablement le même qu’ici: KO côté dépendances - #3 par Mips
J’avais modifié le plugin mais il semble que la stable n’était pas passée; je viens de reforcer la synchro avec le market et cela semble ok à présent.
Pouvez-vous vérifier les mises à jours sur jeedom? il devrait vous proposer une nouvelle version.
C’est bon pour les dépendances mais maintenant c’est le daemon qui bloque
[2022-03-12 11:28:20][INFO] : Starting daemon
[2022-03-12 11:28:20][INFO] : Log level: error
[2022-03-12 11:28:20][ERROR] : Fatal error : (invalid_grant) The provided access grant is invalid, expired, or revoked.
[2022-03-12 18:52:53][INFO] : Starting daemon
[2022-03-12 18:52:53][INFO] : Log level: error
[2022-03-12 18:52:54][ERROR] : Fatal error : (invalid_grant) The provided access grant is invalid, expired, or revoked.
Vérifiez que vous avez accordé les droits sur les apis.
Je viens de refaire les paramétrages API.
Tout me semble ok.
J’ai tout activé mais toujours impossible de lancer le Daemon
C’est bon, problème de mot de passe !!! Merci pour ton aide
