un extrait des miens il y en a qui ne sont pas dans la base
7898|[2021-11-30 17:19:00][DEBUG] : Message: 0a5201c57e0100954e0369
7899|[2021-11-30 17:19:00][DEBUG] : Decode : 0a5201c57e0100954e0369
7900|[2021-11-30 17:19:00][DEBUG] : Test message: 0a5201c57e0100954e0369
7901|[2021-11-30 17:19:00][DEBUG] : PacketType: 0x52
7902|[2021-11-30 17:19:00][DEBUG] : Length: 11
7903|[2021-11-30 17:19:00][DEBUG] : Start decoding packet type 0x52
7904|[2021-11-30 17:19:00][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
7905|[2021-11-30 17:19:00][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0xC5', 'id1': '0x7E', 'id2': '0x01', 'temperaturesign': '', 'temperature': 149, 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7906|[2021-11-30 17:19:00][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': '7E01', 'temperature': '14.9', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7907|[2021-11-30 17:19:00][DEBUG] : Device is known id : 7E01
7908|[2021-11-30 17:19:00][DEBUG] : Send to jeedom : {'devices': {'7E0152': {'packettype': '0x52', 'subtype': '0x01', 'id': '7E01', 'temperature': '14.9', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}}}
7909|[2021-11-30 17:19:00][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
7910|[2021-11-30 17:19:00][DEBUG] : {"devices":{"7E0152":{"packettype":"0x52","subtype":"0x01","id":"7E01","temperature":"14.9","humidity":78,"humidity_status":3,"battery":100,"rssi":6}}}
7911|[2021-11-30 17:19:00][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=@Dom HTTP/1.1" 200 0
7912|[2021-11-30 17:19:04][DEBUG] : Message: 0a520ac67b0100b73d0179
7913|[2021-11-30 17:19:04][DEBUG] : Decode : 0a520ac67b0100b73d0179
7914|[2021-11-30 17:19:04][DEBUG] : Test message: 0a520ac67b0100b73d0179
7915|[2021-11-30 17:19:04][DEBUG] : PacketType: 0x52
7916|[2021-11-30 17:19:04][DEBUG] : Length: 11
7917|[2021-11-30 17:19:04][DEBUG] : Start decoding packet type 0x52
7918|[2021-11-30 17:19:04][DEBUG] : Subtype = TH10 is Rubicson,IW008T,TX95,Xiron-EN6,WH5
7919|[2021-11-30 17:19:04][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0A', 'seqnbr': '0xC6', 'id1': '0x7B', 'id2': '0x01', 'temperaturesign': '', 'temperature': 183, 'humidity': 61, 'humidity_status': 1, 'battery': 100, 'rssi': 7}
7920|[2021-11-30 17:19:04][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x0A', 'id': '7B01', 'temperature': '18.3', 'humidity': 61, 'humidity_status': 1, 'battery': 100, 'rssi': 7}
7921|[2021-11-30 17:19:04][DEBUG] : unknown device id : 7B01
7922|[2021-11-30 17:19:39][DEBUG] : Message: 0a5201c77e0100954e0369
7923|[2021-11-30 17:19:39][DEBUG] : Decode : 0a5201c77e0100954e0369
7924|[2021-11-30 17:19:39][DEBUG] : Test message: 0a5201c77e0100954e0369
7925|[2021-11-30 17:19:39][DEBUG] : PacketType: 0x52
7926|[2021-11-30 17:19:39][DEBUG] : Length: 11
7927|[2021-11-30 17:19:39][DEBUG] : Start decoding packet type 0x52
7928|[2021-11-30 17:19:39][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
7929|[2021-11-30 17:19:39][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0xC7', 'id1': '0x7E', 'id2': '0x01', 'temperaturesign': '', 'temperature': 149, 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7930|[2021-11-30 17:19:39][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': '7E01', 'temperature': '14.9', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7931|[2021-11-30 17:19:39][DEBUG] : Device is known id : 7E01
7932|[2021-11-30 17:19:40][DEBUG] : Send to jeedom : {'devices': {'7E0152': {'packettype': '0x52', 'subtype': '0x01', 'id': '7E01', 'temperature': '14.9', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}}}
7933|[2021-11-30 17:19:40][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
7934|[2021-11-30 17:19:40][DEBUG] : {"devices":{"7E0152":{"packettype":"0x52","subtype":"0x01","id":"7E01","temperature":"14.9","humidity":78,"humidity_status":3,"battery":100,"rssi":6}}}
7935|[2021-11-30 17:19:40][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=@Dom HTTP/1.1" 200 0
7936|[2021-11-30 17:19:46][DEBUG] : Message: 0a5201c8570200944e0369
7937|[2021-11-30 17:19:46][DEBUG] : Decode : 0a5201c8570200944e0369
7938|[2021-11-30 17:19:46][DEBUG] : Test message: 0a5201c8570200944e0369
7939|[2021-11-30 17:19:46][DEBUG] : PacketType: 0x52
7940|[2021-11-30 17:19:46][DEBUG] : Length: 11
7941|[2021-11-30 17:19:46][DEBUG] : Start decoding packet type 0x52
7942|[2021-11-30 17:19:46][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
7943|[2021-11-30 17:19:46][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0xC8', 'id1': '0x57', 'id2': '0x02', 'temperaturesign': '', 'temperature': 148, 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7944|[2021-11-30 17:19:46][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': '5702', 'temperature': '14.8', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7945|[2021-11-30 17:19:46][DEBUG] : unknown device id : 5702
7946|[2021-11-30 17:19:52][DEBUG] : Message: 0a520dc9640180f79b0379
7947|[2021-11-30 17:19:52][DEBUG] : Decode : 0a520dc9640180f79b0379
7948|[2021-11-30 17:19:52][DEBUG] : Test message: 0a520dc9640180f79b0379
7949|[2021-11-30 17:19:52][DEBUG] : PacketType: 0x52
7950|[2021-11-30 17:19:52][DEBUG] : Length: 11
7951|[2021-11-30 17:19:52][DEBUG] : Start decoding packet type 0x52
7952|[2021-11-30 17:19:52][DEBUG] : Subtype = TH13 is Alecto WS1700 and compatibles
7953|[2021-11-30 17:19:52][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0D', 'seqnbr': '0xC9', 'id1': '0x64', 'id2': '0x01', 'temperaturesign': '-', 'temperature': 247, 'humidity': 155, 'humidity_status': 3, 'battery': 100, 'rssi': 7}
7954|[2021-11-30 17:19:52][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x0D', 'id': '6401', 'temperature': '-24.7', 'humidity': 155, 'humidity_status': 3, 'battery': 100, 'rssi': 7}
7955|[2021-11-30 17:19:52][DEBUG] : unknown device id : 6401
7956|[2021-11-30 17:20:01][DEBUG] : Message: 0a520acb7b0100b73d0179
7957|[2021-11-30 17:20:01][DEBUG] : Decode : 0a520acb7b0100b73d0179
7958|[2021-11-30 17:20:01][DEBUG] : Test message: 0a520acb7b0100b73d0179
7959|[2021-11-30 17:20:01][DEBUG] : PacketType: 0x52
7960|[2021-11-30 17:20:01][DEBUG] : Length: 11
7961|[2021-11-30 17:20:01][DEBUG] : Start decoding packet type 0x52
7962|[2021-11-30 17:20:01][DEBUG] : Subtype = TH10 is Rubicson,IW008T,TX95,Xiron-EN6,WH5
7963|[2021-11-30 17:20:01][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x0A', 'seqnbr': '0xCB', 'id1': '0x7B', 'id2': '0x01', 'temperaturesign': '', 'temperature': 183, 'humidity': 61, 'humidity_status': 1, 'battery': 100, 'rssi': 7}
7964|[2021-11-30 17:20:01][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x0A', 'id': '7B01', 'temperature': '18.3', 'humidity': 61, 'humidity_status': 1, 'battery': 100, 'rssi': 7}
7965|[2021-11-30 17:20:01][DEBUG] : unknown device id : 7B01
7966|[2021-11-30 17:20:03][DEBUG] : Message: 0a5201ccc10400964b0369
7967|[2021-11-30 17:20:03][DEBUG] : Decode : 0a5201ccc10400964b0369
7968|[2021-11-30 17:20:03][DEBUG] : Test message: 0a5201ccc10400964b0369
7969|[2021-11-30 17:20:03][DEBUG] : PacketType: 0x52
7970|[2021-11-30 17:20:03][DEBUG] : Length: 11
7971|[2021-11-30 17:20:03][DEBUG] : Start decoding packet type 0x52
7972|[2021-11-30 17:20:03][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
7973|[2021-11-30 17:20:03][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0xCC', 'id1': '0xC1', 'id2': '0x04', 'temperaturesign': '', 'temperature': 150, 'humidity': 75, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7974|[2021-11-30 17:20:03][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': 'C104', 'temperature': '15.0', 'humidity': 75, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7975|[2021-11-30 17:20:03][DEBUG] : Device is known id : C104
7976|[2021-11-30 17:20:03][DEBUG] : Send to jeedom : {'devices': {'C10452': {'packettype': '0x52', 'subtype': '0x01', 'id': 'C104', 'temperature': '15.0', 'humidity': 75, 'humidity_status': 3, 'battery': 100, 'rssi': 6}}}
7977|[2021-11-30 17:20:03][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
7978|[2021-11-30 17:20:03][DEBUG] : {"devices":{"C10452":{"packettype":"0x52","subtype":"0x01","id":"C104","temperature":"15.0","humidity":75,"humidity_status":3,"battery":100,"rssi":6}}}
7979|[2021-11-30 17:20:03][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=@DOM HTTP/1.1" 200 0
7980|[2021-11-30 17:20:18][DEBUG] : Message: 0a5201cd7e0100954e0369
7981|[2021-11-30 17:20:18][DEBUG] : Decode : 0a5201cd7e0100954e0369
7982|[2021-11-30 17:20:18][DEBUG] : Test message: 0a5201cd7e0100954e0369
7983|[2021-11-30 17:20:19][DEBUG] : PacketType: 0x52
7984|[2021-11-30 17:20:19][DEBUG] : Length: 11
7985|[2021-11-30 17:20:19][DEBUG] : Start decoding packet type 0x52
7986|[2021-11-30 17:20:19][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
7987|[2021-11-30 17:20:19][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0xCD', 'id1': '0x7E', 'id2': '0x01', 'temperaturesign': '', 'temperature': 149, 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7988|[2021-11-30 17:20:19][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': '7E01', 'temperature': '14.9', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7989|[2021-11-30 17:20:19][DEBUG] : Device is known id : 7E01
7990|[2021-11-30 17:20:26][DEBUG] : Message: 0a5201ce570200944e0369
7991|[2021-11-30 17:20:26][DEBUG] : Decode : 0a5201ce570200944e0369
7992|[2021-11-30 17:20:26][DEBUG] : Test message: 0a5201ce570200944e0369
7993|[2021-11-30 17:20:26][DEBUG] : PacketType: 0x52
7994|[2021-11-30 17:20:26][DEBUG] : Length: 11
7995|[2021-11-30 17:20:26][DEBUG] : Start decoding packet type 0x52
7996|[2021-11-30 17:20:26][DEBUG] : Subtype = TH1 is THGN122/123, THGN132, THGR122/228/238/268
7997|[2021-11-30 17:20:26][DEBUG] : Data : {'packetlen': '0x0A', 'packettype': '0x52', 'subtype': '0x01', 'seqnbr': '0xCE', 'id1': '0x57', 'id2': '0x02', 'temperaturesign': '', 'temperature': 148, 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7998|[2021-11-30 17:20:26][DEBUG] : Decoded info : {'packettype': '0x52', 'subtype': '0x01', 'id': '5702', 'temperature': '14.8', 'humidity': 78, 'humidity_status': 3, 'battery': 100, 'rssi': 6}
7999|[2021-11-30 17:20:26][DEBUG] : unknown device id : 5702
