Impossible d'installer le plugin blea
j’ai la version 4.2.11 sur jeedom smart et depuis la mise à jours impossible d’installer les dépendances du plugin blea.
*			 Installation des dépendances			 *
Hit:1 http://www.deb-multimedia.org buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Get:5 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:6 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:7 https://oph.mdrjr.net/meveric all InRelease
Hit:8 https://oph.mdrjr.net/meveric buster InRelease
Err:3 https://repo.jeedom.com/odroid stable InRelease
502  Bad Gateway [IP: 51.178.69.128 443]
Fetched 122 kB in 16s (7,809 B/s)
Reading package lists...
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease  502  Bad Gateway [IP: 51.178.69.128 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree...
Reading state information...
libatlas-base-dev is already the newest version (3.10.3-8).
bluetooth is already the newest version (5.50-1.2~deb10u2).
libbluetooth-dev is already the newest version (5.50-1.2~deb10u2).
build-essential is already the newest version (12.6).
libffi-dev is already the newest version (3.2.1-9).
libopenjp2-7 is already the newest version (2.3.0-2+deb10u2).
libssl-dev is already the newest version (1.1.1d-0+deb10u7).
python3-serial is already the newest version (3.4-4).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
rfkill is already the newest version (2.33.1-0.1).
libtiff5 is already the newest version (4.1.0+git191117-2~deb10u3).
0 upgraded, 0 newly installed, 0 to remove and 145 not upgraded.
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 0 newly installed, 3 reinstalled, 0 to remove and 145 not upgraded.
Need to get 0 B/1,188 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 82654 files and directories currently installed.)
Preparing to unpack .../python3_3.7.3-1_arm64.deb ...
running python pre-rtupdate hooks for python3.7...
Unpacking python3 (3.7.3-1) over (3.7.3-1) ...
Preparing to unpack .../bluez_5.50-1.2~deb10u2_arm64.deb ...
Unpacking bluez (5.50-1.2~deb10u2) over (5.50-1.2~deb10u2) ...
Preparing to unpack .../python3-pip_18.1-5_all.deb ...
Unpacking python3-pip (18.1-5) over (18.1-5) ...
Setting up python3 (3.7.3-1) ...
running python rtupdate hooks for python3.7...
running python post-rtupdate hooks for python3.7...
Setting up bluez (5.50-1.2~deb10u2) ...
Setting up python3-pip (18.1-5) ...
Processing triggers for dbus (1.12.16-1) ...
Processing triggers for systemd (241-7~deb10u4) ...
Requirement already up-to-date: setuptools in /usr/local/lib/python3.7/dist-packages (60.8.2)
git is already the newest version (1:2.20.1-2+deb10u3).
libglib2.0-dev is already the newest version (2.58.3-2+deb10u3).
Requirement already satisfied: pyudev in /usr/local/lib/python3.7/dist-packages (0.23.1)
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (from pyudev) (1.16.0)
Requirement already satisfied: pyserial in /usr/local/lib/python3.7/dist-packages (3.5)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (2.27.1)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/lib/python3/dist-packages (from requests) (1.24.1)
Requirement already satisfied: certifi>=2017.4.17 in /usr/lib/python3/dist-packages (from requests) (2018.8.24)
Requirement already satisfied: charset-normalizer~=2.0.0; python_version >= "3" in /usr/local/lib/python3.7/dist-packages (from requests) (2.0.11)
Requirement already satisfied: idna<4,>=2.5; python_version >= "3" in /usr/lib/python3/dist-packages (from requests) (2.6)
Collecting pybluez
Using cached https://files.pythonhosted.org/packages/08/9f/e9d93b266d2d1ea988780a52a696073ba0a65df65a532165fdf6ff90d0ed/PyBluez-0.23.tar.gz
Complete output from command python setup.py egg_info:
error in PyBluez setup command: use_2to3 is invalid.
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-hednbphg/pybluez/
Collecting pillow
Using cached https://files.pythonhosted.org/packages/03/a3/f61a9a7ff7969cdef2a6e0383a346eb327495d20d25a2de5a088dbb543a6/Pillow-9.0.1.tar.gz
Building wheels for collected packages: pillow
Running setup.py bdist_wheel for pillow: started
Running setup.py bdist_wheel for pillow: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-_vzqrxqh/pillow/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-kq9lnhyn --python-tag cp37:
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for pillow
Running setup.py clean for pillow
Failed to build pillow
Installing collected packages: pillow
Running setup.py install for pillow: started
Running setup.py install for pillow: still running...
Running setup.py install for pillow: finished with status 'done'
Successfully installed pillow
Requirement already satisfied: numpy in /usr/local/lib/python3.7/dist-packages (1.21.5)
Collecting bluepy
Using cached https://files.pythonhosted.org/packages/27/91/6cfca10bee9862f93015413cf9e6a52c3081a71f1518963396a055128f8e/bluepy-1.3.0.tar.gz
Building wheels for collected packages: bluepy
Running setup.py bdist_wheel for bluepy: started
Running setup.py bdist_wheel for bluepy: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-mr35q4pk/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-tiwqduin --python-tag cp37:
/usr/local/lib/python3.7/dist-packages/setuptools/dist.py:735: UserWarning: Usage of dash-separated 'description-file' will not be supported in future versions. Please use the underscore name 'description_file' instead
% (opt, underscore_opt)
or: -c cmd --help
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Running setup.py install for bluepy: started
Running setup.py install for bluepy: finished with status 'done'
Successfully installed bluepy
/var/www/html/plugins/blea/core/class/../../resources/install_apt.sh: line 25: /tmp/jeedom/blea/dependance: No such file or directory
Cloning into 'bluepy'...
running build
running build_py
running install
Working dir is /tmp/bluepy
execute make -C ./bluepy clean
execute make -C bluepy -j1
running build
running build_py
running install_lib
copying build/lib/bluepy/blescan.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluez-src.tgz -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/uuids.json -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/sensortag.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scanner.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/get_services.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper.c -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/scan_fuzz.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/__init__.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/thingy52.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/bluepy-helper -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/btle.py -> /usr/lib/python3.7/site-packages/bluepy
copying build/lib/bluepy/Makefile -> /usr/lib/python3.7/site-packages/bluepy
running install_egg_info
running egg_info
writing bluepy.egg-info/PKG-INFO
writing dependency_links to bluepy.egg-info/dependency_links.txt
writing entry points to bluepy.egg-info/entry_points.txt
writing top-level names to bluepy.egg-info/top_level.txt
reading manifest file 'bluepy.egg-info/SOURCES.txt'
adding license file 'LICENSE.txt'
running install_scripts
Installing blescan script to /usr/bin
Installing sensortag script to /usr/bin
Installing thingy52 script to /usr/bin
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
/var/www/html/plugins/blea/core/class/../../resources/install_apt.sh: line 41: /tmp/jeedom/blea/dependance: No such file or directory
Collecting cryptography
Using cached https://files.pythonhosted.org/packages/f9/4b/1cf8e281f7ae4046a59e5e39dd7471d46db9f61bb564fddbff9084c4334f/cryptography-36.0.1.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Collecting cffi>=1.12 (from cryptography)
Using cached https://files.pythonhosted.org/packages/00/9e/92de7e1217ccc3d5f352ba21e52398372525765b2e0c4530e6eb2ba9282a/cffi-1.15.0.tar.gz
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography) (2.21)
Building wheels for collected packages: cryptography, cffi
Running setup.py bdist_wheel for cryptography: started
Running setup.py bdist_wheel for cryptography: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-d030apce/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-oxfy1cxy --python-tag cp37:
running bdist_wheel
running build
running build_py
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files found matching 'mypy.ini'
warning: no previously-included files matching '*' found under directory '.zuul.d'
warning: no previously-included files matching '*' found under directory '.zuul.playbooks'
adding license file 'LICENSE'
adding license file 'LICENSE.APACHE'
adding license file 'LICENSE.BSD'
adding license file 'LICENSE.PSF'
running build_ext
running build_rust
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation/ for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.7.3
platform: Linux-3.16.85+-aarch64-with-debian-10.4
pip: 18.1
setuptools: 60.8.2
setuptools_rust: 1.1.2
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.41.0.
Failed building wheel for cryptography
Running setup.py clean for cryptography
');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
running clean
'build/bdist.linux-aarch64' does not exist -- can't clean it
'build/scripts-3.7' does not exist -- can't clean it
removing 'build'
running clean_rust
Python: 3.7.3
pip: 18.1
setuptools: 60.8.2
To update pip, run:
Failed cleaning build dir for cryptography
Running setup.py bdist_wheel for cffi: started
Running setup.py bdist_wheel for cffi: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-d030apce/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-nt5b57o_ --python-tag cp37:
or: -c cmd --help
Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cryptography cffi
Installing collected packages: cffi, cryptography
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'done'
Running setup.py install for cryptography: started
Running setup.py install for cryptography: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-1t9qhzwu/install-record.txt --single-version-externally-managed --compile:
running install
/tmp/pip-build-env-dcbyfnsj/lib/python3.7/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
running build
running build_py
running egg_info
running build_ext
running build_rust
Python: 3.7.3
pip: 18.1
setuptools: 60.8.2
To update pip, run:
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-d030apce/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-1t9qhzwu/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-d030apce/cryptography/
/var/www/html/plugins/blea/core/class/../../resources/install_apt.sh: line 43: /tmp/jeedom/blea/dependance: No such file or directory
Collecting pycrypto
Using cached https://files.pythonhosted.org/packages/60/db/645aa9af249f059cc3a368b118de33889219e0362141e75d4eaf6f80f163/pycrypto-2.6.1.tar.gz
Building wheels for collected packages: pycrypto
Running setup.py bdist_wheel for pycrypto: started
Running setup.py bdist_wheel for pycrypto: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-unjthq89/pycrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-7_67itic --python-tag cp37:
or: -c cmd --help
Failed building wheel for pycrypto
Running setup.py clean for pycrypto
Failed to build pycrypto
Installing collected packages: pycrypto
Running setup.py install for pycrypto: started
Running setup.py install for pycrypto: finished with status 'done'
Successfully installed pycrypto
/var/www/html/plugins/blea/core/class/../../resources/install_apt.sh: line 45: /tmp/jeedom/blea/dependance: No such file or directory
*			 Installation terminée					*
rm: cannot remove '/tmp/jeedom/blea/dependance': No such file or directory
merci pour votre aide
Il faudrait chercher les messages d’erreurs donnés par le log avant de poster, amha
Par exemple pour le dépôt odroid:
désolé je n’y connais trop rien, y faut que je fasse quoi.
Dans l’outils « administration système » accessibles dans la config jeedom, tapez:
sudo python3 -m pip install wheel
il me marque ceci
Requirement already satisfied: wheel in /usr/local/lib/python2.7/dist-packages (0.37.1)
Pouvez-vous executer ces commande alors pour vérifier les versions:
python --version
pip --version
Parce qu’en fait le script des dépendances a utilisé python3, ce qu’il n’aurait pas du faire, donc je suspecte que votre version de pip soit incorrectement lié à python3.
Python 2.7.16
pour pip
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
pip 20.3.4 from /var/www/.local/lib/python2.7/site-packages/pip (python 2.7)
@Mips , il est en python 2.7 c’est ca?
saleté de serpent, comment on mets tout ça a jour
Désolé, j’ai raté les update sur ce post.
Et je me suis trompé, blea est déjà en python3 donc executez plutot ceci:
et puis relancez les dépendances (si la commande a réussi)
et montrez nous le résultat
ok je fais ça, no stress on est dimanche. merci pour ton aide
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://www.deb-multimedia.org buster InRelease
Get:4 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Err:2 https://repo.jeedom.com/odroid stable InRelease
Fetched 122 kB in 16s (7771 B/s)
0 upgraded, 0 newly installed, 0 to remove and 147 not upgraded.
0 upgraded, 0 newly installed, 3 reinstalled, 0 to remove and 147 not upgraded.
Need to get 0 B/1188 kB of archives.
Collecting pybluez
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-35wu9bqa/pybluez/
Collecting pillow
  Running setup.py bdist_wheel for pillow: still running...
  Running setup.py bdist_wheel for pillow: finished with status 'done'
  Stored in directory: /root/.cache/pip/wheels/f8/b2/44/a975e0b1e3b91506d0cbdb9d5f2c8e3e120096c1898edd4964
Successfully built pillow
Successfully installed pillow-9.0.1
Collecting bluepy
  Running setup.py bdist_wheel for bluepy: still running...
  Running setup.py bdist_wheel for bluepy: finished with status 'done'
  Stored in directory: /root/.cache/pip/wheels/b5/5b/5d/45b16a19daa4f8008c186693c9d06e7543d7a7918c3bd63da6
Successfully built bluepy
Successfully installed bluepy-1.3.0
running build
running build_py
running install
running build
running build_py
running install_lib
running egg_info
  Installing build dependencies: still running...
  Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-mtusm0gc/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-enz9t1p_ --python-tag cp37:
  running bdist_wheel
  running build
  running build_py
  running egg_info
  running build_ext
  running build_rust
      Python: 3.7.3
      pip: 18.1
      setuptools: 60.8.2
  To update pip, run:
  running clean
  removing 'build'
  running clean_rust
      Python: 3.7.3
      pip: 18.1
      setuptools: 60.8.2
  To update pip, run:
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-vnvcfp5v/install-record.txt --single-version-externally-managed --compile:
    running install
    /tmp/pip-build-env-0nts7j12/lib/python3.7/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
    running build
    running build_py
    running egg_info
    running build_ext
    running build_rust
        Python: 3.7.3
        pip: 18.1
        setuptools: 60.8.2
    To update pip, run:
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-mtusm0gc/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-vnvcfp5v/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-mtusm0gc/cryptography/
Collecting pycrypto
  Running setup.py bdist_wheel for pycrypto: still running...
  Running setup.py bdist_wheel for pycrypto: finished with status 'done'
  Stored in directory: /root/.cache/pip/wheels/27/02/5e/77a69d0c16bb63c6ed32f5386f33a2809c94bd5414a2f6c196
Successfully built pycrypto
Successfully installed pycrypto-2.6.1
[2022-02-11 12:34:17][INFO] : Début d'activation du plugin
[2022-02-11 12:34:18][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-11 12:34:33][INFO] : Launching remotes ...
[2022-02-11 12:59:24][INFO] : Début d'activation du plugin
[2022-02-11 12:59:25][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-11 12:59:38][INFO] : Launching remotes ...
[2022-02-11 13:09:51][INFO] : Launching remotes ...
[2022-02-11 13:15:24][INFO] : Launching remotes ...
[2022-02-11 14:31:24][INFO] : Début d'activation du plugin
[2022-02-11 14:31:25][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-11 14:31:25][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php  plugin_id=blea function=install callInstallFunction=1
[2022-02-12 05:28:05][INFO] : Début d'activation du plugin
[2022-02-12 05:28:06][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-12 15:28:10][INFO] : Début d'activation du plugin
[2022-02-12 15:28:11][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-13 09:43:10][INFO] : Début d'activation du plugin
[2022-02-13 09:43:11][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2022-02-13 09:43:55][INFO] : Début d'activation du plugin
[2022-02-13 09:44:12][INFO] : Info sur le démon : {"log":"blea","state":"nok","launchable":"nok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"Inconnue"}
[2022-02-13 09:45:34][INFO] : Updating remotes ...
[2022-02-13 09:45:37][INFO] : Updating files on remotes ...
[2022-02-13 09:45:46][INFO] : Launching remotes ...
[2022-02-13 09:56:01][INFO] : Début d'activation du plugin
[2022-02-13 09:56:20][INFO] : Info sur le démon : {"log":"blea","state":"nok","launchable":"nok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"Inconnue"}
[2022-02-13 09:56:54][INFO] : Updating files on remotes ...
[2022-02-13 09:56:59][INFO] : Updating remotes ...
[2022-02-13 09:57:03][INFO] : Launching remotes ...
[2022-02-13 13:13:17][INFO] : Launching remotes ...
[2022-02-13 13:34:32][INFO] : Launching remotes ...
[2022-02-13 13:49:28][INFO] : Updating files on remotes ...
[2022-02-13 13:49:35][INFO] : Updating remotes ...
[2022-02-13 14:00:50][INFO] : Début d'activation du plugin
[2022-02-13 14:01:07][INFO] : Info sur le démon : {"log":"blea","state":"nok","launchable":"nok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"Inconnue"}
[2022-02-13 14:16:30][INFO] : Launching remotes ...
[2022-02-13 14:45:40][INFO] : Lancement démon blea : sudo /usr/bin/python3 /var/www/html/plugins/blea/resources/blead/blead.py --loglevel info --device hci0 --socketport 55008 --sockethost 127.0.0.1 --callback http://127.0.0.1:80/plugins/blea/core/php/jeeBlea.php --apikey DqDIhXCHNJG0spmCPs9FiBQmlRNkbpxyQ7tk1NF6q23CTnlJYU2uicQ9SNZZhu5r --daemonname local --noseeninterval 4 --scaninterval 29 --scanmode passive --pid /tmp/jeedom/blea/deamon.pid
[2022-02-13 14:45:42][INFO] : Antenna local alive sending known devices
[2022-02-13 14:45:42][INFO] : Sending ready to daemons
[2022-02-13 14:45:42][INFO] : Launching remotes ...
[2022-02-13 14:46:36][INFO] : This is a heartbeat from antenna local
[2022-02-13 14:47:32][INFO] : This is a heartbeat from antenna local
[2022-02-13 14:48:28][INFO] : This is a heartbeat from antenna local
[2022-02-13 14:49:24][INFO] : This is a heartbeat from antenna local
[2022-02-13 14:50:20][INFO] : This is a heartbeat from antenna local
voila les logs, et sa fonctionne ou tout du moins les dependances et le demon c’est lancé et installé.
merci
Cool alors
