Je suis en HTTP et non WS.
J’ai essayé en 4G et Wifi et même résultat…
Par contre je viens de remarquer quelque chose, si je lance l’application « normalement » ça ne fonctionne pas par contre si je lance l’application suite à la réception d’une notification (via celle-ci) alors la l’application se lance… Je ne comprends vraiment rien pour le coup.
Log suite ouverture application via notification
[2022-04-15 08:19:08][INFO] : Send notification with data {"type":"DISPLAY_NOTIF","payload":{"cmdId":"1408","title":"\u2705Mode Absent","message":" Alarme activ\u00e9e","answer":null,"timeout":null,"notificationId":16500035485018,"otherAskCmdId":null,"options":[],"files":[],"time":1650003548,"id":"defaultNotif","channel":"default","index":0}}
[2022-04-15 08:19:08][DEBUG] : Send output : 2022/04/15 07:19:08 {"multicast_id":756944671091148991,"success":1,"failure":0,"canonical_ids":0,"results":[{"message_id":"0:1650003548731372%5d4eda78f9fd7ecd"}]}
[2022-04-15 08:19:15][DEBUG] : [API] HTTP Received {"method":"SET_APPSTATE","params":{"state":"background","apiKey":"2db21a08a1623b19fc92b88fe298fb95"},"jsonrpc":"2.0","id":1650003555512}
[2022-04-15 08:19:15][DEBUG] : [API] Send SET_APPSTATE -> null
[2022-04-15 08:19:21][DEBUG] : [API] HTTP Received {"method":"GET_BATTERIES","jsonrpc":"2.0","id":1650003561308,"params":{"apiKey":"2db21a08a1623b19fc92b88fe298fb95"}}
[2022-04-15 08:19:21][DEBUG] : [API] HTTP Received {"method":"GET_PLUGINS_UPDATE","jsonrpc":"2.0","id":1650003561310,"params":{"apiKey":"2db21a08a1623b19fc92b88fe298fb95"}}
[2022-04-15 08:19:21][DEBUG] : [API] HTTP Received {"method":"GET_JEEDOM_GLOBAL_HEALTH","jsonrpc":"2.0","id":1650003561309,"params":{"apiKey":"2db21a08a1623b19fc92b88fe298fb95"}}
[2022-04-15 08:19:21][DEBUG] : [API] HTTP Received {"method":"GET_JEEDOM_MESSAGES","params":{"folder":"main","apiKey":"2db21a08a1623b19fc92b88fe298fb95"},"jsonrpc":"2.0","id":1650003561310}
[2022-04-15 08:19:21][DEBUG] : [API] Send GET_JEEDOM_MESSAGES -> {"type":"SET_JEEDOM_MESSAGES","payload":{"nbMessages":"4","messages":[{"id":"2410","date":"2022-04-15 00:24:03","logicalId":"scenario::VOk8rpppdcLcbCQQGfF00s87B5pYjOkXdQM2ArhDa5gjqJTBElPQ5yjKPKg97mii","plugin":"scenario","message":"Une commande du sc\u00e9nario : [Notifications][Maison][Humidit\u00e9s] est introuvable","action":"","occurrences":null},{"id":"2411","date":"2022-04-15 00:24:03","logicalId":"scenario::RYZkwIvjyrIPbOxgP0qCQPXKuLuZlYda4E2CJpWei49JX30KkM5mPLSb3F1JxLOk","plugin":"scenario","message":"Une commande du sc\u00e9nario : [Automatisme][Salon][Test matrix LED] est introuvable","action":"","occurrences":"2"},{"id":"2412","date":"2022-04-15 00:24:03","logicalId":"scenario::lXclbB8rLbNCRT7Z0VhEJnlrl3VGv3VKEOFf7qD9SE7j0vVxWfm4HNhW26rsQtfG","plugin":"scenario","message":"Une commande du sc\u00e9nario : [Aucun][Aucun][Matrix LED] est introuvable","action":"","occurrences":"2"},{"id":"2408","date":"2022-04-14 21:41:17","logicalId":"JeedomConnect::tPXE1fHeYDDxI5dugQA0xY5qjbwm0dQ7dQXJjsJj41NMLLAMYB4GY8XWjbJXFPK3","plugin":"JeedomConnect","message":"Error with 'SET_APPSTATE' method Can't find eqLogic","action":"","occurrences":null}]}}
[2022-04-15 08:19:21][DEBUG] : [API] HTTP Received {"method":"CONNECT","params":{"deviceId":"d06c36cafc39ed7c","deviceName":"Mi 9T Pro","userHash":"yOxVqE49i0**********************","appVersion":"1.2.0","pluginRequire":"1.1.1","token":"e5humBTiS_CwIWzvrZtsDW:APA91bEkEYo5tIkySIuS-x-Y4N8E89RGQv42pEH4VFAflF8GbwrnEH3xNZV5uekh2RKlWBDh9NRKUb9XlyAwtt0tvf10zgceMS6TtxgISTBedlvIjYFaurLS7XiFp14tp2AR5fiSjXB0","platformOs":"android","polling":"1","apiKey":"2db21a08a1623b19fc92b88fe298fb95"},"jsonrpc":"2.0","id":1650003561527}
[2022-04-15 08:19:21][DEBUG] : [API] Send GET_BATTERIES -> {"type":"SET_BATTERIES","payload":[{"eqName":"Capteur Temp\u00e9rature Hygrom\u00e9trie 158d0003cb3a61","roomName":"Aucun","roomId":null,"plugin":"Xiaomihome","level":"good","battery":58,"batteryType":"1x3V CR2032","lastUpdate":"14\/04\/2022 21:13:44","lastReplace":""},{"eqName":"Capteur Temp\u00e9rature Hygrom\u00e9trie 158d0003cb5af3","roomName":"Aucun","roomId":null,"plugin":"Xiaomihome","level":"good","battery":62,"batteryType":"1x3V CR2032","lastUpdate":"14\/04\/2022 20:49:43","lastReplace":""},{"eqName":"Capteur Temp\u00e9rature Hygrom\u00e9trie 2 158d00053f5648","roomName":"Aucun","roomId":null,"plugin":"Xiaomihome","level":"warning","battery":29,"batteryType":"1x3V CR2032","lastUpdate":"13\/04\/2022 23:06:11","lastReplace":""},{"eqName":"LUMI.lumi.sensor_motion.aq2 00:15:8d:00:04:64:a4:a4","roomName":"Aucun","roomId":null,"plugin":"Zigbee","level":"good","battery":100,"batteryType":"1x3V CR2450","lastUpdate":"15\/04\/2022 00:00:11","lastReplace":61},{"eqName":"LUMI.lumi.sensor_motion.aq2 00:15:8d:00:04:87:78:a0","roomName":"Aucun","roomId":null,"plugin":"Zigbee","level":"good","battery":100,"batteryType":"1x3V CR2450","lastUpdate":"15\/04\/2022 00:00:11","lastReplace":61},{"eqName":"LUMI.lumi.weather 00:15:8d:00:06:b0:ff:e3","roomName":"Aucun","roomId":null,"plugin":"Zigbee","level":"good","battery":100,"batteryType":"1x3V CR2032","lastUpdate":"15\/04\/2022 00:00:11","lastReplace":61},{"eqName":"Hygro Buanderie","roomName":"Buanderie","roomId":"13","plugin":"Xiaomihome","level":"good","battery":52,"batteryType":"1x3V CR2032","lastUpdate":"11\/04\/2022 20:41:53","lastReplace":171},{"eqName":"Hygro chbre amis zigbee","roomName":"Chambre amis","roomId":"6","plugin":"Zigbee","level":"critical","battery":0,"batteryType":"1x3V CR2032","lastUpdate":"15\/04\/2022 07:49:46","lastReplace":0},{"eqName":"Ouverture fenetre chambre amis","roomName":"Chambre amis","roomId":"6","plugin":"Xiaomihome","level":"good","battery":62,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:54:08","lastReplace":602},{"eqName":"Hygro chambre b\u00e9b\u00e9","roomName":"Chambre b\u00e9b\u00e9","roomId":"8","plugin":"Blea","level":"good","battery":53,"batteryType":"1x1.5V AAA","lastUpdate":"15\/04\/2022 08:18:27","lastReplace":156},{"eqName":"Ouverture fenetre bebe","roomName":"Chambre b\u00e9b\u00e9","roomId":"8","plugin":"Xiaomihome","level":"good","battery":68,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:42:09","lastReplace":137},{"eqName":"Hygro Chambre MJ","roomName":"Chambre MJ","roomId":"7","plugin":"Blea","level":"good","battery":59,"batteryType":"1x1.5V AAA","lastUpdate":"15\/04\/2022 08:12:21","lastReplace":275},{"eqName":"Ouverture fenetre MJ","roomName":"Chambre MJ","roomId":"7","plugin":"Xiaomihome","level":"good","battery":68,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:49:10","lastReplace":620},{"eqName":"Hygro couloir","roomName":"Couloir","roomId":"11","plugin":"Blea","level":"warning","battery":17,"batteryType":"1x3V CR2032","lastUpdate":"15\/04\/2022 08:18:57","lastReplace":""},{"eqName":"Jos\u00e9","roomName":"Couloir","roomId":"11","plugin":"Xiaomihome","level":"good","battery":96,"batteryType":"Batterie","lastUpdate":"20\/07\/2021 17:30:04","lastReplace":271},{"eqName":"Mouvement cuisine","roomName":"Cuisine","roomId":"15","plugin":"Xiaomihome","level":"good","battery":71,"batteryType":"1x3V CR2450","lastUpdate":"15\/04\/2022 07:46:15","lastReplace":346},{"eqName":"Ouverture fenetre cuisine","roomName":"Cuisine","roomId":"15","plugin":"Xiaomihome","level":"good","battery":71,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 08:07:25","lastReplace":620},{"eqName":"Hygro garage","roomName":"Garage","roomId":"10","plugin":"Xiaomihome","level":"good","battery":55,"batteryType":"1x3V CR2032","lastUpdate":"14\/04\/2022 20:55:39","lastReplace":356},{"eqName":"La chati\u00e8re","roomName":"Garage","roomId":"10","plugin":"Surepetcare","level":"good","battery":72,"batteryType":"4x1.5V AA","lastUpdate":"15\/04\/2022 08:19:06","lastReplace":42},{"eqName":"Ouverture porte garage","roomName":"Garage","roomId":"10","plugin":"Xiaomihome","level":"good","battery":58,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:43:58","lastReplace":602},{"eqName":"Porte ext garage","roomName":"Garage","roomId":"10","plugin":"Zigbee","level":"good","battery":100,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:29:35","lastReplace":115},{"eqName":"Capteur 1","roomName":"Informations","roomId":"5","plugin":"Blea","level":"good","battery":50,"batteryType":"1x3V CR2032","lastUpdate":"15\/04\/2022 08:19:17","lastReplace":0},{"eqName":"Temp\u00e9rature TUYA","roomName":"Informations","roomId":"5","plugin":"Zigbee","level":"good","battery":100,"batteryType":"","lastUpdate":"15\/04\/2022 08:18:31","lastReplace":278},{"eqName":"D\u00e9tecteur mouvement jardin","roomName":"Jardin","roomId":"14","plugin":"Xiaomihome","level":"good","battery":58,"batteryType":"1x3V CR2450","lastUpdate":"15\/04\/2022 07:55:38","lastReplace":91},{"eqName":"Hygro Jardin","roomName":"Jardin","roomId":"14","plugin":"Xiaomihome","level":"good","battery":62,"batteryType":"1x3V CR2032","lastUpdate":"14\/04\/2022 20:55:31","lastReplace":171},{"eqName":"Portail \u00e9lectrique","roomName":"Jardin","roomId":"14","plugin":"Zigbee","level":"good","battery":100,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 06:32:26","lastReplace":121},{"eqName":"Julien_JC","roomName":"Membres","roomId":"4","plugin":"JeedomConnect","level":"good","battery":78,"batteryType":"","lastUpdate":"15\/04\/2022 08:15:01","lastReplace":1},{"eqName":"S21_ULTRA_JC","roomName":"Membres","roomId":"4","plugin":"JeedomConnect","level":"good","battery":100,"batteryType":"","lastUpdate":"15\/04\/2022 01:03:26","lastReplace":""},{"eqName":"Cam\u00e9ra salon","roomName":"Salon","roomId":"2","plugin":"Blink_camera","level":"good","battery":100,"batteryType":"","lastUpdate":"15\/04\/2022 08:19:05","lastReplace":5},{"eqName":"Hygro salon zigbee","roomName":"Salon","roomId":"2","plugin":"Zigbee","level":"good","battery":100,"batteryType":"1x3V CR2032","lastUpdate":"15\/04\/2022 07:47:31","lastReplace":137},{"eqName":"Mouvement salon","roomName":"Salon","roomId":"2","plugin":"Xiaomihome","level":"good","battery":68,"batteryType":"1x3V CR2450","lastUpdate":"15\/04\/2022 07:54:42","lastReplace":523},{"eqName":"Ouverture baie vitree D","roomName":"Salon","roomId":"2","plugin":"Xiaomihome","level":"good","battery":71,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 08:06:29","lastReplace":620},{"eqName":"Ouverture baie vitree G","roomName":"Salon","roomId":"2","plugin":"Xiaomihome","level":"good","battery":58,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:37:00","lastReplace":618},{"eqName":"Ouverture fenetre salon","roomName":"Salon","roomId":"2","plugin":"Xiaomihome","level":"good","battery":62,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 08:11:59","lastReplace":602},{"eqName":"Ouverture porte dentree","roomName":"Salon","roomId":"2","plugin":"Xiaomihome","level":"good","battery":78,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 06:32:53","lastReplace":620},{"eqName":"Mouvement WC","roomName":"WC","roomId":"12","plugin":"Xiaomihome","level":"good","battery":75,"batteryType":"1x3V CR2450","lastUpdate":"15\/04\/2022 07:29:26","lastReplace":674},{"eqName":"Ouverture WC","roomName":"WC","roomId":"12","plugin":"Xiaomihome","level":"good","battery":68,"batteryType":"1x3V CR1632","lastUpdate":"15\/04\/2022 07:53:19","lastReplace":524}]}
[2022-04-15 08:19:22][DEBUG] : [API] Send GET_PLUGINS_UPDATE -> {"type":"SET_PLUGINS_UPDATE","payload":{"nbUpdate":"0","pluginsToUpdate":[],"otherPlugins":[{"pluginId":"calendar","name":"Agenda","img":"plugins\/calendar\/plugin_info\/calendar_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/calendar\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/calendar\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-12-03 01:14:32","updateVersion":"2021-12-03 01:14:32","isActive":true,"logFiles":[]},{"pluginId":"alarm","name":"Alarme","img":"plugins\/alarm\/plugin_info\/alarm_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/security\/alarm\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/security\/alarm\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-05-11 16:48:17","updateVersion":"2020-05-11 16:48:17","isActive":true,"logFiles":["alarm"]},{"pluginId":"ash","name":"Alexa","img":"plugins\/ash\/plugin_info\/ash_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/ash\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/ash\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-09-28 01:04:00","updateVersion":"2021-09-28 01:04:00","isActive":true,"logFiles":["ash"]},{"pluginId":"alexaapi","name":"Alexa - API","img":"plugins\/alexaapi\/plugin_info\/alexaapi_icon.png","changelogLink":"http:\/\/jeedom.sigalou-domotique.fr\/alexa-api-changelog","docLink":"http:\/\/jeedom.sigalou-domotique.fr\/alexa-api-documentation","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-11-27 10:11:28","updateVersion":"2021-11-27 10:11:28","isActive":true,"logFiles":["alexaapi","alexaapi_cookie","alexaapi_dep","alexaapi_node"]},{"pluginId":"blink_camera","name":"Blink Camera","img":"plugins\/blink_camera\/plugin_info\/blink_camera_icon.png","changelogLink":"https:\/\/d9-197.github.io\/blink_camera\/fr_FR\/changelog","docLink":"https:\/\/d9-197.github.io\/blink_camera\/fr_FR","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-04-06 17:11:01","updateVersion":"2022-04-06 17:11:01","isActive":true,"logFiles":["blink_camera"]},{"pluginId":"blea","name":"Bluetooth Advertisement","img":"plugins\/blea\/plugin_info\/blea_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/automation protocol\/blea\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/automation protocol\/blea\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-04-06 16:26:29","updateVersion":"2021-04-06 16:26:29","isActive":true,"logFiles":["blea","blea_UD100"]},{"pluginId":"camera","name":"Cam\u00e9ra","img":"plugins\/camera\/plugin_info\/camera_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/security\/camera\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/security\/camera\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-02-11 01:17:03","updateVersion":"2022-02-11 01:17:03","isActive":true,"logFiles":["camera","camera_record","camera_update"]},{"pluginId":"cloudsyncpro","name":"CloudSync Pro","img":"plugins\/cloudsyncpro\/plugin_info\/cloudsyncpro_icon.png","changelogLink":"https:\/\/thanaus.github.io\/jeedom_docs\/plugins\/cloudsyncpro\/fr_FR\/changelog","docLink":"https:\/\/thanaus.github.io\/jeedom_docs\/plugins\/cloudsyncpro\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-04-06 03:14:16","updateVersion":"2020-04-06 03:14:16","isActive":true,"logFiles":["cloudsyncpro","cloudsyncpro.#1251","cloudsyncpro.#1254","cloudsyncpro.#1260","cloudsyncpro.#1261","cloudsyncpro.#1288","cloudsyncpro.#303","cloudsyncpro.#304","cloudsyncpro.#305"]},{"pluginId":"datatransfert","name":"Data Transfert","img":"plugins\/datatransfert\/doc\/images\/datatransfert_icon.png","changelogLink":"https:\/\/github.com\/fensoft\/plugin-datatransfert\/commits\/master","docLink":"https:\/\/github.com\/fensoft\/plugin-datatransfert\/blob\/master\/doc\/fr_FR\/index.asciidoc","doNotUpdate":false,"pluginType":"stable","currentVersion":"2018-04-18 15:01:30","updateVersion":"2018-04-18 15:01:30","isActive":true,"logFiles":["datatransfert_update"]},{"pluginId":"discordlink","name":"Discord Link","img":"plugins\/discordlink\/plugin_info\/discordlink_icon.png","changelogLink":"https:\/\/domotechdiscord.github.io\/Docs\/discordlink\/fr_FR\/changelog","docLink":"https:\/\/domotechdiscord.github.io\/Docs\/discordlink\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-02-16 01:03:48","updateVersion":"2022-02-16 01:03:48","isActive":true,"logFiles":["discordlink","discordlink_dep","discordlink_node"]},{"pluginId":"Djeesign","name":"Djeesign","img":"plugins\/Djeesign\/plugin_info\/Djeesign_icon.png","changelogLink":"https:\/\/github.com\/PhilippeJ-code\/Djeesign\/blob\/master\/docs\/fr_FR\/changelog.md","docLink":"https:\/\/github.com\/PhilippeJ-code\/Djeesign\/blob\/master\/docs\/fr_FR\/index.md","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-03-16 11:51:35","updateVersion":"2021-03-16 11:51:35","isActive":true,"logFiles":[]},{"pluginId":"domogeek","name":"DomoGeek","img":"plugins\/domogeek\/plugin_info\/domogeek_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/domogeek\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/domogeek\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-02-23 01:14:47","updateVersion":"2022-02-23 01:14:47","isActive":true,"logFiles":[]},{"pluginId":"dyndns","name":"Dyndns","img":"plugins\/dyndns\/plugin_info\/dyndns_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/dyndns\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/dyndns\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-08-06 01:14:38","updateVersion":"2021-08-06 01:14:38","isActive":true,"logFiles":["dyndns"]},{"pluginId":"phone_detection","name":"D\u00e9tection de t\u00e9l\u00e9phone (Bluetooth)","img":"plugins\/phone_detection\/plugin_info\/phone_detection_icon.png","changelogLink":"https:\/\/github.com\/sebmafate\/phone_detection\/changelog","docLink":"https:\/\/github.com\/sebmafate\/phone_detection\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-10-19 01:15:52","updateVersion":"2021-10-19 01:15:52","isActive":true,"logFiles":["phone_detection"]},{"pluginId":"enedis","name":"Enedis","img":"plugins\/enedis\/plugin_info\/enedis_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/energy\/enedis\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/energy\/enedis","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-04-01 01:08:34","updateVersion":"2022-04-01 01:08:34","isActive":true,"logFiles":["enedis","enedis_update"]},{"pluginId":"espeasy","name":"ESPeasy","img":"plugins\/espeasy\/plugin_info\/espeasy_icon.png","changelogLink":"https:\/\/lunarok.github.io\/jeedom_docs\/plugins\/espeasy\/changelog.html","docLink":"https:\/\/lunarok.github.io\/jeedom_docs\/plugins\/espeasy\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-11-29 01:00:39","updateVersion":"2021-11-29 01:00:39","isActive":true,"logFiles":["espeasy","espeasy_dep","espeasy_node"]},{"pluginId":"Freebox_OS","name":"Freebox","img":"plugins\/Freebox_OS\/plugin_info\/freebox_os_icon.png","changelogLink":"https:\/\/mika-nt28.github.io\/Documentations\/Freebox_OS\/fr_FR\/changelog","docLink":"http:\/\/mika-nt28.github.io\/Documentations\/Freebox_OS\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-03-17 01:10:09","updateVersion":"2022-03-17 01:10:09","isActive":true,"logFiles":["Freebox_OS"]},{"pluginId":"geoloc","name":"Geoloc","img":"plugins\/geoloc\/plugin_info\/geoloc_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/geoloc\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/geoloc\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-11-25 01:13:26","updateVersion":"2020-11-25 01:13:26","isActive":true,"logFiles":[]},{"pluginId":"groupe","name":"Groupe","img":"plugins\/groupe\/plugin_info\/groupe_icon.png","changelogLink":"https:\/\/zyg0m4t1k.github.io\/groupe\/fr_FR\/changelog","docLink":"https:\/\/zyg0m4t1k.github.io\/groupe\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-02-18 01:08:02","updateVersion":"2021-02-18 01:08:02","isActive":true,"logFiles":[]},{"pluginId":"htmldisplay","name":"HTML Display","img":"plugins\/htmldisplay\/plugin_info\/htmldisplay_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/htmldisplay\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/htmldisplay\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-09-22 01:15:31","updateVersion":"2021-09-22 01:15:31","isActive":true,"logFiles":[]},{"pluginId":"icon","name":"Ic\u00f4nes","img":"plugins\/icon\/plugin_info\/icon_icon.png","changelogLink":"https:\/\/zyg0m4t1k.github.io\/icon\/fr_FR\/changelog","docLink":"https:\/\/zyg0m4t1k.github.io\/icon\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-02-19 01:13:16","updateVersion":"2021-02-19 01:13:16","isActive":true,"logFiles":[]},{"pluginId":"JeedomConnect","name":"Jeedom Connect","img":"plugins\/JeedomConnect\/plugin_info\/JeedomConnect_icon.png","changelogLink":"https:\/\/jared-94.github.io\/JeedomConnectDoc\/fr_FR\/changelog_beta","docLink":"https:\/\/jared-94.github.io\/JeedomConnectDoc\/fr_FR\/index_beta","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-04-12 15:13:16","updateVersion":"2022-04-12 15:13:16","isActive":true,"logFiles":["JeedomConnect"]},{"pluginId":"jeedouino","name":"Jeedouino","img":"plugins\/jeedouino\/plugin_info\/jeedouino_icon.png","changelogLink":"https:\/\/revlysj.github.io\/jeedouino\/fr_FR\/changelog","docLink":"https:\/\/revlysj.github.io\/jeedouino\/fr_FR\/index","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-01-07 01:01:05","updateVersion":"2022-01-07 01:01:05","isActive":true,"logFiles":[]},{"pluginId":"jeexplorer","name":"JeeXplorer","img":"plugins\/jeexplorer\/plugin_info\/jeexplorer_icon.png","changelogLink":"https:\/\/kiboost.github.io\/jeedom_docs\/plugins\/jeexplorer\/fr_FR\/changelog.html","docLink":"https:\/\/kiboost.github.io\/jeedom_docs\/plugins\/jeexplorer\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-04-12 12:44:31","updateVersion":"2021-04-12 12:44:31","isActive":true,"logFiles":[]},{"pluginId":"mail","name":"Mail","img":"plugins\/mail\/plugin_info\/mail_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/mail\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/mail\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-11-20 01:04:00","updateVersion":"2020-11-20 01:04:00","isActive":true,"logFiles":[]},{"pluginId":"mode","name":"Mode","img":"plugins\/mode\/plugin_info\/mode_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/mode\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/organization\/mode\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-12-13 01:15:01","updateVersion":"2021-12-13 01:15:01","isActive":true,"logFiles":[]},{"pluginId":"Monitoring","name":"Monitoring","img":"plugins\/Monitoring\/plugin_info\/Monitoring_icon.png","changelogLink":"https:\/\/surveillancestation.github.io\/surveillancestation\/monitoring\/fr_FR\/#tocAnchor-1-10","docLink":"https:\/\/surveillancestation.github.io\/surveillancestation\/monitoring\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-02-16 01:08:52","updateVersion":"2021-02-16 01:08:52","isActive":true,"logFiles":[]},{"pluginId":"networks","name":"Network","img":"plugins\/networks\/plugin_info\/networks_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/networks\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/networks\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-06-09 09:21:26","updateVersion":"2021-06-09 09:21:26","isActive":true,"logFiles":["networks_update"]},{"pluginId":"SmartLife","name":"Objets SmartLife\/Tuya","img":"plugins\/SmartLife\/plugin_info\/SmartLife_icon.png","changelogLink":"https:\/\/sabinus52.github.io\/jeedom-smartlife\/fr_FR\/changelog","docLink":"https:\/\/sabinus52.github.io\/jeedom-smartlife\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-04-03 01:07:27","updateVersion":"2022-04-03 01:07:27","isActive":true,"logFiles":["SmartLife"]},{"pluginId":"openvpn","name":"Openvpn","img":"plugins\/openvpn\/plugin_info\/openvpn_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/openvpn\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/communication\/openvpn\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-02-16 01:05:09","updateVersion":"2021-02-16 01:05:09","isActive":true,"logFiles":["openvpn_DNS_Jeedom","openvpn_update"]},{"pluginId":"pool","name":"Piscine","img":"plugins\/pool\/plugin_info\/pool_icon.png","changelogLink":"https:\/\/scadinot.github.io\/pool\/fr_FR\/changelog","docLink":"https:\/\/scadinot.github.io\/pool\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-04-05 15:56:16","updateVersion":"2020-04-05 15:56:16","isActive":true,"logFiles":["pool"]},{"pluginId":"script","name":"Script","img":"plugins\/script\/plugin_info\/script_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/script\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/script\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-06-24 09:18:07","updateVersion":"2020-06-24 09:18:07","isActive":true,"logFiles":["script"]},{"pluginId":"simupre","name":"Simulation pr\u00e9sence","img":"plugins\/simupre\/plugin_info\/simupre_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/simupre\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/simupre\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-08-18 01:12:29","updateVersion":"2020-08-18 01:12:29","isActive":true,"logFiles":[]},{"pluginId":"surepetcare","name":"Sure PetCare","img":"plugins\/surepetcare\/plugin_info\/surepetcare_icon.png","changelogLink":"https:\/\/jmvedrine.github.io\/jeedom-surepetcare\/fr_FR\/changelog","docLink":"https:\/\/jmvedrine.github.io\/jeedom-surepetcare\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-03-31 00:33:54","updateVersion":"2022-03-31 00:33:54","isActive":true,"logFiles":["surepetcare"]},{"pluginId":"thermostat","name":"Thermostat","img":"plugins\/thermostat\/plugin_info\/thermostat_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/wellness\/thermostat\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/wellness\/thermostat\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-11-23 01:17:27","updateVersion":"2020-11-23 01:17:27","isActive":true,"logFiles":["thermostat"]},{"pluginId":"virtual","name":"Virtuel","img":"plugins\/virtual\/plugin_info\/virtual_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/virtual\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/programming\/virtual\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-01-31 01:16:25","updateVersion":"2022-01-31 01:16:25","isActive":true,"logFiles":[]},{"pluginId":"watchdog","name":"Watchdog","img":"plugins\/watchdog\/plugin_info\/watchdog_icon.png","changelogLink":"http:\/\/jeedom.sigalou-domotique.fr\/watchdog-changelog","docLink":"http:\/\/jeedom.sigalou-domotique.fr\/watchdog-documentation","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-03-20 01:09:51","updateVersion":"2021-03-20 01:09:51","isActive":true,"logFiles":[]},{"pluginId":"weather","name":"Weather","img":"plugins\/weather\/plugin_info\/weather_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/weather\/weather\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/weather\/weather\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2020-11-12 01:15:44","updateVersion":"2020-11-12 01:15:44","isActive":true,"logFiles":[]},{"pluginId":"wifilightV2","name":"wifilightV2","img":"plugins\/wifilightV2\/plugin_info\/wifilightV2_icon.png","changelogLink":"https:\/\/bcaro.github.io\/wifilightV2-doc\/fr_FR\/changelog","docLink":"https:\/\/bcaro.github.io\/wifilightV2-doc\/fr_FR\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-04-13 07:46:01","updateVersion":"2022-04-13 07:46:01","isActive":true,"logFiles":["wifilightV2","wifilightV2_update"]},{"pluginId":"wled","name":"WLED","img":"plugins\/wled\/plugin_info\/wled_icon.png","changelogLink":"https:\/\/jmvedrine.github.io\/jeedom-wled\/fr_FR\/changelog","docLink":"https:\/\/jmvedrine.github.io\/jeedom-wled\/fr_FR\/","doNotUpdate":false,"pluginType":"beta","currentVersion":"2022-02-20 01:07:31","updateVersion":"2022-02-20 01:07:31","isActive":true,"logFiles":["wled"]},{"pluginId":"xiaomihome","name":"Xiaomi Home","img":"plugins\/xiaomihome\/plugin_info\/xiaomihome_icon.png","changelogLink":"https:\/\/lunarok.github.io\/jeedom_docs\/plugins\/xiaomihome\/changelog.html","docLink":"https:\/\/lunarok.github.io\/jeedom_docs\/plugins\/xiaomihome\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2021-07-27 18:34:51","updateVersion":"2021-07-27 18:34:51","isActive":true,"logFiles":["xiaomihome","xiaomihome_dep"]},{"pluginId":"zigbee","name":"Zigbee","img":"plugins\/zigbee\/plugin_info\/zigbee_icon.png","changelogLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/automation protocol\/zigbee\/changelog","docLink":"https:\/\/doc.jeedom.com\/fr_FR\/plugins\/automation protocol\/zigbee\/","doNotUpdate":false,"pluginType":"stable","currentVersion":"2022-03-31 18:13:57","updateVersion":"2022-03-31 18:13:57","isActive":true,"logFiles":["zigbee","zigbee_packages","zigbee_update","zigbeed_1"]}]}}
Configuration JC
