La dernière version beta dit qu’il faut reinstaller les dépendances mais impossible.
Il time-out à 9%.
Ai toutes les dernières versions.
Essayé sur deux installations avec memes symptômes.
Voici le log qui indique que tout s’est bien passé…
+ touch /tmp/jeedom_install_in_progress_zigbee
+ echo 1
+ echo 2
+ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian-security buster/updates InRelease
Hit:4 http://deb.debian.org/debian buster-updates InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
14 packages can be upgraded. Run 'apt list --upgradable' to see them.
+ echo 3
+ sudo pip3 install --upgrade zigpy
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: zigpy in /usr/local/lib/python3.7/dist-packages (0.37.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.17.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.10.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.1)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.10.0.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (21.2.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (5.1.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (1.6.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (2.6)
+ echo 4
+ sudo pip3 install --upgrade zha-quirks
Requirement already up-to-date: zha-quirks in /usr/local/lib/python3.7/dist-packages (0.0.60)
Requirement already satisfied, skipping upgrade: zigpy>=0.32.0 in /usr/local/lib/python3.7/dist-packages (from zha-quirks) (0.37.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.32.0->zha-quirks) (0.12.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.32.0->zha-quirks) (3.10.0.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (3.0.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (21.2.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.32.0->zha-quirks) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.32.0->zha-quirks) (2.6)
+ echo 5
+ sudo pip3 install --upgrade zigpy-znp
Requirement already up-to-date: zigpy-znp in /usr/local/lib/python3.7/dist-packages (0.5.4)
Requirement already satisfied, skipping upgrade: zigpy>=0.37.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (0.37.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (0.12.1)
Requirement already satisfied, skipping upgrade: async-timeout in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (3.0.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio; platform_system != "Windows" in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (0.5)
Requirement already satisfied, skipping upgrade: jsonschema in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (3.2.0)
Requirement already satisfied, skipping upgrade: coloredlogs in /usr/local/lib/python3.7/dist-packages (from zigpy-znp) (15.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-znp) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-znp) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-znp) (0.17.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-znp) (3.10.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio; platform_system != "Windows"->zigpy-znp) (3.4)
Requirement already satisfied, skipping upgrade: pyrsistent>=0.14.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (0.17.3)
Requirement already satisfied, skipping upgrade: attrs>=17.4.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (21.2.0)
Requirement already satisfied, skipping upgrade: six>=1.11.0 in /usr/lib/python3/dist-packages (from jsonschema->zigpy-znp) (1.12.0)
Requirement already satisfied, skipping upgrade: setuptools in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (56.2.0)
Requirement already satisfied, skipping upgrade: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy-znp) (4.0.1)
Requirement already satisfied, skipping upgrade: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->zigpy-znp) (9.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-znp) (5.1.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-znp) (3.0.4)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-znp) (3.10.0.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-znp) (1.6.3)
Requirement already satisfied, skipping upgrade: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->jsonschema->zigpy-znp) (3.4.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.37.0->zigpy-znp) (2.6)
+ echo 6
+ sudo pip3 install --upgrade zigpy-xbee
Requirement already up-to-date: zigpy-xbee in /usr/local/lib/python3.7/dist-packages (0.14.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.5)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.37.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-xbee) (3.4)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.12.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.10.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.0->zigpy-xbee) (3.10.0.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (5.1.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (21.2.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.0->zigpy-xbee) (2.6)
+ echo 7
+ sudo pip3 install --upgrade zigpy-deconz
Requirement already up-to-date: zigpy-deconz in /usr/local/lib/python3.7/dist-packages (0.13.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.37.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.37.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.5)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-deconz) (0.17.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-deconz) (1.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-deconz) (0.12.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-deconz) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->zigpy-deconz) (3.10.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-deconz) (3.4)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.37.0->zigpy-deconz) (3.10.0.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-deconz) (21.2.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-deconz) (3.0.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-deconz) (5.1.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-deconz) (1.6.3)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.37.0->zigpy-deconz) (3.0.4)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.37.0->zigpy-deconz) (2.6)
+ echo 8
+ sudo pip3 install --upgrade zigpy-zigate
Requirement already up-to-date: zigpy-zigate in /usr/local/lib/python3.7/dist-packages (0.7.4)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.5)
Requirement already satisfied, skipping upgrade: RPi.GPIO in /usr/lib/python3/dist-packages (from zigpy-zigate) (0.7.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.22.2 in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.37.1)
Requirement already satisfied, skipping upgrade: pyusb in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (1.1.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-zigate) (3.4)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (1.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.12.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.22.2->zigpy-zigate) (3.10.0.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (5.1.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (21.2.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.4)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.2->zigpy-zigate) (2.6)
+ echo 9
+ sudo pip3 install --upgrade bellows
Requirement already up-to-date: bellows in /usr/local/lib/python3.7/dist-packages (0.27.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from bellows) (3.4)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from bellows) (0.5)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from bellows) (0.12.1)
Requirement already satisfied, skipping upgrade: pure-pcapy3==1.0.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (1.0.1)
Requirement already satisfied, skipping upgrade: click-log>=0.2.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.3.2)
Requirement already satisfied, skipping upgrade: click in /usr/lib/python3/dist-packages (from bellows) (7.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.37.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.37.1)
Requirement already satisfied, skipping upgrade: setuptools in /usr/local/lib/python3.7/dist-packages (from pure-pcapy3==1.0.1->bellows) (56.2.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (0.17.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (1.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.37.0->bellows) (3.10.0.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.0.4)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (1.6.3)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (21.2.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.37.0->bellows) (2.6)
+ echo 10
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch install of zigbee dependancy
Everything is successfully installed!
+ echo 11
+ rm /tmp/jeedom_install_in_progress_zigbee
