Bonjour à tous
Je suis sous Raspi 3B_Buster à jour et Jeedom V4 Alpha
je pensais que le plugin fonctionner correctement et je voulais relancer un scan.
Mais impossible de cliquer sur aucun des boutons donc je l’ai désinstaller et réinstaller complètement mais depuis plus rien !
Sur la page de configuration tous à l’air Ok , y compris l’installe des dépendances.
Je ne comprends pas, un peu d’aide serait la bienvenue.
Launch install of googlecast dependancies
-- Current OS version :
Description: Raspbian GNU/Linux 10 (buster)
-- Updating repo...
Get:1 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Fetched 25.1 kB in 2s (14.2 kB/s)
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 72 not upgraded.
-- Installed version of Python :
Python 3.7.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python-requests is already the newest version (2.21.0-1).
python3-dev is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5+rpt1).
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-1).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-3).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.1.4-1+rpt7~deb10u1).
-- Upgrade setuptools with command pip3 if not up to date
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.7/dist-packages (46.1.3)
-- Installed version of pip :
pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
-- Installation of python library 'requests' with command pip3
Requirement already satisfied: requests>=2.21.0 in /usr/lib/python3/dist-packages (2.21.0)
-- Installation of python library 'protobuf' with command pip3
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/dist-packages (3.11.3)
Requirement already satisfied: setuptools in /usr/local/lib/python3.7/dist-packages (from protobuf>=3.11.0) (46.1.3)
Requirement already satisfied: six>=1.9 in /usr/lib/python3/dist-packages (from protobuf>=3.11.0) (1.12.0)
-- Installation of python library 'zeroconf' with command pip3
Requirement already satisfied: zeroconf<0.24.4,>=0.22.0 in /usr/local/lib/python3.7/dist-packages (0.23.0)
Requirement already satisfied: ifaddr in /usr/local/lib/python3.7/dist-packages (from zeroconf<0.24.4,>=0.22.0) (0.1.6)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3
Requirement already satisfied: click in /usr/lib/python3/dist-packages (7.0)
Requirement already satisfied: bs4 in /usr/local/lib/python3.7/dist-packages (0.0.1)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (1.12.0)
Requirement already satisfied: beautifulsoup4 in /usr/lib/python3/dist-packages (from bs4) (4.7.1)
-- Installation of python library 'tqdm, websocket-client' for plex with command pip3
Requirement already satisfied: tqdm in /usr/local/lib/python3.7/dist-packages (4.36.1)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/dist-packages (0.56.0)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from websocket-client) (1.12.0)
-- Installation of dependencies is done !
le log remonte bien et même me signale qu’il y des nouveaux appareils détecter
Date et heure Source Description Action Occurrences
2020-05-22 04:51:09 Google Cast Un nouveau GoogleCast (Maison) existe sur le réseau ! Vous pouvez lancer un scan via le plugin pour l'ajouter. Lancer un scan 3
2020-05-22 04:51:09 Google Cast Un nouveau GoogleCast (Chromecast) existe sur le réseau ! Vous pouvez lancer un scan via le plugin pour l'ajouter. Lancer un scan 3
2020-05-22 04:51:09 Google Cast Un nouveau GoogleCast (Mini Nest) existe sur le réseau ! Vous pouvez lancer un scan via le plugin pour l'ajouter. Lancer un scan 3
2020-05-22 04:51:09 Google Cast Un nouveau GoogleCast (Ghome) existe sur le réseau ! Vous pouvez lancer un scan via le plugin pour l'ajouter. Lancer un scan 3
2020-05-22 04:51:09 Google Cast Un nouveau GoogleCast (Étage) existe sur le réseau ! Vous pouvez lancer un scan via le plugin pour l'ajouter. Lancer un scan 3```
