Ce matin, je n’ai plus de message d’Alexa.
Je vérifie les paramètres du plugin, tout est ok.
Je relance le démon, c’est ok mais sans effet.
J’essaie de regénérer le cookie et là ça ne passe pas avec ce message :
Ce site est inaccessible
169.254.212.45 a mis trop de temps à répondre…
Voici les logs :
Alexa-Remote: No cookie given, generate one
Alexa-Cookie: Use as Login-Amazon-URL: amazon.fr
Alexa-Config (alexa-cookie.js): amazonserver=amazon.fr
Alexa-Config (alexa-cookie.js): alexaserver=alexa.amazon.fr
Alexa-Cookie: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
Alexa-Cookie: Use as Accept-Language: fr-FR
Alexa-Cookie: Proxy mode disabled
[HPM] Proxy created: !/cookie-success → https://alexa.amazon.com
[HPM] Proxy rewrite rule created: « ^/www.amazon.com » ~> ""
[HPM] Proxy rewrite rule created: « ^/alexa…amazon.com » ~> ""
events.js:288
throw er; // Unhandled ‹ error › event
Error: listen EADDRINUSE: address already in use :::3457
at Server.setupListenHandle [as _listen2] (net.js:1309:16)
at listenInCluster (net.js:1357:12)
at Server.listen (net.js:1445:7)
at Function.listen (/var/www/html/plugins/alexaapi/resources/node_modules/express/lib/application.js:618:24)
at Object.initAmazonProxy (/var/www/html/plugins/alexaapi/resources/lib/proxy.js:302:22)
at Object.generateAlexaCookie (/var/www/html/plugins/alexaapi/resources/lib/alexa-cookie.js:346:21)
at AlexaRemote.generateCookie (/var/www/html/plugins/alexaapi/resources/lib/alexa-remote.js:782:26)
at getCookie (/var/www/html/plugins/alexaapi/resources/lib/alexa-remote.js:139:22)
at AlexaRemote.init (/var/www/html/plugins/alexaapi/resources/lib/alexa-remote.js:181:9)
at Object. (/var/www/html/plugins/alexaapi/resources/initCookie.js:11:7)
Emitted ‹ error › event on Server instance at:
at emitErrorNT (net.js:1336:8)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
code: ‹ EADDRINUSE ›,
errno: ‹ EADDRINUSE ›,
syscall: ‹ listen ›,
address: ‹ :: ›,
port: 3457
Merci pour votre aide.
J’ai de nombreux scénarios et je voudrais éviter de supprimer et réinstaller le plugin.
J’ai relancé les dépendances, réparer le Nodejs, ça bloque toujours pour le cookie.
Je suis avec la dernière version stable du plugin et en V4 sur Jeedom.
