Bonjour, homebridge ne fonctionne plus depuis que j’ai changé le nom d’utilisateur ou fait un reboot. Je ne sais pas si c’est lié. Depuis j’ai le message :
http://192.168.1.64 Attention : Votre adresse interne ne réponds pas à Homebridge (Configuration > Réseau). Homebridge ne fonctionnera pas.
J’ai redémarrer, désinstallé, réinstallé. Rien ne change. L’adresse Ip est pourtant bonne. Voici mes Logs :
[2/26/2022, 9:08:20 AM] Loaded config.json with 0 accessories and 2 platforms.
[2/26/2022, 9:08:20 AM] —
[2/26/2022, 9:08:21 AM] Loaded plugin: @nebz/homebridge-jeedom@v1.5.0
[2/26/2022, 9:08:23 AM] Registering platform ‹ @nebz/homebridge-jeedom.Jeedom ›
[2/26/2022, 9:08:23 AM] —
[2/26/2022, 9:08:24 AM] Loaded plugin: homebridge-alexa@0.5.55
[2/26/2022, 9:08:24 AM] Registering platform ‹ homebridge-alexa.Alexa ›
[2/26/2022, 9:08:24 AM] —
[2/26/2022, 9:08:25 AM] Loaded plugin: homebridge-camera-ffmpeg@3.1.4
[2/26/2022, 9:08:25 AM] Registering platform ‹ homebridge-camera-ffmpeg.Camera-ffmpeg ›
[2/26/2022, 9:08:25 AM] —
[2/26/2022, 9:08:25 AM] Loaded plugin: homebridge-config-ui-x@4.42.0
[2/26/2022, 9:08:25 AM] Registering platform ‹ homebridge-config-ui-x.config ›
[2/26/2022, 9:08:25 AM] Loaded plugin: homebridge-gsh@2.2.0
[2/26/2022, 9:08:25 AM] Registering platform ‹ homebridge-gsh.google-smarthome ›
[2/26/2022, 9:08:25 AM] Loading 2 platforms…
[2/26/2022, 9:08:25 AM] [Jeedom] Initializing Jeedom platform…
[2/26/2022, 9:08:25 AM] [Jeedom] debugLevel:100
[2/26/2022, 9:08:25 AM] [Jeedom] [INFO] Adresse Jeedom bien configurée :http://192.168.1.64
[2/26/2022, 9:08:25 AM] [Config] Initializing config platform…
[2/26/2022, 9:08:25 AM] [Config] Spawning homebridge-config-ui-x with PID 26547
[2/26/2022, 9:08:25 AM] [Jeedom] Synchronisation Jeedom <> Homebridge…
Setup Payload:
X-HM://0023ISYWYDB5C
Enter this code with your HomeKit app on your iOS device to pair with Homebridge:
│ 031-45-154 │
[2/26/2022, 9:08:25 AM] Homebridge v1.4.0 (HAP v0.10.0) (Jeedom) is running on port 51826.
[2/26/2022, 9:08:25 AM] [Jeedom] [ERROR] #2 Erreur de récupération des données Jeedom: {
code: 1,
message: « Vous n’êtes pas autorisé à effectuer cette action »
undefined
e[0;37m[2/26/2022, 9:08:30 AM] e[0me[0;36m[Homebridge UI]e[0m e[0;33mHomebridge Config UI X v4.42.0 is listening on :: port 33221e[0m
e[0;37m[2/26/2022, 9:08:30 AM] e[0me[0;36m[Homebridge UI]e[0m e[0;33mAdded new user: admine[0m
e[0;37m[2/26/2022, 9:08:30 AM] e[0me[0;36m[Homebridge UI]e[0m Username and password have been set to default:
e[0;37m[2/26/2022, 9:08:30 AM] e[0me[0;36m[Homebridge UI]e[0m Username: admin
e[0;37m[2/26/2022, 9:08:30 AM] e[0me[0;36m[Homebridge UI]e[0m Password: admin
[2022-02-26 09:05:32][ERROR] : {{Attention : Votre adresse interne ne réponds pas à Homebridge (Configuration > Réseau). Homebridge ne fonctionnera pas.}}
[2022-02-26 09:05:47][INFO] : FFMPEG for Homebridge existe, on l’utilise
[2022-02-26 09:05:48][WARNING] : gpu_mem dans /boot/config.txt doit être à min 128, modifiez et rebootez
[2022-02-26 09:05:48][INFO] : Liste des plugins globaux
[2022-02-26 09:05:48][INFO] : installé : homebridge-alexa @ 0.5.55 - Control your Homebridge devices with Amazon Alexa.
[2022-02-26 09:05:48][INFO] : installé : homebridge-camera-ffmpeg @ 3.1.4 - Homebridge Plugin Providing FFmpeg-based Camera Support
[2022-02-26 09:05:48][INFO] : installé : homebridge-config-ui-x @ 4.42.0 - A web based management, configuration and control platform for Homebridge
[2022-02-26 09:05:48][INFO] : installé : homebridge-gsh @ 2.2.0 - Google Smart Home
[2022-02-26 09:06:26][ERROR] : {{Attention : Votre adresse interne ne réponds pas à Homebridge (Configuration > Réseau). Homebridge ne fonctionnera pas.}}
[2022-02-26 09:07:40][ERROR] : {{Attention : Votre adresse interne ne réponds pas à Homebridge (Configuration > Réseau). Homebridge ne fonctionnera pas.}}
[2022-02-26 09:08:18][INFO] : Mode debug :
[2022-02-26 09:08:19][INFO] : Génération du fichier config.json de Homebridge
[2022-02-26 09:08:19][DEBUG] : CMD=export AVAHI_COMPAT_NOWARN=1; /var/www/html/plugins/homebridge/core/class/…/…/resources/node_modules/homebridge/bin/homebridge -I --no-qrcode -U /var/www/html/plugins/homebridge/core/class/…/…/resources/homebridge >> /var/www/html/core/class/…/…/log/homebridge_daemon 2>&1 &
[2022-02-26 09:08:20][INFO] : Démon homebridge lancé
Merci pour votre aide.
