Homebridge Failed to check registry.npmjs.org
J’utilise Jeedom et Homebridge depuis un certain temps sans soucis mais ce soir, je n’arrive plus à accéder sur mon google nest à mes accessoires. Voici mes logs :
[2/8/2021, 9:41:13 PM] [Homebridge UI] [homebridge-ring] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:53 PM] [Homebridge UI] [homebridge] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:53 PM] [Homebridge UI] [homebridge] c.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:58 PM] [Homebridge UI] [homebridge-alexa] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:58 PM] [Homebridge UI] [homebridge-camera-ffmpeg] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:58 PM] [Homebridge UI] [homebridge-config-ui-x] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:58 PM] [Homebridge UI] [homebridge-gsh] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
[2/8/2021, 9:51:58 PM] [Homebridge UI] [homebridge-ring] Failed to check registry.npmjs.org for updates: "timeout of 5000ms exceeded" - see https://git.io/JJSz6 for help.
Avez vous une idée du soucis ? car je n’ai rien changer.
D’avance merci
Hello.
As tu regardé le lien proposé dans le message d’erreur ?
