Voilà quelques mois que je ne m’inquiétais plus du fonctionnement du module, et je constate qu’il ne fonctionne plus.
Dans les logs au lancement du démon :
[1/26/2020, 5:45:14 PM] Loaded config.json with 0 accessories and 1 platforms.
[1/26/2020, 5:45:14 PM] —
[1/26/2020, 5:45:14 PM] Plugin /usr/lib/node_modules/homebridge-jeedom does not contain a package.json.
[1/26/2020, 5:45:15 PM] ====================
[1/26/2020, 5:45:15 PM] ERROR LOADING PLUGIN homebridge-alexa:
[1/26/2020, 5:45:15 PM] SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
at exports.runInThisContext (vm.js:53:16)
at Module._compile (module.js:387:25)
at Object.Module._extensions…js (module.js:422:10)
at Module.load (module.js:357:32)
at Function.Module._load (module.js:314:12)
at Module.require (module.js:367:17)
at require (internal/module.js:20:19)
at Object. (/usr/share/nginx/www/jeedom/plugins/homebridge/resources/node_modules/debug/src/index.js:9:19)
at Module._compile (module.js:413:34)
[1/26/2020, 5:45:15 PM] ERROR LOADING PLUGIN homebridge-camera-ffmpeg:
[1/26/2020, 5:45:15 PM] SyntaxError: Unexpected token {
at Object. (/usr/share/nginx/www/jeedom/plugins/homebridge/resources/node_modules/homebridge-camera-ffmpeg/ffmpeg.js:8:13)
[1/26/2020, 5:45:15 PM] Loaded plugin: homebridge-jeedom
/usr/share/nginx/www/jeedom/plugins/homebridge/resources/node_modules/fakegato-history/lib/googleDrive.js:7
const {google} = require(‹ googleapis ›);
at Object. (/usr/share/nginx/www/jeedom/plugins/homebridge/resources/node_modules/fakegato-history/fakegato-storage.js:11:19)
Configuration : Jeedom Mini Plus v3.3.39
Je suis preneur d’un coup de main
