HIKVISION Probleme dépendance nodejs
Petit souci sur mes dépendances que je n’arrive pas à lancer…
La version nodejs semble pas bonne. je suis bien en Debian 10 mise à jour.
Je ne comprends pas non plus l’interaction avec le plugin #plugin-wifilightv2 de @bernardfr.caron .
Etrange.
Il semble avoir supprimé nodejs 14.18.2 pour le réinstaller…
Les voici
Début de l'installation
--2021-12-31 00:17:05--  https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.108.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
Length: 1552 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K .                                                     100% 22.2M=0s
2021-12-31 00:17:05 (22.2 MB/s) - 'dependencies.sh' saved [1552/1552]
dependencies.sh: 3: [: /tmp/jeedom/hikvision/dependance: unexpected operator
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon3008.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon1519.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon1210.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon1102.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon1212.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon2223.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon2100.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/wifilightV2_icon.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon1504.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon2219.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon2602.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon2302.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images/icon2415.png': Operation not permitted
chown: changing ownership of '/var/www/html/plugins/wifilightV2/data/images': Operation not permitted
Version actuelle : 14
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://ftp.fr.debian.org/debian buster InRelease
Hit:3 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:4 http://phoscon.de/apt/deconz buster InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
dependencies.sh: 29: dependencies.sh: [[: not found
Package 'npm' is not installed, so not removed
The following packages will be REMOVED:
nodejs*
0 upgraded, 0 newly installed, 1 to remove and 13 not upgraded.
After this operation, 122 MB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 71468 files and directories currently installed.)
Removing nodejs (14.18.2-deb-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
dependencies.sh: 38: [: x86_64: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
## Creating apt sources list file for the NodeSource Node.js 14.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Hit:2 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
debconf: (This frontend requires a controlling tty.)
0 upgraded, 1 newly installed, 0 to remove and 13 not upgraded.
Need to get 0 B/25.1 MB of archives.
After this operation, 122 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ... 66536 files and directories currently installed.)
Preparing to unpack .../nodejs_14.18.2-deb-1nodesource1_amd64.deb ...
Unpacking nodejs (14.18.2-deb-1nodesource1) ...
Setting up nodejs (14.18.2-deb-1nodesource1) ...
ln: failed to create symbolic link '/usr/bin/nodejs': File exists
Version actuelle : v14.18.2
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm ERR! code 128
npm ERR! Command failed: git clone --mirror -q https://github.com/Tsopic/hikvision-node-eventSubscribe.git /root/.npm/_cacache/tmp/git-clone-a7b5122e/.git
npm ERR! fatal: could not create leading directories of '/root/.npm/_cacache/tmp/git-clone-a7b5122e/.git'
npm ERR!
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-12-30T23_17_16_774Z-debug.log
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
