je te remercie , dernière petite question, t’as associé aussi la télécommande à l’ampoule ?
bonne soirée
Sinon voici mes 3 scénarios en JSON pour les importer en template pour créer ton scénario…
scenario T on-off.txt (913 Octets)
scenario.txt (350 Octets)
Une fois téléchargé, remplacer le .txt par .json
Créer un nouveau scénario et charger un template en utilisant le json téléchargé…
merci beaucoup autrement t’as associé aussi la télécommande à l’ampoule ?
Non, car ça met le bazar. Juste télécommande et ampoule via Jeedom.
ok , elle me fait pas les couleurs par contre , me demande si elle marche normalement
Tu peux donner les infos brutes de l’ampoule…
"ieee": "00:15:8d:00:06:c5:b9:e5",
"nwk": 53705,
"status": 2,
"lqi": "132",
"rssi": "-67",
"last_seen": "1661033679.097422",
"node_descriptor": "01:40:8e:0b:12:7f:5a:00:00:2a:5a:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 268,
"profile_id": 260,
"manufacturer": "HEIMAN",
"model": "TemperLight",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 65534,
"name": "Manufacturer Specific",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 2
"id": 1,
"name": "app_version",
"value": 25
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 18
"id": 4,
"name": "manufacturer",
"value": "HEIMAN"
"id": 5,
"name": "model",
"value": "TemperLight"
"id": 6,
"name": "date_code",
"value": "20190925"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "1000-0001"
"id": 4,
"name": "Groups",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16387,
"name": "start_up_on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 254
"id": 5,
"name": "Scenes",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 20650
"id": 4,
"name": "current_y",
"value": 21396
"id": 7,
"name": "color_temperature",
"value": 153
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 65534,
"attributes": []
"id": 2821,
"name": "Diagnostic",
"attributes": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4619,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 90,
"server_mask": 10752,
"maximum_outgoing_transfer_size": 90,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 268,
"input_clusters": [
0,
4,
3,
6,
8,
5,
768,
4096,
65534,
2821
25,
65534
"class": "zigpy.device"
Voici une copie du lien que j’avais mis…
voici les scénarios associés à la télécommande…
pour le bouton ONOFF
pour la luminosité
pour la couleur
C’est la même ampoule que moi, c’est une avec variation de blanc chaud à blanc froid.
voici le logical ID pour les commandes Luminosité et Température Couleur en entier pour l’ampoule car c’est tronqué sur les captures
Luminosité: 1::level::move_to_level::#slider#::#duration#
Température Couleur: 1::light_color::move_to_color_temp::#slider#::#duration#
merci beaucoup, c’est ce que je pensais une blanche variateur, je l’ai acheté pour une rgb sur amazon
La personne avec qui j’avais échangé en privé avait lui commandé une variante de blanc et reçu à la place une RGB…
De son message : Mon ampoule : « model »: « ColorLight »
du grand n’importe quoi
je t’embête une dernière fois, tu pourras me faire une capture de très commandes télécommandes, je trouve bizarre de n’avoir que le 2 soit binaire alors que c’est une variation d’intensité
C’est bien du binaire pour les boutons de luminosité.
C’est pour ça que mon scénario intègre à chaque appui une augmentation ou réduction de la valeur de 50 dans l’intervalle mini et maxi de l’ampoule.
ok merci.Mon bouton 2 ne réagit pas en binaire, il reste à 0
hello,
je viens de reprendre mon post , apres qqes temps d’abscence.
j’ai aussi appliqué vos com et comme toi XAV31190 j’ai le meme souci avec le bouton 2
j’ai du 0 que j’appuie sur l’un ou l’autre …
c’est dans le decodage du bt qu 'il y a un soucci si 1::8::cmd::1 on remplace le 1 a la fin de la commande par 0 la elle envoie 1 …
effectivement en modifiant la valeur, il passe à 1. Pour notre part, il faut prévoir ,un retour à 0 dans les scénarios pour pouvoir le faire fonctionner correctement, il est pas en mode « poussoir »
Merci pour l’info.
j’ai recup qqes infos ici
merci pour l’info
