Sur un graphique en colonne, existe t’il une astuce afin d’afficher la valeur en haut des colonnes ?
Finalement, je vais essayer de m’orienter vers des graphiques highcharts. Le point de départ sera ce format.
<!DOCTYPE HTML>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>Highcharts Example</title>
<style type="text/css">
@import 'https://code.highcharts.com/css/highcharts.css';
.highcharts-figure, .highcharts-data-table table {
min-width: 310px;
max-width: 800px;
margin: 1em auto;
font-family: Verdana, sans-serif;
border-collapse: collapse;
border: 1px solid #EBEBEB;
margin: 10px auto;
text-align: center;
width: 100%;
max-width: 500px;
.highcharts-data-table caption {
padding: 1em 0;
font-size: 1.2em;
color: #555;
.highcharts-data-table th {
font-weight: 600;
padding: 0.5em;
.highcharts-data-table td, .highcharts-data-table th, .highcharts-data-table caption {
padding: 0.5em;
.highcharts-data-table thead tr, .highcharts-data-table tr:nth-child(even) {
background: #f8f8f8;
.highcharts-data-table tr:hover {
background: #f1f7ff;
/* Link the series colors to axis colors */
.highcharts-color-0 {
fill: #7cb5ec;
stroke: #7cb5ec;
.highcharts-axis.highcharts-color-0 .highcharts-axis-line {
stroke: #7cb5ec;
.highcharts-axis.highcharts-color-0 text {
fill: #7cb5ec;
.highcharts-color-1 {
fill: #90ed7d;
stroke: #90ed7d;
.highcharts-axis.highcharts-color-1 .highcharts-axis-line {
stroke: #90ed7d;
.highcharts-axis.highcharts-color-1 text {
fill: #90ed7d;
.highcharts-yaxis .highcharts-axis-line {
stroke-width: 2px;
</style>
</head>
<body>
<script src="../../code/highcharts.js"></script>
<script src="../../code/modules/exporting.js"></script>
<script src="../../code/modules/export-data.js"></script>
<script src="../../code/modules/accessibility.js"></script>
<figure class="highcharts-figure">
<div id="container"></div>
<p class="highcharts-description">
Charts can be styled using CSS, allowing designers and
developers to more easily collaborate on chart configuration.
This example shows how the base Highcharts styling is imported
using CSS, and modified without the need for Javascript.
</p>
</figure>
<script type="text/javascript">
Highcharts.chart('container', {
chart: {
type: 'column',
styledMode: true
title: {
text: 'Styling axes and columns'
yAxis: [{
className: 'highcharts-color-0',
title: {
text: 'Primary axis'
className: 'highcharts-color-1',
opposite: true,
title: {
text: 'Secondary axis'
plotOptions: {
column: {
borderRadius: 5
series: [{
data: [1, 3, 2, 4]
data: [324, 124, 547, 221],
yAxis: 1
</script>
</body>
</html>
L’objectif sera :
Je rencontre un premier point de blocage : comment charge t’on les séries de l’historique de jeedom ? J’ai ceci dans l’exemple
series: [{
data: [1, 3, 2, 4]
yAxis: 1
je n’ai toujours pas trouvé comment récupérer les données et ce que j’ai trouvé sur le forum ne m’a pas fait avancer. Je pars de loin ^^.
J’ai essayé avec un graphique simple et le chargement d’une donnée d’un équipement avec la commande jeedom.cmd.execute({ id: ‹ 3428 › , mais rien…
Après il me faudra récupérer les données de l’historique de cette commande sur les 7 derniers jours…
<html>
<head>
</style>
</head>
<body>
<div id="Graphique_1" style="min-width: 150px; height: 410px;"></div>
<script>
var valeur1;
jeedom.cmd.execute({ id: '3428',
success: function(resultat) {
valeur1 = parseFloat(resultat);
setTimeout(graph, 10);
function graph(){
Highcharts.chart('Graphique_1', {
chart: {
type: 'column'
title: {
text: ''
plotOptions: {
column: {
borderRadius: 5
series: [{
data: [{
color: '#ccd41f'
</script>
</body>
</html>
J’ai avancé un peu. j’arrive à charger des données mais je passe avant par un virtuel pour les récupérer… il y a surement mieux en tapant dans la base de donnée.
J’essaie d’afficher une image, mais je bloque
Si je met le lien en dur, l’image se charge.
return '<div style="text-align:center"><div>' + this.y + '</div><div class="dynamic-class-' + this.series.name.toLowerCase() +'"><img src="/html/data/img/14.png"></div></div>';
Mais si je veux adapter l’image en fonction de la valeur, cela plante le tableau et rien ne se charge.
return '<div style="text-align:center"><div>' + this.y + '</div><div class="dynamic-class-' + this.series.name.toLowerCase() +'"><img src="/html/data/img/' + math.round(this.y) + '.png"></div></div>';
Voyez-vous pourquoi ?
Le code complet :
<!DOCTYPE HTML>
<html>
<head>
min-width: 310px;
max-width: 800px;
margin: 1em auto;
font-family:Montserrat, Arial;
font-variant: small-caps;
font-weight:normal;
margin: 10px auto;
text-align: center;
width: 100%;
max-width: 500px;
padding: 1em 0;
font-size: 1.2em;
color: #555;
font-weight: 600;
padding: 0.5em;
padding: 0.5em;
fill: #7cb5ec;
stroke: #7cb5ec;
stroke: #7cb5ec;
fill: #7cb5ec;
fill: #90ed7d;
stroke: #90ed7d;
stroke: #90ed7d;
fill: #90ed7d;
stroke-width: 2px;
</style>
</head>
<body>
</figure>
var valeur1;
jeedom.cmd.execute({ id: '3577',
var valeur2;
jeedom.cmd.execute({ id: '3578',
valeur2 = parseFloat(resultat);
var valeur3;
jeedom.cmd.execute({ id: '3579',
valeur3 = parseFloat(resultat);
var valeur4;
jeedom.cmd.execute({ id: '3580',
valeur4 = parseFloat(resultat);
var valeur5;
jeedom.cmd.execute({ id: '3581',
valeur5 = parseFloat(resultat);
var valeur6;
jeedom.cmd.execute({ id: '3582',
valeur6 = parseFloat(resultat);
var valeur7;
jeedom.cmd.execute({ id: '3583',
valeur7 = parseFloat(resultat);
var consommation_jour = valeur1 + "," + valeur2 + "," + valeur3 + ","+ valeur4 + ","+ valeur5 + "," + valeur6 + "," + valeur7
chart: {
type: 'column',
styledMode: true
title: {
text: ''
yAxis: [{
title: {
text: ''
xAxis: {
categories: ['J-7', 'J-6', 'J-5', 'J-4', 'J-3', 'J-2', 'J-l']
plotOptions: {
column: {
dataLabels: {
enabled: true,
useHTML: true,
formatter: function() {
y: 0
series: [{
data: JSON.parse("[" + consommation_jour + "]")
</script>
</body>
</html>
