quoique je change dans la configuration du googlecast j’ai toujours une femme robot qui me parle
voici la config
quelqu’un a une idée?
merci
voici la config
merci
une petite relecture de la documentation et tu verra qu’il faut créer et récupérer une clé API
j’ai l’impresssion de l’avoir bien fait
voici les logs :
> 2020-09-15 15:28:35][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 15:28:35][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 15:28:51][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 15:28:51][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:48:15][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:48:15][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:48:56][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:48:56][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:49:06][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:49:06][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:50:12][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:50:12][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:50:31][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:50:31][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:51:04][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:51:04][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:51:20][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:51:20][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:51:21][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:51:21][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:52:03][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:52:03][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 16:52:21][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 16:52:21][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:01:35][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 17:01:35][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:01:47][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 17:01:47][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:02:31][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 17:02:31][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:02:45][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 17:02:45][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:02:53][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 17:02:53][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:20:23][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 400 (Bad Request) from Google Cloud TTS API. Probable cause: API key not valid
> [2020-09-15 17:20:23][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:32:39][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 403 (Forbidden) from Google Cloud TTS API. Probable cause: Cloud Text-to-Speech API is not enabled for this key. Check and enable this API for the project in Google Console.
> [2020-09-15 17:32:39][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:34:09][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 403 (Forbidden) from Google Cloud TTS API. Probable cause: Cloud Text-to-Speech API is not enabled for this key. Check and enable this API for the project in Google Console.
> [2020-09-15 17:34:09][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:34:20][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 403 (Forbidden) from Google Cloud TTS API. Probable cause: Cloud Text-to-Speech API is not enabled for this key. Check and enable this API for the project in Google Console.
> [2020-09-15 17:34:20][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:36:06][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 403 (Forbidden) from Google Cloud TTS API. Probable cause: Cloud Text-to-Speech API is not enabled for this key. Check and enable this API for the project in Google Console.
> [2020-09-15 17:36:06][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:36:18][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 403 (Forbidden) from Google Cloud TTS API. Probable cause: Cloud Text-to-Speech API is not enabled for this key. Check and enable this API for the project in Google Console.
> [2020-09-15 17:36:18][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
> [2020-09-15 17:36:23][ERROR] : CMD-TTS------Google Cloud TextToSpeech API Error : 403 (Forbidden) from Google Cloud TTS API. Probable cause: Cloud Text-to-Speech API is not enabled for this key. Check and enable this API for the project in Google Console.
> [2020-09-15 17:36:23][ERROR] : CMD-TTS------Google Cloud TextToSpeech API : Error while using Google Cloud TextToSpeech API - failover to picotts
je dois pas bien ecrire le format…
c’est ma faute j’vais pas pris « Cloud Text-to-Speech API »
pardon merci beaucoup
bonne soirée
Juste une dernière petite question qu’elle est la voix qui se rapproche le plus de celle de Google home d’après vous?
Pour ma part :Google translation sans mettre la CB me convient parfaitement
Cloud texte ti speech api n’est pas payant
