Bonjour à tous ,
je rêve où dans un avenir proche y aurait possibilité de Google Home en local, et donc par déduction dans Jeedom ?
home-assistant:dev
← elupus:google_assistant_local
opened 09:35PM - 02 Jan 20 UTC
## Description:
Support local api execution for google assistant with local ins… tall
**Related issue (if applicable):** fixes #<home-assistant issue number goes here>
**Pull request with documentation for [home-assistant.io](https://github.com/home-assistant/home-assistant.io) (if applicable):** home-assistant/home-assistant.io#<home-assistant.io PR number goes here>
## Example entry for `configuration.yaml` (if applicable):
```yaml
## Checklist:
- [ ] The code change is tested and works locally.
- [ ] Local tests pass with `tox`. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated in [home-assistant.io](https://github.com/home-assistant/home-assistant.io)
If the code communicates with devices, web services, or third-party tools:
- [ ] [_The manifest file_][manifest-docs] has all fields filled out correctly. Update and include derived files by running `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt` by running `python3 -m script.gen_requirements_all`.
- [ ] Untested files have been added to `.coveragerc`.
If the code does not interact with devices:
- [ ] Tests have been added to verify that the new code works.
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
Loic
Juin 5, 2020, 12:43
2
C’est deja en place sur le plugin depuis plus de 1 mois…
lol , je sors de ma caverne, c etait confinement !! MDR
non mais sérieux , tout google home sans connexion internet ???
edit : je relis la doc , mode cloud…ok, et quel en est le retour des utilisateurs ? inconvénients éventuels ?
Loic
Juin 5, 2020, 12:48
4
Non non ca c’est pas possible car le google home a besoin d’internet pour comprendre ce que tu dis. La ce que tu vois c’est juste qu’une fois qu’il a compris au lieu d’envoyer la demande a nos serveur cloud qui la renvoi vers ton jeedom la demande est directement envoyé depuis le google home vers ton jeedom.
Attention ce n’est possible qu’avec les requêtes d’exécution les requête de demande d’information ne sont pas compatible ni la synchro (restriction google)
ok, merci c est beaucoup plus clair…et logique, j avais cru à un goggle Home « total » dans la bécane
