Bonjour à tous
je viens de tester mon jeedom sur une VM en passant de la dernière 4.1 à la 4.2.13
dernière version stable sur plugin
l’instalaltion des dépendances reste à NOK
* Install dependancies *
> Progress file: /tmp/jeedom/fullyKiosK/dependance
> Install Mosquitto: 1
* Update package source repository
Reading package lists...
Building dependency tree...
Reading state information...
php-pear is already the newest version (1:1.10.6+submodules+notgz-1.1+deb10u2).
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
--2022-02-28 15:21:44-- http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
Resolving repo.mosquitto.org (repo.mosquitto.org)... 85.119.83.194, 2001:ba8:1f1:f271::2
Connecting to repo.mosquitto.org (repo.mosquitto.org)|85.119.83.194|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3167 (3.1K) [application/octet-stream]
Saving to: 'mosquitto-repo.gpg.key'
0K ... 100% 34.7M=0s
2022-02-28 15:21:44 (34.7 MB/s) - 'mosquitto-repo.gpg.key' saved [3167/3167]
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
* Synchronize the package index
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
* Install Mosquitto
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
mosquitto : Depends: libwebsockets8 (>= 1.6.0) but it is not installable
E: Unable to correct problems, you have held broken packages.
* Install php mosquitto wrapper
PHP Warning: PHP Startup: Unable to load dynamic library 'mosquitto.so' (tried: /usr/lib/php/20180731/mosquitto.so (/usr/lib/php/20180731/mosquitto.so: cannot open shared object file: No such file or directory), /usr/lib/php/20180731/mosquitto.so.so (/usr/lib/php/20180731/mosquitto.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
> Version 7 of PHP detected
> Install php7.3-dev
php7.3-dev is already the newest version (7.3.31-1~deb10u1).
> Install pecl/Mosquitto
WARNING: channel "pecl.php.net" has updated its protocols, use "pecl channel-update pecl.php.net" to update
downloading Mosquitto-0.4.0.tgz ...
Starting to download Mosquitto-0.4.0.tgz (23,804 bytes)
........done: 23,804 bytes
5 source files, building
running: phpize
Configuring for:
PHP Api Version: 20180731
Zend Module Api No: 20180731
Zend Extension Api No: 320180731
Please provide the prefix of the libmosquitto installation [autodetect] : building in /tmp/pear/temp/pear-build-rootBp5HyW/Mosquitto-0.4.0
running: /tmp/pear/temp/Mosquitto/configure --with-php-config=/usr/bin/php-config --with-mosquitto
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for a sed that does not truncate output... /bin/sed
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for PHP prefix... /usr
checking for PHP includes... -I/usr/include/php/20180731 -I/usr/include/php/20180731/main -I/usr/include/php/20180731/TSRM -I/usr/include/php/20180731/Zend -I/usr/include/php/20180731/ext -I/usr/include/php/20180731/ext/date/lib
checking for PHP extension directory... /usr/lib/php/20180731
checking for PHP installed headers prefix... /usr/include/php/20180731
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking for mosquitto support... yes, shared
checking for mosquitto files in default path... not found
configure: error: Please reinstall the mosquitto distribution
ERROR: `/tmp/pear/temp/Mosquitto/configure --with-php-config=/usr/bin/php-config --with-mosquitto' failed
> No need to reload the web server
* End dependancy installation *
