Pour le problème 2, Ok ça marche, mais c’est étrange car je l’avais fait plusieurs fois.
Pour l’autre problème, voici le lot que j’obtiens lorsque que je fais un "Scan Tiles
[2020-08-30 10:02:10][DEBUG] : >───────── Création équipement : Home Adapters
[2020-08-30 10:02:14][DEBUG] : ┌───────── Début de Mise à jour
[2020-08-30 10:02:14][DEBUG] : │ [FreeboxRequest] Connexion GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-08-30 10:02:14][DEBUG] : │ [FreeboxRequest] {"success":true,"result":{"mac":"34:27:92:61:12:06","sensors":[{"id":"temp_hdd0","name":"Disque dur 1","value":46},{"id":"temp_t2","name":"Température 2","value":54},{"id":"temp_t1","name":"Température 1","value":50},{"id":"temp_t3","name":"Température 3","value":48},{"id":"temp_cpu_cp_slave","name":"Température CPU CP Slave","value":80},{"id":"temp_cpu_ap","name":"Température CPU AP","value":72},{"id":"temp_cpu_cp_master","name":"Température CPU CP Master","value":79}],"model_info":{"has_dect":true,"wifi_type":"2d4_5g_5g","has_home_automation":true,"customer_hdd_slots":4,"name":"fbxgw7-r1\/full","has_lan_sfp":true,"internal_hdd_size":0,"pretty_name":"Freebox v7 (r1)","has_vm":true,"has_expansions":true},"fans":[{"id":"fan1_speed","name":"Ventilateur 2","value":1517},{"id":"fan0_speed","name":"Ventilateur 1","value":2129}],"expansions":[{"type":"security","present":true,"slot":1,"probe_done":true,"supported":true,"bundle":"985700J184601653"},{"type":"ftth_pon","present":true,"slot":2,"probe_done":true,"supported":true,"bundle":"955800A184804454"}],"board_name":"fbxgw7r","disk_status":"active","uptime":"17 jours 15 heures 39 minutes 38 secondes","uptime_val":1525178,"user_main_storage":"Disque 1","box_authenticated":true,"serial":"957601J183900212","firmware_version":"4.2.3"}}
[2020-08-30 10:02:14][DEBUG] : └─────────
