J’ai redémarré avec la commande ON ça marche bien. Les commandes actions marchent bien c’est juste le retour d’état qui ne vient pas…
Un simple refresh après avoir coupé le wifi. J’ai mis le log en debug après l’action et j’ai juste fait un refresh après avoir activé le mode debug :
[2020-12-03 11:42:21][DEBUG] : ┌───────── Début de Mise à jour
[2020-12-03 11:42:21][DEBUG] : │ Connexion sur la freebox pour mise à jour de : Rafraichir
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/mac_filter/([])
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":[{"mac":"00:04:20:28:77:CD","type":"whitelist",BLABLABLABLA...
[2020-12-03 11:42:21][DEBUG] : └─────────
[2020-12-03 11:42:21][DEBUG] : >───────── Liste Noire :
[2020-12-03 11:42:21][DEBUG] : >───────── Liste Blanche : BLABLABLA
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/config(null)
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":false,"mac_filter_state":"whitelist"}}
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/planning(null)
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"use_planning":false,"resolution":48,"mapping":["on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on"]}}
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/wifi/wps/config(null)
[2020-12-03 11:42:21][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true}}
[2020-12-03 11:42:24][DEBUG] : >───────── Type de box compatible Tiles ? : NOK
[2020-12-03 11:42:24][DEBUG] : ┌───────── Début de Mise à jour
[2020-12-03 11:42:24][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v8/system(null)
[2020-12-03 11:42:24][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":{"mac":"14:0C:76:60:96:CE","model_info":{"has_ext_telephony":true,"has_speakers_jack":true,"wifi_type":"2d4_5g","pretty_name":"Freebox Server (r1)","customer_hdd_slots":0,"name":"fbxgw-r1\/full","has_speakers":true,"internal_hdd_size":250,"has_femtocell_exp":true,"has_internal_hdd":true,"has_dect":true},"fans":[{"id":"fan0_speed","name":"Ventilateur 1","value":2002}],"sensors":[{"id":"temp_hdd","name":"Disque dur","value":47},{"id":"temp_sw","name":"Température Switch","value":57},{"id":"temp_cpum","name":"Température CPU M","value":68},{"id":"temp_cpub","name":"Température CPU B","value":83}],"board_name":"fbxgw1r","disk_status":"active","uptime":"48 jours 1 heure 58 minutes 45 secondes","uptime_val":4154325,"user_main_storage":"Disque dur","box_authenticated":true,"serial":"806401S191703760","firmware_version":"4.2.5"}}
[2020-12-03 11:42:24][DEBUG] : └─────────
A lire ton log j’ai l’impression que tu récupères bien le bon status ([Freebox Request Result] : {« success »:true,« result »:{« enabled »:false,« mac_filter_state »:« whitelist »}}) cad enabled = false mais que ça ne remonte pas dans l’équipement. Pour info je suis en v4.1.61.
