Depuis quelques temps j’ai un problème sur mon réseau Z-Wave.
Je ne sais pas pourquoi (surement la faute d’un modue) mais mon réseau z-wave se sature à intervalle irrégulier.
Comme puis-je connaître les instructions qui causent ce bouchon ?
Je ne vois rien de spécial au niveau des LOGS.
[2020-09-15 10:22:02][INFO] : node info getHealth
[2020-09-15 10:22:02][INFO] : 200 GET /node?node_id=34&type=info&info=getHealth&apikey=XXXCLEF_APIXXX (127.0.0.1) 38.45ms
[2020-09-15 10:22:02][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:22:02][INFO] : Received Meter report from node 72: Power=44.751W
[2020-09-15 10:22:06][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:22:06][INFO] : Received Meter report from node 73: Energy=42.293kWh
[2020-09-15 10:22:06][INFO] : Received Meter report from node 73: Previous Reading=42.293kWh
[2020-09-15 10:22:06][INFO] : Received Meter report from node 73: Interval=300seconds
[2020-09-15 10:22:06][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:22:32][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:22:32][INFO] : Received Meter report from node 72: Power=44.666W
[2020-09-15 10:22:36][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:22:36][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:22:41][INFO] : Received Sensor multilevel report from node 76: Temperature=26.1C
[2020-09-15 10:22:53][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:22:53][INFO] : Received Meter report from node 73: Power=0.978W
[2020-09-15 10:22:55][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:22:55][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:22:59][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:22:59][INFO] : Received Meter report from node 73: Power=0.967W
[2020-09-15 10:23:01][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:23:01][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:23:01][INFO] : node info getHealth
[2020-09-15 10:23:01][INFO] : 200 GET /node?node_id=34&type=info&info=getHealth&apikey=XXXCLEF_APIXXX (127.0.0.1) 38.98ms
[2020-09-15 10:23:02][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:23:02][INFO] : Received Meter report from node 72: Power=44.708W
[2020-09-15 10:23:06][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:23:06][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:23:25][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:23:25][INFO] : Received Meter report from node 73: Power=0.929W
[2020-09-15 10:23:27][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:23:27][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:23:32][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:23:32][INFO] : Received Meter report from node 72: Power=44.666W
[2020-09-15 10:23:34][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:23:34][INFO] : Received Meter report from node 73: Power=0.839W
[2020-09-15 10:23:36][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:23:36][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:23:46][INFO] : Received Sensor binary report from node 46: Sensor=True
[2020-09-15 10:23:47][INFO] : Received Meter report from node 56: Exporting=False
[2020-09-15 10:23:47][INFO] : Received Meter report from node 56: Energy=2.65kWh
[2020-09-15 10:23:57][INFO] : Received Sensor binary report from node 42: Sensor=True
[2020-09-15 10:24:02][INFO] : node info getHealth
[2020-09-15 10:24:02][INFO] : 200 GET /node?node_id=34&type=info&info=getHealth&apikey=XXXCLEF_APIXXX (127.0.0.1) 38.70ms
[2020-09-15 10:24:02][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:24:02][INFO] : Received Meter report from node 72: Power=44.666W
[2020-09-15 10:24:05][INFO] : Received Sensor binary report from node 79: Sensor=False
[2020-09-15 10:24:05][INFO] : Received Sensor binary report from node 79: Sensor=True
[2020-09-15 10:24:06][INFO] : Received Sensor binary report from node 24: Sensor=False
[2020-09-15 10:24:06][INFO] : Received Sensor binary report from node 79: Sensor=False
[2020-09-15 10:24:06][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:24:06][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:24:06][INFO] : Received Alarm report from node 24: Alarm Type=0
[2020-09-15 10:24:06][INFO] : Received Alarm report from node 24: Alarm Level=0
[2020-09-15 10:24:10][INFO] : Received Sensor binary report from node 18: Sensor=True
[2020-09-15 10:24:12][INFO] : Received Sensor binary report from node 24: Sensor=True
[2020-09-15 10:24:12][INFO] : Received Alarm report from node 24: Alarm Type=0
[2020-09-15 10:24:12][INFO] : Received Alarm report from node 24: Alarm Level=0
[2020-09-15 10:24:17][INFO] : Received Central scene report from node 19: Scene KeyAttribute=Pressed 1 Time
[2020-09-15 10:24:17][INFO] : Received Central scene report from node 19: Scene ID=5
[2020-09-15 10:24:17][INFO] : Received Central scene report from node 19: Scene Number=50
[2020-09-15 10:24:18][INFO] : Send command to node 78 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:18][INFO] : 200 GET /node?node_id=78&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.82ms
[2020-09-15 10:24:18][INFO] : Send command to node 8 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:18][INFO] : 200 GET /node?node_id=8&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.84ms
[2020-09-15 10:24:18][INFO] : Send command to node 50 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:18][INFO] : 200 GET /node?node_id=50&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.35ms
[2020-09-15 10:24:18][INFO] : Send command to node 51 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:18][INFO] : 200 GET /node?node_id=51&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.86ms
[2020-09-15 10:24:19][INFO] : Received Battery report from node 19: Battery Level=91%
[2020-09-15 10:24:26][INFO] : Received Central scene report from node 19: Scene KeyAttribute=Pressed 1 Time
[2020-09-15 10:24:26][INFO] : Received Central scene report from node 19: Scene ID=5
[2020-09-15 10:24:26][INFO] : Received Central scene report from node 19: Scene Number=50
[2020-09-15 10:24:26][INFO] : Send command to node 78 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:26][INFO] : 200 GET /node?node_id=78&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.97ms
[2020-09-15 10:24:26][INFO] : Send command to node 8 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:26][INFO] : 200 GET /node?node_id=8&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.73ms
[2020-09-15 10:24:26][INFO] : Send command to node 50 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:26][INFO] : 200 GET /node?node_id=50&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.38ms
[2020-09-15 10:24:26][INFO] : Send command to node 51 on class 38 instance 1 index 0 value 0
[2020-09-15 10:24:26][INFO] : 200 GET /node?node_id=51&instance_id=1&cc_id=38&index=0&type=setvalue&value=0&apikey=XXXCLEF_APIXXX (127.0.0.1) 2.34ms
[2020-09-15 10:24:27][INFO] : Received Battery report from node 19: Battery Level=91%
[2020-09-15 10:24:29][INFO] : Received Battery report from node 71: Battery Level=90%
[2020-09-15 10:24:31][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:24:31][INFO] : Received Meter report from node 73: Power=0.959W
[2020-09-15 10:24:32][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:24:32][INFO] : Received Meter report from node 72: Power=44.624W
[2020-09-15 10:24:33][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:24:33][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:24:34][INFO] : 200 GET /network?type=info&info=getStatus&apikey=XXXCLEF_APIXXX (127.0.0.1) 1.73ms
[2020-09-15 10:24:36][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:24:36][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:24:37][INFO] : 200 GET /network?type=info&info=getNeighbours&apikey=XXXCLEF_APIXXX (127.0.0.1) 9.52ms
[2020-09-15 10:24:37][INFO] : 200 GET /network?type=info&info=getStatus&apikey=XXXCLEF_APIXXX (127.0.0.1) 1.92ms
[2020-09-15 10:24:39][INFO] : 200 GET /network?type=info&info=getStatus&apikey=XXXCLEF_APIXXX (127.0.0.1) 1.81ms
[2020-09-15 10:24:41][INFO] : 200 GET /network?type=info&info=getStatus&apikey=XXXCLEF_APIXXX (127.0.0.1) 1.73ms
[2020-09-15 10:24:43][INFO] : 200 GET /network?type=info&info=getStatus&apikey=XXXCLEF_APIXXX (127.0.0.1) 1.71ms
[2020-09-15 10:24:54][INFO] : Received Sensor multilevel report from node 38: Temperature=43.5C
[2020-09-15 10:24:54][INFO] : Received Sensor binary report from node 18: Sensor=False
[2020-09-15 10:24:57][INFO] : Received Sensor binary report from node 42: Sensor=False
[2020-09-15 10:25:01][INFO] : node info getHealth
[2020-09-15 10:25:01][INFO] : 200 GET /node?node_id=34&type=info&info=getHealth&apikey=XXXCLEF_APIXXX (127.0.0.1) 79.04ms
[2020-09-15 10:25:02][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:25:02][INFO] : Received Meter report from node 72: Power=44.624W
[2020-09-15 10:25:03][INFO] : Received Sensor binary report from node 46: Sensor=False
[2020-09-15 10:25:06][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:25:06][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:25:11][INFO] : Received Meter report from node 48: Energy=832.36kWh
[2020-09-15 10:25:32][INFO] : Received Meter report from node 72: Exporting=False
[2020-09-15 10:25:32][INFO] : Received Meter report from node 72: Power=44.624W
[2020-09-15 10:25:36][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:25:36][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:25:43][INFO] : Received Sensor multilevel report from node 76: Temperature=26.2C
[2020-09-15 10:25:48][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:25:48][INFO] : Received Meter report from node 73: Power=0.772W
[2020-09-15 10:25:50][INFO] : Received Meter report from node 73: Exporting=False
[2020-09-15 10:25:50][INFO] : Received Meter report from node 73: Power=0.0W
[2020-09-15 10:25:53][INFO] : Received Meter report from node 34: Exporting=False
[2020-09-15 10:25:53][INFO] : Received Meter report from node 34: Energy=1335.96kWh
2020-09-15 10:21:02.919 Info, Node072, Received Meter report from node 72: Power=44.752W
2020-09-15 10:21:06.245 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:21:32.927 Info, Node072, Received Meter report from node 72: Energy=36.874kWh
2020-09-15 10:21:32.928 Info, Node072, Previous value was 36.869kWh, received 300 seconds ago.
2020-09-15 10:21:33.017 Info, Node072, Received Meter report from node 72: Power=44.752W
2020-09-15 10:21:36.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:22:02.918 Info, Node072, Received Meter report from node 72: Power=44.752W
2020-09-15 10:22:06.249 Info, Node073, Received Meter report from node 73: Energy=42.294kWh
2020-09-15 10:22:06.249 Info, Node073, Previous value was 42.294kWh, received 300 seconds ago.
2020-09-15 10:22:06.343 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:22:32.918 Info, Node072, Received Meter report from node 72: Power=44.666W
2020-09-15 10:22:36.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:22:41.803 Info, Node076, Received SensorMultiLevel report from node 76, instance 1, Temperature: value=26.1C
2020-09-15 10:22:53.245 Info, Node073, Received Meter report from node 73: Power=0.979W
2020-09-15 10:22:55.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:22:59.245 Info, Node073, Received Meter report from node 73: Power=0.968W
2020-09-15 10:23:01.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:23:02.918 Info, Node072, Received Meter report from node 72: Power=44.709W
2020-09-15 10:23:06.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:23:25.244 Info, Node073, Received Meter report from node 73: Power=0.929W
2020-09-15 10:23:27.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:23:32.918 Info, Node072, Received Meter report from node 72: Power=44.666W
2020-09-15 10:23:34.244 Info, Node073, Received Meter report from node 73: Power=0.840W
2020-09-15 10:23:36.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:23:46.895 Info, Node046, Received Basic set from node 46: level=255. Treating it as a Basic report.
2020-09-15 10:23:46.895 Info, Node046, SensorBinary::Set by basic report - Setting node 46 to On on instance 1
2020-09-15 10:23:47.513 Info, Node056, Received Meter report from node 56: Energy=2.65kWh
2020-09-15 10:23:57.622 Info, Node042, Received SensorBinary report: Sensor:23 State=On
2020-09-15 10:23:57.846 Info, Node042, Received Basic set from node 42: level=255. Treating it as a Basic report.
2020-09-15 10:23:57.846 Info, Node042, SensorBinary::Set by basic report - Setting node 42 to On on instance 1
2020-09-15 10:24:02.918 Info, Node072, Received Meter report from node 72: Power=44.666W
2020-09-15 10:24:05.394 Info, Node079, Received Basic set from node 79: level=0. Treating it as a Basic report.
2020-09-15 10:24:05.394 Info, Node079, SensorBinary::Set by basic report - Setting node 79 to Off on instance 1
2020-09-15 10:24:05.684 Info, Node079, Received Basic set from node 79: level=255. Treating it as a Basic report.
2020-09-15 10:24:05.684 Info, Node079, SensorBinary::Set by basic report - Setting node 79 to On on instance 1
2020-09-15 10:24:06.031 Info, Node024, Received SensorBinary report: Sensor:218 State=Off
2020-09-15 10:24:06.107 Info, Node079, Received Basic set from node 79: level=0. Treating it as a Basic report.
2020-09-15 10:24:06.107 Info, Node079, SensorBinary::Set by basic report - Setting node 79 to Off on instance 1
2020-09-15 10:24:06.243 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:24:06.446 Info, Node024, Received Alarm report: type=0, level=0
2020-09-15 10:24:10.424 Info, Node018, Received SensorBinary report: Sensor:47 State=On
2020-09-15 10:24:10.479 Info, Node018, Received Basic set from node 18: level=255. Treating it as a Basic report.
2020-09-15 10:24:10.479 Info, Node018, SensorBinary::Set by basic report - Setting node 18 to On on instance 1
2020-09-15 10:24:12.203 Info, Node024, Received SensorBinary report: Sensor:37 State=On
2020-09-15 10:24:12.469 Info, Node024, Received Alarm report: type=0, level=0
2020-09-15 10:24:17.806 Info, Node019, Received Central Scene set from node 19: scene id=5 with key Attribute 0. Sending event notification.
2020-09-15 10:24:18.072 Info, Node078, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:18.072 Info, Node078, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:18.078 Info, Node008, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:18.078 Info, Node008, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:18.083 Info, Node050, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:18.083 Info, Node050, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:18.089 Info, Node051, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:18.089 Info, Node051, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:19.296 Info, Node019, Received Battery report from node 19: level=91
2020-09-15 10:24:26.040 Info, Node019, Received Central Scene set from node 19: scene id=5 with key Attribute 0. Sending event notification.
2020-09-15 10:24:26.375 Info, Node078, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:26.375 Info, Node078, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:26.380 Info, Node008, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:26.380 Info, Node008, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:26.386 Info, Node050, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:26.386 Info, Node050, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:26.391 Info, Node051, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 -
2020-09-15 10:24:26.391 Info, Node051, SwitchMultilevel::Set - Setting to level 0
2020-09-15 10:24:27.082 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:27.086 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:27.090 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:27.099 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:27.530 Info, Node019, Received Battery report from node 19: level=91
2020-09-15 10:24:29.583 Info, Node071, Received Battery report from node 71: level=90
2020-09-15 10:24:29.711 Info, Node071, Received Battery report from node 71: level=90
2020-09-15 10:24:31.244 Info, Node073, Received Meter report from node 73: Power=0.960W
2020-09-15 10:24:32.918 Info, Node072, Received Meter report from node 72: Power=44.624W
2020-09-15 10:24:33.244 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:24:35.385 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:35.385 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:35.396 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:35.399 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:36.090 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:36.094 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:36.099 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:36.099 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:36.243 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:24:44.394 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:44.394 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:44.402 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:44.408 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:45.099 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:45.102 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:45.106 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:45.106 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:53.399 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:53.400 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:53.411 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:53.416 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:54.108 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:54.109 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:54.109 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:54.109 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:24:54.199 Info, Node038, Received SecurityCmd_NonceGet from node 38
2020-09-15 10:24:54.199 Info, NONCES: 0xd0, 0xbe, 0x10, 0x7c, 0x45, 0x51, 0x36, 0xd6
2020-09-15 10:24:54.199 Info, NONCES: 0xcb, 0x80, 0xad, 0x55, 0x4a, 0xa0, 0xd9, 0x93
2020-09-15 10:24:54.199 Info, NONCES: 0x87, 0xfd, 0x6d, 0x74, 0x71, 0xc4, 0x3b, 0x5d
2020-09-15 10:24:54.199 Info, NONCES: 0xb9, 0xf4, 0xb5, 0xd5, 0xc9, 0xfe, 0x41, 0x99
2020-09-15 10:24:54.199 Info, NONCES: 0xd6, 0x72, 0xbb, 0x47, 0x1b, 0xc7, 0x54, 0xdc
2020-09-15 10:24:54.199 Info, NONCES: 0x4f, 0x4d, 0x4b, 0x9d, 0xf8, 0xe2, 0xea, 0x6f
2020-09-15 10:24:54.199 Info, NONCES: 0x54, 0xda, 0xfe, 0x78, 0xdb, 0x73, 0xd6, 0xb1
2020-09-15 10:24:54.199 Info, NONCES: 0xe5, 0x92, 0xf9, 0x00, 0x59, 0x4e, 0xdd, 0x4c
2020-09-15 10:24:54.199 Info, Node038, Sending (Command) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x26, 0x0a, 0x98, 0x80, 0xe5, 0x92, 0xf9, 0x00, 0x59, 0x4e, 0xdd, 0x4c, 0x05, 0x01, 0xc5:
2020-09-15 10:24:54.351 Info, Raw: 0x98, 0x81, 0x3c, 0x7d, 0xca, 0xe9, 0x96, 0x33, 0x83, 0x1e, 0x4c, 0xe3, 0x2b, 0x1c, 0xc4, 0x21, 0x82, 0xe5, 0xd1, 0xc2, 0x99, 0x1e, 0x32, 0xf9, 0x1c, 0x47, 0xba
2020-09-15 10:24:54.351 Info, Node038, Received SensorMultiLevel report from node 38, instance 1, Temperature: value=43.6C
2020-09-15 10:24:54.468 Info, Node018, Received SensorBinary report: Sensor:208 State=Off
2020-09-15 10:24:54.486 Info, Node018, Received Basic set from node 18: level=0. Treating it as a Basic report.
2020-09-15 10:24:54.486 Info, Node018, SensorBinary::Set by basic report - Setting node 18 to Off on instance 1
2020-09-15 10:24:57.015 Info, Node042, Received SensorBinary report: Sensor:232 State=Off
2020-09-15 10:24:57.240 Info, Node042, Received Basic set from node 42: level=0. Treating it as a Basic report.
2020-09-15 10:24:57.240 Info, Node042, SensorBinary::Set by basic report - Setting node 42 to Off on instance 1
2020-09-15 10:25:02.402 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:02.409 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:02.419 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:02.425 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:02.917 Info, Node072, Received Meter report from node 72: Power=44.624W
2020-09-15 10:25:03.113 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:03.113 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:03.113 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:03.118 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:03.768 Info, Node046, Received Basic set from node 46: level=0. Treating it as a Basic report.
2020-09-15 10:25:03.768 Info, Node046, SensorBinary::Set by basic report - Setting node 46 to Off on instance 1
2020-09-15 10:25:06.243 Info, Node073, Received Meter report from node 73: Power=0.000W
2020-09-15 10:25:11.027 Info, Node048, Received Meter report from node 48: Energy=832.37kWh
2020-09-15 10:25:11.405 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:11.418 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:11.428 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:11.433 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:12.122 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:12.122 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:12.123 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:12.123 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:18.762 Info, Node036, Received Wakeup Notification from node 36
2020-09-15 10:25:20.410 Info, mgr, Refreshing node 8: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:20.420 Info, mgr, Refreshing node 78: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:20.435 Info, mgr, Refreshing node 50: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2020-09-15 10:25:20.435 Info, mgr, Refreshing node 51: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
Je me suis aperçu vers 12H00 que la file d’attente est passé à plus de 100 appels en attente… (il y a un décalage de 2H dans les logs)
Ou bien sinon les modules 72 et 73 qui ont l’air beaucoup trop bavards.
