Voilà les informations nécessaires.
Le Node signale une erreur de connexion ENOTFOUND
La version installée depuis le market
L’état de mes mises à jour
Je n’ai pas encore le droit d’attacher des logs donc je les copy/paste
Le log Dep
–0%
–10%
Lancement de l’installation/mise à jour des dépendances eWeJee
Désactivation de la source repo.jeedom.com !
–20%
Get:1 http://security.debian.org stretch/updates InRelease [53.0 kB]
Ign:2 http://ftp.debian.org/debian stretch InRelease
Hit:3 http://ftp.debian.org/debian stretch-updates InRelease
Hit:4 http://www.deb-multimedia.org stretch InRelease
Hit:5 http://ftp.debian.org/debian stretch-backports InRelease
Hit:6 http://ftp.debian.org/debian stretch-proposed-updates InRelease
Hit:7 http://ftp.debian.org/debian stretch Release
Hit:8 https://deb.nodesource.com/node_12.x stretch InRelease
Hit:9 Index of /meveric all InRelease
Hit:10 Index of /meveric stretch InRelease
Fetched 53.0 kB in 3s (17.5 kB/s)
Reading package lists…
Building dependency tree…
Reading state information…
apt-utils is already the newest version (1.4.10).
avahi-daemon is already the newest version (0.6.32-2).
avahi-discover is already the newest version (0.6.32-2).
avahi-utils is already the newest version (0.6.32-2).
libavahi-compat-libdnssd-dev is already the newest version (0.6.32-2).
build-essential is already the newest version (12.3).
dialog is already the newest version (1.3-20160828-2).
lsb-release is already the newest version (9.20161125).
libnss-mdns is already the newest version (0.10-8).
0 upgraded, 0 newly installed, 0 to remove and 193 not upgraded.
Réactivation de la source repo.jeedom.com qu’on avait désactivé !
–30%
Version actuelle : v12.18.3
Ok, version suffisante
–50%
–60%
Installation de eWeJee… Cette partie est très longue, veuillez attendre les 100%
npm WARN deprecated request@2.88.2: request has been deprecated, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
websocket@1.0.31 install /var/www/html/plugins/ewejee/resources/node_modules/websocket
(node-gyp rebuild 2> builderror.log) || (exit 0)
make: Entering directory ‹ /var/www/html/plugins/ewejee/resources/node_modules/websocket/build ›
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
SOLINK_MODULE(target) Release/obj.target/bufferutil.node
COPY Release/bufferutil.node
CXX(target) Release/obj.target/validation/src/validation.o
SOLINK_MODULE(target) Release/obj.target/validation.node
COPY Release/validation.node
make: Leaving directory ‹ /var/www/html/plugins/ewejee/resources/node_modules/websocket/build ›
core-js@2.6.11 postinstall /var/www/html/plugins/ewejee/resources/node_modules/core-js
node -e « try{require(‹ ./postinstall ›)}catch(e){} »
e[96mThank you for using core-js (e[94m GitHub - zloirock/core-js: Standard Library e[96m) for polyfilling JavaScript standard library!e[0m
e[96mThe project needs your help! Please consider supporting of core-js on Open Collective or Patreon: e[0m
e[96m>e[94m core-js - Open Collective e[0m
e[96m>e[94m Denis Pushkarev | creating core-js | Patreon e[0m
e[96mAlso, the author of core-js (e[94m zloirock (Denis Pushkarev) · GitHub e[96m) is looking for a good job -)e[0m
npm WARN saveError ENOENT: no such file or directory, open ‹ /var/www/html/plugins/ewejee/resources/package.json ›
npm notice created a lockfile as package-lock.json. You should commit this file.
npm WARN enoent ENOENT: no such file or directory, open ‹ /var/www/html/plugins/ewejee/resources/package.json ›
npm WARN resources No description
npm WARN resources No repository field.
npm WARN resources No README data
npm WARN resources No license field.
- ewelink-api@1.10.0
added 96 packages from 95 contributors and audited 96 packages in 27.523s
14 packages are looking for funding
run npm fund for details
found 0 vulnerabilities
- express@4.17.1
added 47 packages from 33 contributors and audited 217 packages in 10.999s
COREJS
RES
–70%
–80%
–90%
–95%
–100%
Installation des dépendances eWeJee terminée, vérifiez qu’il n’y a pas d’erreur
Et celui de NODE
http://undefined:non SSL ? undefined
Serveur correctement lancé sur http://localhost:6005 Le Sun Jul 26 2020 21:55:05 GMT+0000 (Coordinated Universal Time)
{« error »:406,« sequence »:« 1595800508830 »}
events.js:292
throw er; // Unhandled ‹ error › event
Error: getaddrinfo ENOTFOUND undefined
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:66:26)
Emitted ‹ error › event on Request instance at:
at Request.onRequestError (/var/www/html/plugins/ewejee/core/js/node_modules/request/request.js:881:8)
at ClientRequest.emit (events.js:315:20)
at Socket.socketErrorListener (_http_client.js:426:9)
at Socket.emit (events.js:315:20)
at emitErrorNT (internal/streams/destroy.js:92:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
errno: ‹ ENOTFOUND ›,
code: ‹ ENOTFOUND ›,
syscall: ‹ getaddrinfo ›,
hostname: ‹ undefined ›
Serveur correctement lancé sur http://localhost:6005 Le Sun Jul 26 2020 22:00:07 GMT+0000 (Coordinated Universal Time)
{« error »:406,« sequence »:« 1595800809878 »}
events.js:292
http://oui:80 SSL ? undefined
Serveur correctement lancé sur http://localhost:6005 Le Sun Jul 26 2020 22:07:55 GMT+0000 (Coordinated Universal Time)
{« error »:406,« sequence »:« 1595801280467 »}
events.js:292
Error: getaddrinfo ENOTFOUND oui
hostname: ‹ oui ›
Serveur correctement lancé sur http://localhost:6005 Le Sun Jul 26 2020 22:09:44 GMT+0000 (Coordinated Universal Time)
{« error »:0,« apikey »:« 9cfab200-3977-49b9-ad56-faa19e753707 »,« config »:{« hb »:1,« hbInterval »:145},« sequence »:« 1595801388045 »}
events.js:292
hostname: ‹ oui ›
Serveur correctement lancé sur http://localhost:6005 Le Sun Jul 26 2020 22:49:24 GMT+0000 (Coordinated Universal Time)
{« error »:0,« apikey »:« 9cfab200-3977-49b9-ad56-faa19e753707 »,« config »:{« hb »:1,« hbInterval »:145},« sequence »:« 1595803767808 »}
events.js:292
hostname: ‹ oui ›
