J’ai configuré Jeedom et le plugin Ajax, mais l’état des objets ne se synchronise pas lorsque j’active une commande. Cela fonctionne uniquement lorsque je synchronise manuellement depuis le plugin.
Auriez-vous des conseils ?
Merci beaucoup,
Anthonws.
[2024-12-29 22:13:09] INFO : Event on command <mark>[Home][Hub]</mark>[Alimentation secteur] value : 1
[2024-12-29 22:13:09] INFO : Event on command <mark>[Home][Hub]</mark>[Etat de la batterie] value : CHARGED
[2024-12-29 22:13:09] INFO : Event on command <mark>[Home][Hub]</mark>[Batterie] value : 100
[2024-12-29 22:14:03] INFO : Command execution: <mark>[Home][Hub]</mark>[Mode nuit] with parameters {"apikey":"xxxxxxxxxxxxxx,"type":"cmd","id":"185"}
[2024-12-29 22:19:01] INFO : Event on command <mark>[Home][Hub]</mark>[Etat] value : NIGHT_MODE
[2024-12-29 22:19:01] INFO : Event on command <mark>[Home][Hub]</mark>[Trafiqué] value : 0
[2024-12-29 22:19:01] INFO : Event on command <mark>[Home][Hub]</mark>[Ethernet] value : 1
[2024-12-29 22:19:01] INFO : Event on command <mark>[Home][Hub]</mark>[Alimentation secteur] value : 1
[2024-12-29 22:19:01] INFO : Event on command <mark>[Home][Hub]</mark>[Etat de la batterie] value : CHARGED
[2024-12-29 22:19:01] INFO : Event on command <mark>[Home][Hub]</mark>[Batterie] value : 100
[2024-12-29 22:19:25] INFO : Command execution: <mark>[Home][Hub]</mark>[Desarmement] with parameters {"user_login":"admin","user_id":"1"}
[2024-12-29 22:19:35] INFO : Command execution: <mark>[Home][Hub]</mark>[Desarmement] with parameters {"user_login":"admin","user_id":"1"}
[2024-12-29 22:22:18] INFO : Event on command <mark>[Home][Hub]</mark>[Etat] value : DISARMED
[2024-12-29 22:22:18] INFO : Event on command <mark>[Home][Hub]</mark>[Trafiqué] value : 0
[2024-12-29 22:22:18] INFO : Event on command <mark>[Home][Hub]</mark>[Ethernet] value : 1
[2024-12-29 22:22:18] INFO : Event on command <mark>[Home][Hub]</mark>[Alimentation secteur] value : 1
[2024-12-29 22:22:18] INFO : Event on command <mark>[Home][Hub]</mark>[Etat de la batterie] value : CHARGED
[2024-12-29 22:22:18] INFO : Event on command <mark>[Home][Hub]</mark>[Batterie] value : 100
Information Jeedom
Core : 4.4.19 (master)
DNS Jeedom : No
Plugin : Ajax Systems
Version : 2024-11-20 01:20:38 (beta)
