Après plusieurs essais de plusieurs procèdures je ne parviens pas à installer les dépendances de mon ESPEASY et le Demon reste à NOK.
Je suis en version Jeedom 3.3.39 sur un Odroid C2 (carte emmc). J’ai en mode SSH installé nodjs. J’ai installé/désinstallé le plugin.
Je suis en Debian 9 strech
Je joins une copie du log « Espeasydep »:
The following additional packages will be installed:
libuv1
libuv1 nodejs
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 2 newly installed, 0 to remove and 8 not upgraded.
Need to get 0 B/3,248 kB of archives.
After this operation, 13.5 MB of additional disk space will be used.
Selecting previously unselected package libuv1:arm64.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 41625 files and directories currently installed.)
Preparing to unpack .../libuv1_1.9.1-3_arm64.deb ...
Unpacking libuv1:arm64 (1.9.1-3) ...
Selecting previously unselected package nodejs.
Preparing to unpack .../nodejs_4.8.2~dfsg-1_arm64.deb ...
Unpacking nodejs (4.8.2~dfsg-1) ...
Setting up libuv1:arm64 (1.9.1-3) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up nodejs (4.8.2~dfsg-1) ...
update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
Version actuelle : v4.8.2
dependencies.sh: 59: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
Merci pour votre aide et vos réponses
Cordialement
