Tu peux essayer via SSH :
sudo pip3 install cryptography==3.3.1
puis relance installation dépendances
akenad
akenad
Merci,
J’ai essayé:
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting cryptography==3.3.1
Using cached https://www.piwheels.org/simple/cryptography/cryptography-3.3.1-cp37-cp37m-linux_armv7l.whl (782 kB)
Requirement already satisfied: six>=1.4.1 in /usr/local/lib/python3.7/dist-packages (from cryptography==3.3.1) (1.16.0)
Requirement already satisfied: cffi>=1.12 in /usr/local/lib/python3.7/dist-packages (from cryptography==3.3.1) (1.15.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.12->cryptography==3.3.1) (2.21)
Installing collected packages: cryptography
Attempting uninstall: cryptography
Found existing installation: cryptography 3.4.8
Uninstalling cryptography-3.4.8:
Successfully uninstalled cryptography-3.4.8
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
python-miio 0.5.8 requires click<8,>=7, but you have click 8.1.3 which is incompatible.
python-miio 0.5.8 requires importlib_metadata<2,>=1; python_version <= "3.7", but you have importlib-metadata 4.11.4 which is incompatible.
Successfully installed cryptography-3.3.1
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Mais dans les log des dépendances, il y a toujours un message d’erreur en rapport avec rust:
=============================DEBUG ASSISTANCE=============================
error: Rust 1.41.1 does not match extension requirement >=1.48.0
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
+ echo 15
+ sudo pip3 install --force-reinstall --upgrade zigpy-deconz
Collecting zigpy-deconz
Using cached zigpy_deconz-0.18.0-py3-none-any.whl (31 kB)
Collecting zigpy>=0.47.0
Using cached https://www.piwheels.org/simple/zigpy/zigpy-0.50.2-py3-none-any.whl (142 kB)
Collecting pyserial-asyncio
Using cached https://www.piwheels.org/simple/pyserial-asyncio/pyserial_asyncio-0.6-py3-none-any.whl (7.5 kB)
Collecting aiosqlite>=0.16.0
Using cached https://www.piwheels.org/simple/aiosqlite/aiosqlite-0.17.0-py3-none-any.whl (15 kB)
Using cached cryptography-38.0.1.tar.gz (599 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting crccheck
Using cached https://www.piwheels.org/simple/crccheck/crccheck-1.1-py3-none-any.whl (27 kB)
Collecting aiohttp
Using cached https://www.piwheels.org/simple/aiohttp/aiohttp-3.8.1-cp37-cp37m-linux_armv7l.whl (1.1 MB)
Collecting voluptuous
Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
Collecting pyserial
Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting typing_extensions>=3.7.2
Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.3.0-py3-none-any.whl (25 kB)
Collecting aiosignal>=1.1.2
Using cached https://www.piwheels.org/simple/aiosignal/aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
Collecting async-timeout<5.0,>=4.0.0a3
Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting attrs>=17.3.0
Using cached https://www.piwheels.org/simple/attrs/attrs-22.1.0-py2.py3-none-any.whl (58 kB)
Collecting frozenlist>=1.1.1
Using cached https://www.piwheels.org/simple/frozenlist/frozenlist-1.3.1-cp37-cp37m-linux_armv7l.whl (66 kB)
Collecting charset-normalizer<3.0,>=2.0
Using cached https://www.piwheels.org/simple/charset-normalizer/charset_normalizer-2.1.1-py3-none-any.whl (39 kB)
Collecting asynctest==0.13.0
Using cached https://www.piwheels.org/simple/asynctest/asynctest-0.13.0-py3-none-any.whl (26 kB)
Collecting multidict<7.0,>=4.5
Using cached https://www.piwheels.org/simple/multidict/multidict-6.0.2-cp37-cp37m-linux_armv7l.whl (53 kB)
Collecting yarl<2.0,>=1.0
Using cached https://www.piwheels.org/simple/yarl/yarl-1.8.1-cp37-cp37m-linux_armv7l.whl (94 kB)
Collecting cffi>=1.12
Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
Collecting pycparser
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
Collecting idna>=2.0
Using cached https://www.piwheels.org/simple/idna/idna-3.3-py3-none-any.whl (64 kB)
Building wheels for collected packages: cryptography
Building wheel for cryptography (pyproject.toml): started
Building wheel for cryptography (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
× Building wheel for cryptography (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [179 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-37
creating build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
creating build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files found matching 'mypy.ini'
warning: no previously-included files matching '*' found under directory '.circleci'
adding license file 'LICENSE'
adding license file 'LICENSE.APACHE'
adding license file 'LICENSE.BSD'
adding license file 'LICENSE.PSF'
writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
copying src/cryptography/hazmat/bindings/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
running build_ext
running build_rust
/usr/local/lib/python3.7/dist-packages/setuptools/command/build_py.py:202: SetuptoolsDeprecationWarning: Installing 'cryptography.hazmat.bindings._rust' as data is deprecated, please list it in `packages`.
# Package would be ignored #
Python recognizes 'cryptography.hazmat.bindings._rust' as an importable package,
but it is not listed in the `packages` configuration of setuptools.
'cryptography.hazmat.bindings._rust' has been automatically added to the distribution only
because it may contain data files, but this behavior is likely to change
in future versions of setuptools (and therefore is considered deprecated).
Please make sure that 'cryptography.hazmat.bindings._rust' is included as a package by using
the `packages` configuration field or the proper discovery methods
(for example by using `find_namespace_packages(...)`/`find_namespace:`
instead of `find_packages(...)`/`find:`).
You can read more about "package discovery" and "data files" on setuptools
documentation page.
check.warn(importable)
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation/ for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.7.3
platform: Linux-5.10.103-v7+-armv7l-with-debian-10.12
pip: 22.2.2
setuptools: 65.3.0
setuptools_rust: 1.5.1
rustc: 1.41.1
[end of output]
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade zigpy-zigate
Collecting zigpy-zigate
Using cached https://www.piwheels.org/simple/zigpy-zigate/zigpy_zigate-0.9.2-py3-none-any.whl (39 kB)
Collecting pyserial-asyncio>=0.5
Collecting gpiozero
Using cached https://www.piwheels.org/simple/gpiozero/gpiozero-1.6.2-py2.py3-none-any.whl (148 kB)
Collecting pyserial>=3.5
Collecting pyusb>=1.1.0
Using cached https://www.piwheels.org/simple/pyusb/pyusb-1.2.1-py3-none-any.whl (58 kB)
Donc ça n’a pas réglé ton problème.
Tu peux revenir dans l’état précédent :
sudo pip3 install cryptography==3.4.8
akenad
Est ce que la restauration de la sauvegarde faite avant la mise à jour du plug in me permettra de faire repartir mon zigbee en attendant ?
J’ai fait ça, issu de la doc:
Mais à part me dire qu’il y a pas python3 (donc pas besoin de l’enlever) et que pip3 est déjà ok, ça n’a rien donné.
Une restauration de jeedom changera rien car le soucis est au niveau os. Malheureusement la ton problème est nouveau il faut donc la log d’installation complete et l’analyse risque de prendre du temps comme la résolution si j’y arrive, c’est problèmes de dépendance c’est toujours très compliqué.
Le log d’installation des dépendances?
Il repart à zéro à chaque fois qu’il recommence, celui que j’ai mis au premier message est le plus complet que j’ai eu.
Le zigbee update:
Launch install of zigbee dependancy
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Fetched 13.0 MB in 12s (1124 kB/s)
Reading package lists...
Skipping serial as it is not installed.
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
python3 is already the newest version (3.7.3-1).
python3-dev is already the newest version (3.7.3-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1).
python3-setuptools is already the newest version (40.8.0-1).
python3-pip is already the newest version (18.1-5+rpt1).
Requirement already up-to-date: wheel in /usr/local/lib/python3.7/dist-packages (0.37.1)
Collecting pyserial
Using cached https://files.pythonhosted.org/packages/07/bc/587a445451b253b285629263eb51c2d8e9bcea4fc97826266d186f96f558/pyserial-3.5-py2.py3-none-any.whl
Installing collected packages: pyserial
Successfully installed pyserial-3.5
Requirement already up-to-date: zigpy in /usr/local/lib/python3.7/dist-packages (0.43.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy) (1.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.17.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy) (3.10.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy) (0.12.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (21.2.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy) (3.0.4)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.10.0.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (5.1.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (1.6.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy) (3.0.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy) (3.3)
Requirement already up-to-date: bellows in /usr/local/lib/python3.7/dist-packages (0.29.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.37.0 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.43.0)
Requirement already satisfied, skipping upgrade: click-log>=0.2.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (0.3.2)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from bellows) (0.5)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from bellows) (3.5)
Requirement already satisfied, skipping upgrade: click in /usr/local/lib/python3.7/dist-packages (from bellows) (7.1.2)
Requirement already satisfied, skipping upgrade: pure-pcapy3==1.0.1 in /usr/local/lib/python3.7/dist-packages (from bellows) (1.0.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from bellows) (0.12.1)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (3.10.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.37.0->bellows) (0.17.0)
Requirement already satisfied, skipping upgrade: setuptools in /usr/lib/python3/dist-packages (from pure-pcapy3==1.0.1->bellows) (40.8.0)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.10.0.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.0.1)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (21.2.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.37.0->bellows) (5.1.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.37.0->bellows) (3.3)
Requirement already up-to-date: zha-quirks in /usr/local/lib/python3.7/dist-packages (0.0.66)
Requirement already satisfied, skipping upgrade: zigpy>=0.42.0 in /usr/local/lib/python3.7/dist-packages (from zha-quirks) (0.43.0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (0.12.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.42.0->zha-quirks) (3.10.1)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.42.0->zha-quirks) (3.10.0.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (21.2.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (3.0.4)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (5.1.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (3.0.1)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.42.0->zha-quirks) (1.6.3)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.42.0->zha-quirks) (3.3)
Requirement already up-to-date: zigpy_znp in /usr/local/lib/python3.7/dist-packages (0.7.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.40.0 in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.43.0)
Requirement already satisfied, skipping upgrade: coloredlogs in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (15.0.1)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.12.1)
Requirement already satisfied, skipping upgrade: pyserial-asyncio; platform_system != "Windows" in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (0.5)
Requirement already satisfied, skipping upgrade: async-timeout in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (3.0.1)
Requirement already satisfied, skipping upgrade: jsonschema in /usr/local/lib/python3.7/dist-packages (from zigpy_znp) (3.2.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy_znp) (1.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy_znp) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy_znp) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy_znp) (0.17.0)
Requirement already satisfied, skipping upgrade: humanfriendly>=9.1 in /usr/local/lib/python3.7/dist-packages (from coloredlogs->zigpy_znp) (9.2)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio; platform_system != "Windows"->zigpy_znp) (3.5)
Requirement already satisfied, skipping upgrade: importlib-metadata; python_version < "3.8" in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy_znp) (1.7.0)
Requirement already satisfied, skipping upgrade: attrs>=17.4.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy_znp) (21.2.0)
Requirement already satisfied, skipping upgrade: setuptools in /usr/lib/python3/dist-packages (from jsonschema->zigpy_znp) (40.8.0)
Requirement already satisfied, skipping upgrade: six>=1.11.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy_znp) (1.16.0)
Requirement already satisfied, skipping upgrade: pyrsistent>=0.14.0 in /usr/local/lib/python3.7/dist-packages (from jsonschema->zigpy_znp) (0.18.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy_znp) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy_znp) (1.6.3)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy_znp) (3.10.0.0)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy_znp) (5.1.0)
Requirement already satisfied, skipping upgrade: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata; python_version < "3.8"->jsonschema->zigpy_znp) (3.6.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.40.0->zigpy_znp) (3.3)
Requirement already up-to-date: zigpy-xbee in /usr/local/lib/python3.7/dist-packages (0.14.0)
Requirement already satisfied, skipping upgrade: zigpy>=0.23.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.43.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-xbee) (0.5)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.12.1)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (1.0)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.23.0->zigpy-xbee) (3.10.1)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-xbee) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.23.0->zigpy-xbee) (3.10.0.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (1.6.3)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.4)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.0.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (5.1.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.23.0->zigpy-xbee) (21.2.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.23.0->zigpy-xbee) (3.3)
Requirement already up-to-date: zigpy-deconz in /usr/local/lib/python3.7/dist-packages (0.14.0)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.5)
Requirement already satisfied, skipping upgrade: zigpy>=0.40.0 in /usr/local/lib/python3.7/dist-packages (from zigpy-deconz) (0.43.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-deconz) (3.5)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (0.12.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (0.17.0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (1.0)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.40.0->zigpy-deconz) (3.10.1)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (3.0.4)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (3.10.0.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (1.6.3)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (5.1.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (21.2.0)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.40.0->zigpy-deconz) (3.0.1)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.40.0->zigpy-deconz) (3.3)
Requirement already up-to-date: zigpy-zigate in /usr/local/lib/python3.7/dist-packages (0.7.4)
Requirement already satisfied, skipping upgrade: zigpy>=0.22.2 in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.43.0)
Requirement already satisfied, skipping upgrade: RPi.GPIO in /usr/lib/python3/dist-packages (from zigpy-zigate) (0.7.0)
Requirement already satisfied, skipping upgrade: pyusb in /usr/lib/python3/dist-packages (from zigpy-zigate) (1.0.2)
Requirement already satisfied, skipping upgrade: pyserial-asyncio in /usr/local/lib/python3.7/dist-packages (from zigpy-zigate) (0.5)
Requirement already satisfied, skipping upgrade: voluptuous in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.12.1)
Requirement already satisfied, skipping upgrade: pycryptodome in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.10.1)
Requirement already satisfied, skipping upgrade: aiosqlite>=0.16.0 in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (0.17.0)
Requirement already satisfied, skipping upgrade: aiohttp in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (3.7.4.post0)
Requirement already satisfied, skipping upgrade: crccheck in /usr/local/lib/python3.7/dist-packages (from zigpy>=0.22.2->zigpy-zigate) (1.0)
Requirement already satisfied, skipping upgrade: pyserial in /usr/local/lib/python3.7/dist-packages (from pyserial-asyncio->zigpy-zigate) (3.5)
Requirement already satisfied, skipping upgrade: typing_extensions>=3.7.2 in /usr/local/lib/python3.7/dist-packages (from aiosqlite>=0.16.0->zigpy>=0.22.2->zigpy-zigate) (3.10.0.0)
Requirement already satisfied, skipping upgrade: chardet<5.0,>=2.0 in /usr/lib/python3/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.4)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (1.6.3)
Requirement already satisfied, skipping upgrade: async-timeout<4.0,>=3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.0.1)
Requirement already satisfied, skipping upgrade: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (5.1.0)
Requirement already satisfied, skipping upgrade: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp->zigpy>=0.22.2->zigpy-zigate) (21.2.0)
Requirement already satisfied, skipping upgrade: idna>=2.0 in /usr/local/lib/python3.7/dist-packages (from yarl<2.0,>=1.0->aiohttp->zigpy>=0.22.2->zigpy-zigate) (3.3)
Requirement already up-to-date: tornado in /usr/local/lib/python3.7/dist-packages (6.1)
Après je sais pas quoi vous donner.
J’ai déjà essayé de réinstaller le plugin (sans avoir desinstallé bien sûr). D’ailleurs le log au dessus c’est celui de la réinstall.
Est ce que je suis le seul à être en rust 1.41? Si oui, je voudrai savoir comment le mettre à jour. A moins que ça n’ai rien à voir et j’arrête d’en parler.
J’ai parlé trop vite, il vient enfin de lacher l’affaire sur l’installation des dépendances donc j’ai un fichier complet.
zigbee_packages(2).txt (154,7 Ko)
Non tu n’es pas le seul …je suis en train de refaire une install from scratch avec la derniere image jeedom pour rpi … et je suis face au meme soucis que toi.
La version 1.48 de rustc est pas la version debian 11 alors que nous on est en 10 …le pb ne viendrait il pas de la ?
ok. J’ai été bête. J’ai regardé le changelog qui datait du 02/09, je pensais donc que ça faisait 5 jours que c’était déployé et comme je regarde le forum tout les jours et que j’ai pas vu de soucis, j’y suis allé. En fait le plugin est du 04/09, j’ai pas fait attention.
J’ai malheureusement pas de quoi tester (pas de rpi) mais de ce que je vois debian 10 sur rpi n’est plus compatible avec le plugin il va falloir debian 11 pour avoir la nouvelle version de rustc pour pouvoir installer cryptogtaphie.
Il faudrait que quelqu’un test deja pour confirmer. Ensuite si c’est le cas je remonterais le soucis a Jeedom SAS.
Merci @Loic pour ton retour … la liste des incompatibilité jeedom / bullseye (https://doc.jeedom.com/fr_FR/compatibility/debian11) … je vais migrer ce nouveau jeedom sur un debian 11
Je connais cette liste c’est moi qui l’ai faite, après perso je tourne en debian 11 depuis sa sortie et aucun soucis (mais j’ai pas de zwave).
Exactement le même souci de dépendances… Cryptography semble ne pas s’accorder avec Rust.
Seule solution pour l’instant : rester comme ça sans ZigBee ou passer à Debian 11 et perdre le Z-Wave !? Bof bof
En espérant qu’il y ait une meilleure solution prochainement…
Si je peux aider, faites-le-moi savoir
La solution a été mise en beta.
Bonjour à tous, j’ai exactement le même problème que Fabx4 depuis hier et malheureusement tous mon système repose sur le zigbee donc plus rien ne fonctionne et cela va devenir compliqué pour mes scenario si quelqu’un a une solution j’ai vraiment tous essayé ce que j’ai trouvé sur tous les tuto
Passer en beta.
Peut tu me donné la méthode pour le faire ou un lien car je perd patience a cherché une solution et je n’arrive plus rien STP Merci
Il faut activer le profil beta testeurs dans le market et installé la version beta du plugin zigbee. Mais attention, c’est une beta.
