j’ai une erreur lorsque j’utilise la connexion local du plugin jeedom
03/29/2020 08:09:06 - Hello DeltaDore! <3
03/29/2020 08:09:06 - Unix 5.3.0.1019
03/29/2020 08:09:07 - Jeedore Daemon is starting in local network mode...
03/29/2020 08:09:07 - Websocket connection initialization....
03/29/2020 08:09:07 - Connecting to '172.16.100.100'
03/29/2020 08:09:08 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.An error has occurred during a TLS handshake. at WebSocketSharp.WebSocket.SetClientStream() in C:\Users\EliZium\source
epos\jeedore-daemon\WebSocketSharp\WebSocket.cs:line 1824
at WebSocketSharp.WebSocket.doHandshake() in C:\Users\EliZium\source
epos\jeedore-daemon\WebSocketSharp\WebSocket.cs:line 1116
at WebSocketSharp.WebSocket.connect() in C:\Users\EliZium\source
epos\jeedore-daemon\WebSocketSharp\WebSocket.cs:line 989'
03/29/2020 08:09:08 - Jeedore Daemon connection has been closed...
03/29/2020 08:09:08 - Connection to DeltaDore server has been closed...
03/29/2020 08:09:08 - Server started. Listening to TCP clients at 127.0.0.1:13666
03/29/2020 08:09:13 - Websocket connection initialization....
03/29/2020 08:09:13 - Connecting to '172.16.100.100'
03/29/2020 08:09:13 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.An error has occurred during a TLS handshake. at WebSocketSharp.WebSocket.SetClientStream() in C:\Users\EliZium\source
03/29/2020 08:09:13 - Jeedore Daemon connection has been closed...
03/29/2020 08:09:13 - Connection to DeltaDore server has been closed...
03/29/2020 08:09:18 - Websocket connection initialization....
03/29/2020 08:09:18 - Connecting to '172.16.100.100'
03/29/2020 08:09:18 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.An error has occurred during a TLS handshake. at WebSocketSharp.WebSocket.SetClientStream() in C:\Users\EliZium\source
03/29/2020 08:09:18 - Jeedore Daemon connection has been closed...
03/29/2020 08:09:18 - Connection to DeltaDore server has been closed...
03/29/2020 08:09:23 - Websocket connection initialization....
03/29/2020 08:09:23 - Connecting to '172.16.100.100'
03/29/2020 08:09:23 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.An error has occurred during a TLS handshake. at WebSocketSharp.WebSocket.SetClientStream() in C:\Users\EliZium\source
03/29/2020 08:09:23 - Jeedore Daemon connection has been closed...
03/29/2020 08:09:23 - Connection to DeltaDore server has been closed...
03/29/2020 08:09:28 - Websocket connection initialization....
03/29/2020 08:09:28 - Connecting to '172.16.100.100'
03/29/2020 08:09:28 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.An error has occurred during a TLS handshake. at WebSocketSharp.WebSocket.SetClientStream() in C:\Users\EliZium\source
03/29/2020 08:09:28 - Jeedore Daemon connection has been closed...
03/29/2020 08:09:28 - Connection to DeltaDore server has been closed...
mais dès que j’utilise la connexion remote pas de soucis:
Statut
Action
Version
2020-03-04 00:07:24
Version minimum Jeedom
3.0
License
MIT License
Logs et surveillance
Niveau log
Aucun Defaut Debug Info Warning Error
Logs
Heartbeat (min)
Redémarrer démon
Dépendances
Nom Statut Installation Dernière installation
Local OK
2020-03-16 21:30:36
Démon
Nom Statut Configuration (Re)Démarrer Arrêter Gestion automatique Dernier lancement
Local OK OK
2020-03-29 10:09:50
Configuration
MAC address
Password
AlarmCode
Network
IP
JeedomAlert
JeedomIP
JeedomPort
Theme
Architecture
AlarmId
Fonctionnalités
interact
Non
cron
Non
cron5
Non
cron10
Non
cron15
Non
cron30
Non
cronHourly
Oui
Activer
cronDaily
Oui
Activer
deadcmd
Non
health
Non
Log du plugin
03/29/2020 08:09:51 - Hello DeltaDore! <3
03/29/2020 08:09:51 - Unix 5.3.0.1019
03/29/2020 08:09:52 - Jeedore Daemon is starting in remote network mode...
03/29/2020 08:09:52 - Websocket connection initialization....
03/29/2020 08:09:52 - Connecting to 'mediation.tydom.com'
03/29/2020 08:09:54 - Websocket connection has been opened!
03/29/2020 08:09:54 - Jeedore Daemon is connecting to DeltaDore...
03/29/2020 08:09:54 - Sending command 1585469394336 to DeltaDore...
03/29/2020 08:09:58 - Sending command 1585469398360 to DeltaDore...
03/29/2020 08:10:00 - Sending command 1585469400363 to DeltaDore...
03/29/2020 08:10:02 - Jeedore Daemon is authenticating to a DeltaDore alarm!
03/29/2020 08:10:02 - Sending command 1585469402372 to DeltaDore...
03/29/2020 08:10:04 - Jeedore Daemon is connected to DeltaDore! :-*
03/29/2020 08:10:05 - Connection to DeltaDore server has been opened...
03/29/2020 08:10:05 - Server started. Listening to TCP clients at 127.0.0.1:13666
03/29/2020 08:10:10 - Sending command 1585469410332 to DeltaDore...
03/29/2020 08:10:12 - An expected message has been received from DeltaDore
03/29/2020 08:10:12 - Sending DeltaDore response to Jeedom, command : 'getcmddata'...
03/29/2020 08:10:12 - Command '1557521616#1557521616' has been posted to Jeedom successfully!
03/29/2020 08:10:12 - Sending DeltaDore response to Jeedom, command : 'getinstant'...
03/29/2020 08:10:12 - Command 'energyInstant ELEC_A' has been posted to Jeedom successfully!
03/29/2020 08:10:15 - Sending command 1585469415330 to DeltaDore...
03/29/2020 08:10:15 - An expected message has been received from DeltaDore
03/29/2020 08:10:15 - Sending DeltaDore response to Jeedom, command : 'getinstant'...
avez vous déjà eu cette erreur ?
ma config:
- jeedore 3.0
- jeedom 4.0.45
- Raspberry Pi 4 Model B Rev 1.1
- Ubuntu 19.10
Merci d’avance
