J’ai installaé le plugin Homewizard le 16 juillet dernier , qui fonctionne très bien, et j’ai remarqué depuis ce jour que le daemon de mon plugin RFLINK s’est planté et ne veut plus redémarer .
le log me dit que il ne trouve pas les bindings files
Node.js v22.23.2
Sat Aug 22 2026 22:50:05 GMT+0200 (Central European Summer Time) - Jeedom url : http://127.0.0.1:80/plugins/rflink/core/api/rflink.php?apikey=s5SlfywyGDGtYg831pDjUDMSbNEx0ytR, gwAddress : /dev/ttyACM0
/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:135
throw err;
Error: Could not locate the bindings file. Tried:
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/Debug/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/Release/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/out/Debug/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/Debug/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/out/Release/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/Release/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build/default/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/compiled/22.23.2/linux/arm64/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
→ /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/binding/node-v127-linux-arm64/bindings.node
at bindings (/var/www/html/plugins/rflink/resources/node_modules/bindings/bindings.js:126:9)
at Object.<anonymous> (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module.\_compile (node:internal/modules/cjs/loader:1781:14)
at Object..js (node:internal/modules/cjs/loader:1913:10)
at Module.load (node:internal/modules/cjs/loader:1505:32)
at Function.\_load (node:internal/modules/cjs/loader:1309:12)
at wrapModuleLoad (node:internal/modules/cjs/loader:254:19)
at Module.require (node:internal/modules/cjs/loader:1527:12)
at require (node:internal/modules/helpers:147:16)
at Object.<anonymous> (/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/lib/index.js:14:22)
y a t il un souci entre ces deux plugings ?
J’ai déjà relancé un rebuild mais rien n’y fait.
Quelqu’un aurait-il une idée ?
Merci beaucoup
